nrf9160 GPS TCP MQTT
Hi All,
Recently I have been working on nrf9160dk board. The use case is to have nrf9160 work as a serial LTE modem with GPS functionality. I have the following link https://github.com/nrfconnect/sdk-nrf/tree/v1.3.0/applications/serial_lte_modem .
I am trying to run AT commands for GPS TCP and MQTT. I am not able to run the commands mentioned in the notes on github. The board locks out after the commands are entered. I think I don't have the correct use case of the commands I am using. Can someone please reply with the exact commands used and which worked on their board. That would be a great help.
Thanks in advanced
Regards
Nordic user
     What do you mean by "the exact commands used"? I'm pretty sure that the commands you are referring to should work. Can you please show exactly what you're doing and what you're trying to achieve and also include information that will help with the debugging like log outputs etc.?
