Updating Advertising and scan response Packet dynamically using ble_advdata_set
I am using SDK 14.01 and ble_app_beacon example in that, I want to send updated sensor data in advertising. Using ble_advdata_set() I am able to send the updated data in advertising based on interval. but due to more data length, I have to used scan response(2nd argument of the function) to send more data. But In that, I am unable to send it.
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_beacon_main main.c
 * @ingroup ble_sdk_app_beacon
 * @brief Beacon Transmitter Sample Application main file.
 * This file contains the source code for an Beacon transmitter sample application.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "math.h"
#define APP_BLE_CONN_CFG_TAG            1                                 /**< A tag identifying the SoftDevice BLE configuration. */
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(20, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                              /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                              /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                              /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                              /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER          0x0059                            /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                        /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                        /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                        /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                        /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
#define SCAN_DURATION_WITELIST 			0x00							  /**< Duration of the scanning in units of 10 milliseconds. */
#define NRF_BLE_SCAN_SCAN_INTERVAL		0x0032
#define NRF_BLE_SCAN_SCAN_DURATION 		0
#define NRF_BLE_SCAN_SCAN_WINDOW		0x0019
#define APP_BLE_OBSERVER_PRIO           0
APP_TIMER_DEF(Brodcast_data_timer_id); 					  				  /**< broudcasting data */
NRF_BLE_SCAN_DEF(m_scan);                                 /**< Scanning Module instance. */
static ble_gap_scan_params_t m_scan_param =               /**< Scan parameters requested for scanning and connection. */
    .active        = 1,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .timeout       = NRF_BLE_SCAN_SCAN_DURATION,
    #if (NRF_SD_BLE_API_VERSION <= 2)
        .selective   = 0,
        .p_whitelist = NULL,
    #if (NRF_SD_BLE_API_VERSION >= 3)
        .use_whitelist = 0,
/**@brief Variable length data encapsulation in terms of length and pointer to data */
typedef struct
    uint8_t * p_data;   /**< Pointer to data. */
    uint16_t  data_len; /**< Length of data. */
}data_t;
static bool scan_evt = false;
static uint8_t scan_result_not_avail_count = 0U;
#if 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
static void brodcast_data_timer_handler(void * p_context)
	ble_advdata_t scanrsp;
	ble_advdata_manuf_data_t manuf_data;
	uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
	uint32_t      err_code;
	memset(&scanrsp, 0, sizeof(scanrsp));
	int i = 0;
	for(i = 0; i < 1; i++){
			manuf_data.data.p_data = node_db[i].bda;
			manuf_data.data.size = sizeof(node_db[i].bda);
			scanrsp.name_type             = BLE_ADVDATA_NO_NAME;
			scanrsp.flags                 = flags;
			scanrsp.p_manuf_specific_data = &manuf_data;
			NRF_LOG_INFO("ble_advdata_set\r\n");
			err_code = ble_advdata_set(NULL, &scanrsp);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_manuf_data_t manuf_specific_data;
/*#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;*/
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    manuf_specific_data.data.p_data = (uint8_t *) manufacure_adv_data;
    manuf_specific_data.data.size   = MANUFACTURE_DATA_LEN;
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
	err_code = ble_advdata_set(&advdata, NULL);
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
    m_adv_params.p_peer_addr = NULL;    // Undirected advertisement.
    m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval    = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.timeout     = 0;       // Never time out.
/**@brief Function for starting timer.
static void timer_start(void)
    ret_code_t err_code;
	// Start application timers.
	err_code = app_timer_start(Brodcast_data_timer_id, BRODCASTING_INTERVAL, NULL);
    err_code = sd_ble_gap_adv_start(&m_adv_params, APP_BLE_CONN_CFG_TAG);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing LEDs. */
static void leds_init(void)
	bsp_board_leds_init();
    //ret_code_t err_code = bsp_init(BSP_INIT_LED, NULL);
    //APP_ERROR_CHECK(err_code);
/**@brief Function for initializing timers. */
static void timers_init(void)
	/*Create a timer instance*/
	err_code = app_timer_create(&Brodcast_data_timer_id,
        APP_TIMER_MODE_REPEATED, brodcast_data_timer_handler);
/**@brief Function for doing power management. */
static void power_manage(void)
    ret_code_t err_code = sd_app_evt_wait();
/**@brief Function to start scanning.
static void scan_start(void)
    (void) sd_ble_gap_scan_stop();
    err_code = sd_ble_gap_scan_start(&m_scan_param);
 * @brief Function for application main entry.
    // Initialize.
    log_init();
    timers_init();
    leds_init();
    ble_stack_init();
    advertising_init();
	timer_start();
	scan_start();
	advertising_start();
    // Start execution.
	NRF_LOG_INFO("Beacon example started.");
	// Enter main loop.
    for (;; )
            power_manage();
Can anyone please help? I have attached an example file.
