nRF connect for desktop BLE & DTM apps opens with a blank window
Like many posts before I'm facing blank white screen when trying to run nRFCOnnect for desktop (3.4.1) BLE app (2.4.0)
Tried to:
  • Restart PC
  • Uninstall-reinstall 3.4.1
  • Uninstall-reinstall 3.4.0
  • Uninstall-install latest nrf command line tools-reinstall (link)
  • Use nRF52840 (PCA10056) dongle
  • Use nRF52832 (PCA10031) dongle
  • Use another fresh nRF52840 dongle
all to no avail....
Same blank screen occurs on all other NRFConnect's apps: DTM, RSSI viewer, Programmer but NOT with the toolchain manager... implying it stems from (probably) the same root cause (jlink driver? graphic library?)
Any advise ?
  • Make sure that you are not using any terminal window/tools that are accessing or claiming the COM ports on the PC. I have seen that cause the windows to hang (white screen). You can try to press ctrl+R to refresh the white screen.
    You may try to uninstall segger j-link tools and nrf command line tools also, before installing nrf connect for desktop again. You can also try to install the latest nrf command line tools (that also bundles segger j-link) to see if that helps.
  • Thanks for the prompt response.
    seems that your advise "Make sure that you are not using any terminal window/tools that are accessing or claiming the COM ports on the PC" works
    Thanks again
  • I am having the exact same issue, however, I had been using the BLE app for 3 weeks and have changed nothing. Now, all of a sudden today, I have the blank with screen. I have no other apps running. I.E. nothing claiming the COM ports. I have uninstalled and reinstalled the app, reboot, etc.
    Are there any other ideas?
    I have:
    BLE tool v4.0.4
    nRF Connect for Desktop v4.1.2
    thanks
  • I am running Ubuntu 22.04 and use nRF Connect for Desktop v4.1.2
    My BLE tool v4.0.4 window blanks only after selecting the adapter/USB device (both nRF52840 DK and nRF52 DK, adapter programming / image download through JLink still works). It is similar to the problem described here
    Other nRF Connect applications (e.g. RSSI viewer) work fine.
    Reinstalling nrf command line tools as suggested and even downgrading JLink do not help in my case.
    I double checked my udev rules and read/write permission to serial ports, ttyACM / CDC)
    It had been working until yesterday, I never had the "blank window" issue before. Ctrl-R does not help, it will just repeat the crash. From my /var/log/syslog:
    systemd[1]: tmp-.mount_nrfconf256ro.mount: Deactivated successfully.
    kernel: [ 78.648080] nrfconnect-blue[1821]: segfault at 0 ip 00007fca09eb542b sp 00007fca05dfcba8 error 4 in libstdc++.so.6.0.30[7fca09e7d000+111000]
    kernel: [ 78.648121] Code: 0f 1f 80 00 00 00 00 31 d2 e9 14 ff ff ff 90 49 89 f0 48 8b 0f 48 8b 77 08 48 89 fa b8 fe ff ff ff 48 29 ce 0f 84 8a 00 00 00 <0f> b6 01 83 f8 7f 0f 86 89 00 00 00 3d c1 00 00 00 76 72 3d df 00
  • Hi X2023. I just updated to the latest libstdc++6 version and the problem persists.
    I am going to try to go back a version.
