Proper memory settings for S340 SoftDevice Bike Power TX Example?
Currently working on flashing the bike power tx example to my Arduino Nano 33 which uses a NINA-B306 nRF52840. The device is wiped clean with only the s340 softdevice loaded. No bootloader is present. I have defined a custom board definition with nrf_gpio and have successfully flashed some other non-softdevice examples like Blinky. I believe my custom board definition is good, but I'm not fully confident.
When I flash the bike power tx example I start off by erasing the device. Then I flash the s340 softdevice. Finally I flash the bike power tx application via SES.
My Garmin 500 Edge does not receive any ANT+ data, so something is broken. Also two of my board LEDs are stuck in the on position. It could be my board definition, but it could also be my linker_section_placement_macros which are as follows:
FLASH_PH_START=0x0;
FLASH_PH_SIZE=0x80000;
RAM_PH_START=0x20000000;
RAM_PH_SIZE=0x10000;
FLASH_START=0x31000;
FLASH_SIZE=0x6e000;
RAM_START=0x20002000;
RAM_SIZE=0xf480"
I have read the guidelines on memory adjustments but I am still sort of lost. For example, if FLASH_SIZE > FLASH_PH_SIZE - FLASH_START, which one do I adjust? Also, what does the PH even stand for? I cannot find documentation on this unfortunately.
