how to set static passkey ?
SDK14.0+NRF52832(PCA10040 demo board):
I want to add static passkey to avoid MITM attack, I write code as following, but when I use the mobile  app ‘nRF Connect’  to connect the PCA10040  board, mobile have not any
message box  notice me to input the passkey. I don't know what's wrong with me? Is there a complete example project for me to ref, thanks!
#define SEC_PARAM_BOND  0
#define SEC_PARAM_MITM	1
#define SEC_PARAM_IO_CAPABILITIES    BLE_GAP_IO_CAPS_DISPLAY_ONLY
#define SEC_PARAM_OOB	0
#define SEC_PARAM_MIN_KEY_SIZE  7
#define SEC_PARAM_MAX_KEY_SIZE  16
ble_gap_sec_params_t m_sec_params;
static void sec_params_init(void)
	m_sec_params.bond = SEC_PARAM_BOND;
	m_sec_params.mitm = SEC_PARAM_MITM;
	m_sec_params.io_caps = SEC_PARAM_IO_CAPABILITIES;
	m_sec_params.oob = SEC_PARAM_OOB;
	m_sec_params.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
	m_sec_params.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
	sec_params_init();
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
	//@zk20200710
	uint8_t passkey[]="123456";
	m_static_pin_option.gap_opt.passkey.p_passkey = passkey;
    err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
void resp_pair_request()
    ble_gap_sec_params_t sec_params;
    uint32_t                    err_code;
    memset(&sec_params,0,sizeof(ble_gap_sec_params_t));
    sec_params.bond = 0;
    sec_params.io_caps = BLE_GAP_IO_CAPS_DISPLAY_ONLY;
    sec_params.max_key_size = 16;
    sec_params.min_key_size = 7;
    sec_params.oob = 0;
    sec_params.mitm = 1;
	err_code=sd_ble_gap_sec_params_reply(m_conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,NULL);
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code;
        case BLE_GAP_EVT_CONNECTED:
			ble_gap_sec_params_t params;
			sd_ble_gap_authenticate(m_conn_handle, &params);
				   resp_pair_request();
		case BLE_GAP_EVT_PASSKEY_DISPLAY:
		case BLE_GAP_EVT_AUTH_STATUS:
			if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
				printf("Success!");
				sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            // No implementation needed.
static uint32_t rx_char_add(ble_nus_t * p_nus, const ble_nus_init_t * p_nus_init)
	ble_gatts_char_md_t char_md;
    ble_gatts_attr_t    attr_char_value;
    ble_uuid_t          ble_uuid;
    ble_gatts_attr_md_t attr_md;
    memset(&char_md, 0, sizeof(char_md));
    char_md.char_props.write         = 1;
    char_md.char_props.write_wo_resp = 1;
    char_md.p_char_user_desc         = NULL;
    char_md.p_char_pf                = NULL;
    char_md.p_user_desc_md           = NULL;
    char_md.p_cccd_md                = NULL;
    char_md.p_sccd_md                = NULL;
    ble_uuid.type = p_nus->uuid_type;
    ble_uuid.uuid = BLE_UUID_NUS_RX_CHARACTERISTIC;
    memset(&attr_md, 0, sizeof(attr_md));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
    //BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
	BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&attr_md.write_perm);
    attr_md.vloc    = BLE_GATTS_VLOC_STACK;
    attr_md.rd_auth = 0;
    attr_md.wr_auth = 0;
    attr_md.vlen    = 1;
    memset(&attr_char_value, 0, sizeof(attr_char_value));
    attr_char_value.p_uuid    = &ble_uuid;
    attr_char_value.p_attr_md = &attr_md;
    attr_char_value.init_len  = 1;
    attr_char_value.init_offs = 0;
    attr_char_value.max_len   = BLE_NUS_MAX_RX_CHAR_LEN;
    return sd_ble_gatts_characteristic_add(p_nus->service_handle,
                                           &char_md,
                                           &attr_char_value,
                                           &p_nus->rx_handles);
