I have an issue that is urgent for me, as we wish to add DFU capabilities via pre and post production hardware.
I am using Android 10 on Samsung Galaxy A10 to test.
I clone the repository from nRF Toolbox, run the app on the phone - and the DFU process succeeds.
I then copy paste that code as much as I can for my specific use case, and the device goes into bootloader mode but the connection is lost before the DFU process starts.
I have put more detail in the Github issue comment here:
https://github.com/NordicSemiconductor/Android-DFU-Library/issues/250#issuecomment-656074123
To my knowledge the configuration code is the same as the nRFTool Box - but I must be missing something?
The error log I get states the generic issue:
E/DfuBaseService: Connection state change error: 133 newState: 0 E/DfuBaseService: An error occurred while connecting to the device:133
and we are using the latest SDKs with the DFU implementation that is out of the box implementation provided by Nordic firmware sample (I am paraphrasing hardware team here). This isn't an issue coming from Legacy DFU, besides we know it works with nRF Toolbox app running on the same device so it shouldn't be a hardware issue.
I have created a stripped down sample project and shared it on github here:
https://github.com/oliver-ep/android-nordic-dfu
it is basically a Kotlin version of the nRF Toolbox code, copy pasted as much as I can, with a simple UI and one use case. The device address is hard-coded, and the app will immediately open a file picker to select the firmware file - and we are only using the .zip file. All the hard-coded values used for configuring the DFU initialiser was obtained from debugging with a functional nRF Toolbox clone app.
What am I missing?
Is it possible that I need to establish a BLE connection and discover the services exposed before referencing the DFU library?
Oliver
