Most Significative Bit in TWIM RX transfer is always 1
While trying to communicate through I2C/TWI with a MCP39F521 using a NRF52 DK (NRF52832), the first bit of the received data is always 1. The NRF52 DK is the TWI Master and the MCP39F521 is the TWI slave.
According to the MCP39F521 datasheet, the first byte in a response is the ACK/NAK, which is 0x06 on an ACK and 0x15 on a NAK, but I am receiving 0x86, no matter the command I sent to the MCP39F521. However, the remaining of the transfer is received correctly and corresponds to what is expected for the sent command. A command, on this context, is a set of bytes sent in a given order and with a given value to the MCP39F521.
Moreover, the last byte of a command is the checksum of the sent data. This checksum is sent either from MCP39F521 to NRF52DK on an RX command and vice-versa on a TX command. According to the datasheet, the MCP39F521 only processes commands once the command is fully sent (STOP bit sent by the master) and only if the checksum is correct. From this, I conclude that the commands are being correctly sent to the TWI bus by the NRF52 DK and correctly received by the MCP39F521.
I do not have a scope or a logical analyzer, but debugging also shows the correct data being sent by the nrfx_twim_xfer.
On section 4.3, page 16 of the MCP39F521 datasheet, it is indicated that the MCP39F521 performs clock stretching and "In the case of the MCP39F521, after a frame is received, the device will hold the clock low until the frame has been processed. The maximum clock stretching duration is less than 10 milliseconds"
Tested with an Arduino and its Wire library, the first byte received is 0x06, and this problem does not occur.
From the previous, and to the best of my understanding, I believe that the NRF52 DK is sampling the SDA line too soon after a response from the MCP39F521 and this timing issue results on the SDA line not yet been driven low by theMCP39F521. Can someone confirm if my conclusion makes sense?
Also, I also believe to be experiencing the Errata 149 -  TWIM: First clock pulse after clock stretching may be too long or too short.
Comments or suggestions on how to tackle this issue are very much appreciated.
I am using the SDK v16.0.0, and the nrfx_twim drivers. I have already tried using the nrf_drv_twi and nrfx_twi, both blocking and non-blocking and the problem persists.
The TWIM config:
 * @brief TWIM initialization.
void twim_init (void)
    ret_code_t err_code;
    const nrfx_twim_config_t twim_config = {
       .scl                 = ARDUINO_SCL_PIN,
       .sda                 = ARDUINO_SDA_PIN,
       .frequency           = NRF_TWIM_FREQ_100K,
       .interrupt_priority  = NRFX_TWIM_DEFAULT_CONFIG_IRQ_PRIORITY,
       .hold_bus_uninit     = NRFX_TWIM_DEFAULT_CONFIG_HOLD_BUS_UNINIT
    err_code = nrfx_twim_init(&m_twi_master, &twim_config, twim_handler, NULL);
    nrfx_twim_enable(&m_twi_master);
The twim handler:
 * @brief TWI events handler.
void twim_handler(nrfx_twim_evt_t const * p_event, void * p_context)
  switch (p_event->type)
      case NRFX_TWIM_EVT_DONE:
      test = 1;
          if (p_event->xfer_desc.type == NRFX_TWIM_XFER_TX) // TX Done
            m_xfer_done = true;
          if (p_event->xfer_desc.type == NRFX_TWIM_XFER_RX) // RX Done
            m_xfer_done = true;
And the instruction to read a command frame. rx_data is passed by argument and resides in .data (global variable defined in main).
