Trouble getting started on OS X
Version: Mac OS X 10.15.5 (19F101)
I'm using the nRF Connect app Getting Started Assistant and manage to get through most of it. However, when I use Segger to open up a sample project I'm faced with permissions issues trying to run executables of the embedded toolchain.
My work-around for that was to use Homebrew to install the GNU ARM Embedded toolchain as per https://github.com/osx-cross/homebrew-arm.
With that behind me, I then moved to the next problem when attempting to open a file within Segger.
When opening "/opt/nordic/ncs/nrf/applications/serial_lte_modem/CMakeLists.txt", selecting "/opt/nordic/ncs/nrf/boards/arm/nrf52840gmouse_nrf52840" as my board directory, I'm presented with a dialog box of warnings and errors:
Including boilerplate (Zephyr base): /opt/nordic/ncs/zephyr/cmake/app/boilerplate.cmake
nrf52840gmouse_nrf52840.dts.pre.tmp:161.22-169.5: Warning (unique_unit_address_if_enabled): /soc/i2c@40004000: duplicate unit-address (also used in node /soc/spi@40004000)
  also defined at nrf52840gmouse_nrf52840.dts.pre.tmp:423.7-427.3
warning: RTT_CONSOLE (defined at drivers/console/Kconfig:119) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: CONSOLE (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_RTT_CONSOLE.html and/or look up
RTT_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
/opt/nordic/ncs/nrf/applications/serial_lte_modem/prj.conf:26: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
/opt/nordic/ncs/nrf/applications/serial_lte_modem/prj.conf:41: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
/opt/nordic/ncs/nrf/applications/serial_lte_modem/prj.conf:42: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
warning: UART_0_NRF_HW_ASYNC (defined at drivers/serial/Kconfig.nrfx:74) has direct dependencies UART_0_NRF_UARTE && UART_ASYNC_API && (UART_0_NRF_UART || UART_0_NRF_UARTE) && UART_NRFX && SERIAL with value n, but is currently being y-selected by the following symbols:
 - SLM_CONNECT_UART_0 (defined at /opt/nordic/ncs/nrf/applications/serial_lte_modem/Kconfig:36), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y)
error: Aborting due to Kconfig warnings
CMake Error at /opt/nordic/ncs/zephyr/cmake/kconfig.cmake:217 (message):
  command failed with return code: 1
  /opt/nordic/ncs/zephyr/cmake/app/boilerplate.cmake:506 (include)
  /opt/nordic/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
  /opt/nordic/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
  CMakeLists.txt:20 (find_package)
...continuing beyond that yields, the following error:
Any pointers? I've gone over the install steps a number of times now. I'm looking forward to doing some development with my newly purchased boards. Thanks for any help.
Cheers,
-C
