USB Error connecting SPI Interface with nRF24L01 Module with nRF24L01+EC
I decided to play around with an nRF24L01 chip and I'm trying to get it to work on my Windows 10 computer.
My current issue is the following: I've downloaded and installed the nRF24l01+EC file. When I run the program, it gives me the following error:
"There was an error accessing the USB. Please exit the program reconnect the device and try again."
If I exit the program, disconnect and reconnect the device, it'll still give me the error. However, if I do not exit the program, but disconnect and reconnect the device, I get a different error:
"An unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will be shut down immediately.
USB Operation failed with status: Write Error."
If I hit continue, the software will continue to run, however the second error will continue to pop up. If I quit, it will revert back to the first error.
I've switched USB ports on my computer (I've used a USB 2.0, 3.0, 3.1, and a Type-C with none of them working).
Any help is greatly appreciated. Thank you.
