STLINK-V2 -> ChipID = 0 / timed out while waiting for target halted
I'm beginner with nrf chips.
I have a custom board with ntf52840 module. I connect board to stlink via swd interface, then check:
st-info --probe
Found 1 stlink programmers
 serial: 2c38010032124353354b4e00
openocd: "\x2c\x38\x01\x00\x32\x12\x43\x53\x35\x4b\x4e\x00"
  flash: 0 (pagesize: 0)
   sram: 0
 chipid: 0x0000
  descr: unknown device
openocd -f /usr/share/openocd/scripts/interface/stlink-v2.cfg -f /usr/share/openocd/scripts/target/nrf52.cfg -d2
Open On-Chip Debugger 0.10.0
Licensed under GNU GPL v2
For bug reports, read
    openocd.org/.../bugs.html
debug_level: 2
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 10000 kHz
Info : Unable to match requested speed 10000 kHz, using 4000 kHz
Info : clock speed 4000 kHz
Info : STLINK v2 JTAG v29 API v2 SWIM v7 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 3.167187
Info : nrf52.cpu: hardware has 0 breakpoints, 2 watchpoints
telnet localhost 4444
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
> init
> reset halt
TARGET: nrf52.cpu - Not halted
in procedure 'reset'
in procedure 'ocd_bouncer'
Something wrong?
    Unfortunately we do not know this debugger and do not support it. We know that some have used it and that it might work in some cases or with some tools, but we can not give any guarantees. There is some material on Devzone, I recommend that you try searching for your answer.
    Andreas
  • that problem solved.
    /usr/local/bin/openocd -f $(OPENOCD_HOME)/interface/stlink-dap.cfg -f $(OPENOCD_HOME)/target/nrf52.cfg
    and
    >dap apreg 1 0x04 0x01
    unlocking chip.
    And next. Chip is 52840
    I download SDK nrf5_SDK_for_Mesh_v4.2.0_src.
    Then upload softdevice: s140_nrf52_6.0.0_softdevice.hex (or s140_nrf52_7.0.1_softdevice.hex)
    and demo: blinky_nrf52840_xxAA_s140_6.0.0.hex (or blinky_nrf52840_xxAA_s140_7.0.1.hex)
    by:
    write_blinky600:
        $(OCD) -c init -c "reset halt" -c "flash write_image $(BLINKY_FILE_140_600)" -c "flash write_image $(BLINKY_FILE_140_600)" -c reset -c exit
    write_blinky701:
        $(OCD) -c init -c "reset halt" -c "flash write_image $(SOFTDEV_140_701)" -c "flash write_image $(BLINKY_FILE_140_701)" -c reset -c exit
    Output log:
    Open On-Chip Debugger 0.10.0+dev-01321-ge8cfdd4a-dirty (2020-07-10-11:52)
    nRF52 device has a CTRL-AP dedicated to recover the device from AP lock.
    A high level adapter (like a ST-Link) you are currently using cannot access
    the CTRL-AP so 'nrf52_recover' command will not work.
    Do not enable UICR APPROTECT.
    Info : clock speed 1000 kHz
    Info : STLINK V2J29S7 (API v2) VID:PID 0483:3748
    Info : Target voltage: 3.176563
    Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
    Info : starting gdb server for nrf52.cpu on 3333
    Info : Listening on port 3333 for gdb connections
    target halted due to debug-request, current mode: Thread
    xPSR: 0x01000000 pc: 0x00000880 msp: 0x20000400
    Info : nRF52840-xxAA(build code: C0) 1024kB Flash, 256kB RAM
    Warn : Flash protection of this nRF device is not supported
    wrote 1656 bytes from file /home/shubin/electronic/firmware/nrf/nrf5_SDK_for_Mesh_v4.2.0_src/bin/blinky/blinky_nrf52840_xxAA_s140_6.0.0.hex in 0.097093s (16.656 KiB/s)
    wrote 1656 bytes from file /home/shubin/electronic/firmware/nrf/nrf5_SDK_for_Mesh_v4.2.0_src/bin/blinky/blinky_nrf52840_xxAA_s140_6.0.0.hex in 0.091625s (17.650 KiB/s)
    Looking for device at nRF Blinky Android software. Nothing found
    Led not blinked.
    One time, i don't remember, what combination was used, the diode began to blink with a frequency of 2 Hz, but device scanner nothing found.