ret_code_t mcp39f521_reg_read(const uint16_t reg_address, const uint8_t n_bytes, uint8_t * rx_data)
  if (n_bytes > CMD_FRAME_MAX_REG_READ_BYTES)
    return NRF_ERROR_INVALID_PARAM;
  m_xfer_done = false;
  // partially Init Array (Checksum field not initialized)
  uint8_t cmd_frame[REG_READ_CMD_N_BYTES] = {MCP39F521_HEADER_BYTE, \
                                             REG_READ_CMD_N_BYTES, \
                                             MCP39F521_SET_ADR_PTR_INSTR, \
                                             (reg_address & LEFTMOST_BYTE_BIT_MASK) >> BYTE_SHIFT, \
                                             reg_address & RIGHTMOST_BYTE_BIT_MASK, \
                                             MCP39F521_REG_READ_INSTR, \
                                             n_bytes, \
  uint8_t bytes = n_bytes + MCP39F521_RESPONSE_BASE_N_BYTES;
  cmd_frame[REG_READ_CMD_N_BYTES - 1] = __compute_byte_addition_checksum(cmd_frame);      // Compute Command Checksum
  nrfx_twim_xfer_desc_t tx_xfer = NRFX_TWIM_XFER_DESC_TX(MCP39F521_BASE_ADDRESS, cmd_frame, sizeof(cmd_frame));
  nrfx_twim_xfer_desc_t rx_xfer = NRFX_TWIM_XFER_DESC_RX(MCP39F521_BASE_ADDRESS, rx_data, bytes);
  err_code = nrfx_twim_xfer(g_mcp39f521_twim_instance, &tx_xfer, 0  );
  if (err_code != NRF_SUCCESS) {
    NRF_LOG_DEBUG("TX Error Code: %d", err_code);
  while(m_xfer_done == false){
    __WFE();
  err_code = nrfx_twim_xfer(g_mcp39f521_twim_instance, &rx_xfer, 0 );
    NRF_LOG_DEBUG("RX Error Code: %d", err_code);
    __WFE();
  return err_code;
Thank you in advance!
    Your reasoning sounds plausible, but it would really help if you could get logic/scope traces of the bus to determine if this could be what is happening. It is strange if you see this every time if it is related to clock stretching unless the slave performs clock stretching on every transfer.
    Have you tried other slaves to see if they experience the same behavior?
    Jørgen
  • Long shot, but try comparing the total pull-up resistance between the DK and the Arduino (parallel combo of board and sensor board); if they are the same then this isn't an issue.
    I would also try H0D1 settings for both SDA and SCL pins. This is the default:
    #define TWIM_PIN_INIT(_pin) nrf_gpio_cfg((_pin),                     \
                                             NRF_GPIO_PIN_DIR_INPUT,     \
                                             NRF_GPIO_PIN_INPUT_CONNECT, \
                                             NRF_GPIO_PIN_PULLUP,        \
                                             NRF_GPIO_PIN_S0D1,          \
                                             NRF_GPIO_PIN_NOSENSE)
    This would be better
                                             NRF_GPIO_PIN_H0D1,          \
    The H0D1 can also be set after the i2c has been initialised using the io pin setup. The reason for trying this change is that weak clock drive can affect timing.
  • Your reasoning sounds plausible, but it would really help if you could get logic/scope traces of the bus to determine if this could be what is happening.
    Thank you for confirming . I am trying to get my hands on a scope/logic analyzer. If I can get one during the next week, I update my answer with scopes.
    From my understanding of the MCP39F521 datasheet, this is indeed true. The device performs clock stretching on every transfer. Regarding clock stretching, can you please inform how well are the twim drivers "prepared to deal with with"?
    I noticed several failed reads from the NRF52 DK and it seems that the MCU fails to wait for a response of the MCP39F521. This behavior happens on blocking and non-blocking mode and results on NRF_ERROR_INTERNAL or NRF_DEVICE_NACK.
    Also, despite the device supporting up to 400 kHz, the MCU only receives "garbage data" if the line is configured to 250 or 400 kHz.
    Not yet, but I will during the following days.
  • Thank you for the suggestions .
    Regarding the internal pull-up values, the Arduino Uno uses 20 kΩ and the NRF52 DK 13 kΩ. Since I am using the MCP39F521 Development Kit, it has 2.1 kΩ pull-ups on the I2C lines. This yields the total pull-up resistors for the Arduino setup to be 1.9 kΩ and 1.8 kΩ for the NRF52 DK.
    I have also tried using only the MCP39F521 Development Kit, pull ups, i.e., disabling the NRF52 DK internal pull-ups, but the result is the same (as would be expected, since the total pull-up values are very similar)
    The stronger low driver makes sense. I changed the GPIO drive mode to the High-Drive '0', but the result stays the same.
    As far as I know, handling of clock stretching performed by the TWI slave is handled purely in HW. There are no timeouts in the driver, so it should always wait for either a STOPPED or ERROR event to be generated (or SUSPENDED event in case of TX without STOP condition). It would really help if you could get some logic traces of the bus to see what is actually going on.
