$i2c1 {
dac80501@48 {
compatible = "ti,dac80501";
reg = <0x48>;
3. write the driver in zephyr/drivers/adc/
Do you have any more specific questions regarding 1 and 2? How far have you come with the implementation?
I would recommend reading Device Driver Model and understand that, which will give you a great starting point. Then I would look at the already present Sensor drivers and try to mirror them. E.g. if you use the adxl362 as a reference, look at the yaml file zephyr\dts\bindings\sensor\adi,adxl362.yaml, the driver in zephyr\drivers\sensor\adxl362 and the sample zephyr\samples\sensor\adxl362 which shows how to use that driver. The sample doesn't interract with the adxl362 driver directly but uses the Sensor Subsystem on top of that. Take a look at the figure below to see all the abstraction layers included:
There may be some step-by-step tutorials on how to do this, but I couldn't find it after a quick search.
Since this is a more Zephyr related question, you may get better help here:
Simon
Hi Simon,
I have a custom board based on nRF5340. I have SDA connected to pin P1.02 and SCL connected to pin P1.03.
I've made some progress following your suggestions.
1. The DTS section of the board looks like this
&i2c1 {
status = "okay";
clock-frequency = <100000>;
sda-pin = <33>;
scl-pin = <34>;
dac: dacx0501@48 {
compatible = "ti,dacx0501";
label = "DAC80501";
reg = <0x48>;
2. For the binding part I've added file /ncs/zephyr/dts/bindings/sensor/ti,dacx0501.yaml with content
description: Texas Instruments 12/14/16-bit DAC (e.g. DAC80501)
compatible: "ti,dacx0501"
include: i2c-device.yaml
(You might wander why to put a DAC into sensor branch. This is just a temporary measure.)
3. For the driver part I've added files under /ncs/zephyr/drivers/sensors/dacx0501/
dacx0501.c
dacx0501.h
Kconfig
At the very first I2C reading from device
if (i2c_read(drv_data->i2c, buf, 4, DT_INST_REG_ADDR(0)) < 0) {
LOG_ERR("Failed to read sample data");
return -EIO;
I get an error log message
E: Error 195952641 occurred for message 0
which correspondes to error number 0xBAE0000, or "NRFX_ERROR_DRV_TWI_ERR_ANACK".
Can you figure out how to fix this ?
Best Regards,
Gabriele
Additional information you might find of worth
DT_INST_REG_ADDR(0) expands to 72
As for the zephyr configuration added to prj.conf
CONFIG_I2C=y
CONFIG_I2C_1=y
CONFIG_SENSOR=y
CONFIG_DACX0501=y
Gabriele
My bad mistake! The correct gpio numbers are
sda-pin = <34>;
scl-pin = <35>;
This issue is closed.
I've been working on adding a new sensor.
This ticket has been very helpful.
Just thought I should add for others that you'll also want to modify these files when adding a new sensor
add_subdirectory_ifdef(CONFIG_<name of sensor> <sensor directory>)
