nRF91 How to use Google's primary and backup root CA on the modem?
I want to connect to Google Cloud IoT with a modified asset_tracker and want the TLS done by the modem like in asset_tracker.
Google has a primary and a backup root CA for IoT and they may switch between the primary and backup certificates at any time without notice
See here cloud.google.com/.../mqtt-bridge
Is it enough to install these certificates (in the right converted form) as type 0 with different sec_tags on the modem?
I hope :)
With kind regards,
Árpád
  • Hi Simon,
    update: The different root CAs should come to different sec_tags installed on the modem and that sec_tags must be referenced from the application software. That's clear me now.
    But I have a problem when I try to verify the peer in the TLS connection:
    struct mqtt_sec_config *tls_config =  &client->transport.tls.config;
    tls_config->peer_verify = MQTT_TRANSPORT_SECURE;
    results in EOPNOTSUPP 95 (Operation not supported on socket)
    When I use
    tls_config->peer_verify = TLS_PEER_VERIFY_NONE;
    I can connect.
    The peer verification works on Amazon with its sha256WithRSAEncryption signature. Google's signature for mqtt.2030.ltsapis.goog is an ecdsa-with-SHA256 signature.
    Is that not supported?
    Is this a bug in the modem software?
    I use the latest one (mfw_nrf9160_1.2.0.zip).
    With best regards,
    Árpád
  • Hi Simon,
    this is not a big problem for me now: this one is much bigger :)
    Árpád
  • Currently, a huge portion of the support team (including many of the experts on nRF9160) is on summer vacation, and you may experience delayed answers. My apologies for that.
    I will try to provide you with an answer within this week.
    Simon
