I am using SDK 14.01 and ble_app_beacon example in that, I want to send updated sensor data in advertising. Using ble_advdata_set() I am able to send the updated data in advertising based on interval. but due to more data length, I have to used scan response(2nd argument of the function) to send more data. But In that, I am unable to send it.
* Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_beacon_main main.c
* @ingroup ble_sdk_app_beacon
* @brief Beacon Transmitter Sample Application main file.
* This file contains the source code for an Beacon transmitter sample application.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "math.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(20, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0 /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO 18 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS 0x10001080 /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
#define SCAN_DURATION_WITELIST 0x00 /**< Duration of the scanning in units of 10 milliseconds. */
#define NRF_BLE_SCAN_SCAN_INTERVAL 0x0032
#define NRF_BLE_SCAN_SCAN_DURATION 0
#define NRF_BLE_SCAN_SCAN_WINDOW 0x0019
#define APP_BLE_OBSERVER_PRIO 0
APP_TIMER_DEF(Brodcast_data_timer_id); /**< broudcasting data */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
static ble_gap_scan_params_t m_scan_param = /**< Scan parameters requested for scanning and connection. */
.active = 1,
.interval = NRF_BLE_SCAN_SCAN_INTERVAL,
.window = NRF_BLE_SCAN_SCAN_WINDOW,
.timeout = NRF_BLE_SCAN_SCAN_DURATION,
#if (NRF_SD_BLE_API_VERSION <= 2)
.selective = 0,
.p_whitelist = NULL,
#if (NRF_SD_BLE_API_VERSION >= 3)
.use_whitelist = 0,
/**@brief Variable length data encapsulation in terms of length and pointer to data */
typedef struct
uint8_t * p_data; /**< Pointer to data. */
uint16_t data_len; /**< Length of data. */
}data_t;
static bool scan_evt = false;
static uint8_t scan_result_not_avail_count = 0U;
#if 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
// implementation.
APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
// manufacturer specific data in this implementation.
APP_BEACON_UUID, // 128 bit UUID value.
APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons.
APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons.
APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in
// this implementation.
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
static void brodcast_data_timer_handler(void * p_context)
ble_advdata_t scanrsp;
ble_advdata_manuf_data_t manuf_data;
uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
uint32_t err_code;
memset(&scanrsp, 0, sizeof(scanrsp));
int i = 0;
for(i = 0; i < 1; i++){
manuf_data.data.p_data = node_db[i].bda;
manuf_data.data.size = sizeof(node_db[i].bda);
scanrsp.name_type = BLE_ADVDATA_NO_NAME;
scanrsp.flags = flags;
scanrsp.p_manuf_specific_data = &manuf_data;
NRF_LOG_INFO("ble_advdata_set\r\n");
err_code = ble_advdata_set(NULL, &scanrsp);
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
uint32_t err_code;
ble_advdata_t advdata;
ble_advdata_manuf_data_t manuf_specific_data;
/*#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
// UICR instead of using the default values. The major and minor values obtained from the UICR
// are encoded into advertising data in big endian order (MSB First).
// To set the UICR used by this example to a desired value, write to the address 0x10001080
// using the nrfjprog tool. The command to be used is as follows.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
// the following command should be used.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;*/
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
manuf_specific_data.data.p_data = (uint8_t *) manufacure_adv_data;
manuf_specific_data.data.size = MANUFACTURE_DATA_LEN;
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
err_code = ble_advdata_set(&advdata, NULL);
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
m_adv_params.type = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.fp = BLE_GAP_ADV_FP_ANY;
m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.timeout = 0; // Never time out.
/**@brief Function for starting timer.
static void timer_start(void)
ret_code_t err_code;
// Start application timers.
err_code = app_timer_start(Brodcast_data_timer_id, BRODCASTING_INTERVAL, NULL);
err_code = sd_ble_gap_adv_start(&m_adv_params, APP_BLE_CONN_CFG_TAG);
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing LEDs. */
static void leds_init(void)
bsp_board_leds_init();
//ret_code_t err_code = bsp_init(BSP_INIT_LED, NULL);
//APP_ERROR_CHECK(err_code);
/**@brief Function for initializing timers. */
static void timers_init(void)
/*Create a timer instance*/
err_code = app_timer_create(&Brodcast_data_timer_id,
APP_TIMER_MODE_REPEATED, brodcast_data_timer_handler);
/**@brief Function for doing power management. */
static void power_manage(void)
ret_code_t err_code = sd_app_evt_wait();
/**@brief Function to start scanning.
static void scan_start(void)
(void) sd_ble_gap_scan_stop();
err_code = sd_ble_gap_scan_start(&m_scan_param);
* @brief Function for application main entry.
// Initialize.
log_init();
timers_init();
leds_init();
ble_stack_init();
advertising_init();
timer_start();
scan_start();
advertising_start();
// Start execution.
NRF_LOG_INFO("Beacon example started.");
// Enter main loop.
for (;; )
power_manage();
Can anyone please help? I have attached an example file.
