Null pointer dereferenced in sdc_handler in SDK 17.0.0
While upmerging our project from SDK 15.3.0 to 17.0.0 we faced an issue in the sdc_handler due to usage of a NULL pointer.
In the case SDC_EVT_INIT if the p_event->result is not SDC_SUCCESS the block_dev_sdc_uninit function is called. It in turn sets m_active_sdc_dev = NULL (line 223) if uninit is success.
Then when calling the "if (m_active_sdc_dev->p_work->ev_handler)" in the sdc_handler at line 93 a NULL pointer is used.
Do you confirm this ?
Could you provide a solution ?
Thanks in advance
    I see two possible workarounds.
    1. Add a break; at the end of the first if statement.
      case SDC_EVT_INIT:
                      if (p_event->result != SDC_SUCCESS)
                          nrf_block_dev_t const * block_dev = &(p_sdc_dev->block_dev);
                          ret_code_t err_code = block_dev_sdc_uninit(block_dev);
                      p_work->geometry.blk_count = app_sdc_info_get()->num_blocks;
                      p_work->geometry.blk_size  = SDC_SECTOR_SIZE;
                          const nrf_block_dev_event_t ev = {
                                  NRF_BLOCK_DEV_EVT_INIT,
                                  ((p_event->result == SDC_SUCCESS) ? \
                                          NRF_BLOCK_DEV_RESULT_SUCCESS : NRF_BLOCK_DEV_RESULT_IO_ERROR),
                                  NULL,
                                  p_work->p_context
                          p_work->ev_handler(&p_sdc_dev->block_dev, &ev);
    2. Move the first if statement after the second if statement, to allow passing the result of the init back to the event handler before uninit.
      case SDC_EVT_INIT:
                                  NULL,
                                  p_work->p_context
    Jørgen
  • Hi Jørgen,
    Sorry to come back late on your answer.
    We’ve selected 2. as final fix. This is cleaner to us (uses the ev_handler, avoids having an early break statement, ...).
    Note that we didn’t test the 1.
    Best regards
    Benoît
