Install micro-ecc with SEGGER
Hi
I'm trying to use Crypto but can't get started because micro-ecc isn't installed
The install instructions say:
Enter the subdirectory for the SoC and the toolchain that you are using to build your application:
  • InstallFolder\external\micro-ecc\nrf52_keil\armgcc
  • InstallFolder\external\micro-ecc\nrf52_iar\armgcc
  • InstallFolder\external\micro-ecc\nrf52_armgcc\armgcc
What about Segger Embedded Studio? (nRF52832)
Also, is it necessary to install extra build tools (i.e. isn't is possible to compile this stuff in the IDE?)
Thanks
    We are not allowed to provide micro-ecc with the SDK due to limitations in the license of the library. If you want to use the micro-ecc backend, you need to build it yourself using GCC. See the instructions here.
    By default, the micro-ecc backend is not used in the crypto examples, the nRF_Oberon backend is used (NRF_CRYPTO_BACKEND_OBERON_ENABLED=1). You can exclude/remove the micro-ecc library file (micro_ecc_lib_nrf52.a) from the project if you do not intend to use it. That way you should be able to build the examples in SES without any need for additional tools.
    Jørgen
  • Hi. Yes I understand the licencing issue, and I was referring to the page you linked to which doesn't help because step 4 (which I quoted in my question) doesn't make any reference to SES. "Enter the subdirectory for the SoC and the toolchain that you are using to build your application" - there isn't a subdirectory for Segger.
    Anyway, I probably asked the wrong question because I was just trying to compile the SDK examples to start with which maybe isn't the best approach here.
    I need 2 crypto functions. AES  encrypt/decrypt, and MD5 for file checking. What libraries do I need to include?
    Sorry for misunderstanding your question. SES uses GCC as the compiler internally. The libraries built by GCC can be used with SES.
    You can see the backends supporting AES in the nrf_crypto library documentation. For nRF52832, only mbedTLS is available, as it does not have the CC310 HW Cryptocell module in the chip. For MD5, this is not supported by the nrf_crypto library at all. I believe this was decided to not implement because it is simple to do in SW and not that much used in small embedded systems. I see that mbedTLS has functions for calculating MD5 (external\mbedtls\library\md5.c), they are included in the nRF_Crypto examples and I think you should be able to call the API without any modifications.
    Jørgen
  • I have a follow up question.
    I want to use the ECDSA256 with the micro-ecc but for the life of me I cannot get a fully linked build.
    I keep getting this error in the bootloader:
        nrf_dfu_validation.c:(.text.nrf_dfu_validation_signature_check+0x3e): undefined reference to `nrf_crypto_hash_calculate'
    I have raised this issue in another ticket but wanted to see if you have any suggestions.
    What kind of backend can I use to support ECDSA256 on nRF52832 (no 310), SDK 16.0.0 and S132 v7.0.2
    Cheers
    RMV
