I am trying to use a uartpipe as described here
for the 9160 image:
prj.conf:
CONFIG_UART_PIPE=y
CONFIG_UART_PIPE_ON_DEV_NAME="UART_2"
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
### configure the uart between 9160 and 52840
CONFIG_UART_2_NRF_UARTE=y
CONFIG_UART_2_NRF_FLOW_CONTROL=y
child_secure_partition_manager.conf:
CONFIG_SPM_NRF_UARTE2_NS=y
nrf9160_pca10090ns.overlay:
chosen {
zephyr,bt-uart=&uart2;
&uart2 {
current-speed = <1000000>;
status = "okay";
tx-pin = <18>;
rx-pin = <17>;
rts-pin = <21>;
cts-pin = <19
And for building the image for the nrf52840:
prj.conf:
CONFIG_UART_PIPE=y
CONFIG_UART_PIPE_ON_DEV_NAME="UART_1"
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_NRF_FLOW_CONTROL=y
nrf52840_pca10090.overlay:
chosen {
zephyr,uart-pipe=&uart1;
&uart1 {
status = "okay";
tx-pin = <17>;
rx-pin = <20>;
rts-pin = <15>;
cts-pin = <22>;
I only see send from 52840 side and 9160 always reboots and i noticed the error
Non-secure callable region 0 placed in flash region 0 with size 32.
SRAM region Domain Permissions
00 07 0x00000 0x10000 Secure rwxl
08 31 0x10000 0x40000 Non-Secure rwxl
Peripheral Domain Status
00 NRF_P0 Non-Secure OK
01 NRF_CLOCK Non-Secure OK
02 NRF_RTC0 Non-Secure OK
03 NRF_RTC1 Non-Secure OK
04 NRF_NVMC Non-Secure OK
05 NRF_UARTE1 Non-Secure OK
06 NRF_UARTE2 Secure SKIP
07 NRF_TWIM2 Non-Secure OK
08 NRF_SPIM3 Non-Secure OK
09 NRF_TIMER0 Non-Secure OK
10 NRF_TIMER1 Non-Secure OK
11 NRF_TIMER2 Non-Secure OK
12 NRF_SAADC Non-Secure OK
13 NRF_PWM0 Non-Secure OK
14 NRF_PWM1 Non-Secure OK
# # Modules # # # Nordic nRF Connect # # CONFIG_NCS_SAMPLES_DEFAULTS is not set # # Bootloader # # CONFIG_BUILD_S1_VARIANT is not set # CONFIG_SECURE_BOOT is not set CONFIG_PM_PARTITION_SIZE_PROVISION=0x280 CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000 # CONFIG_SECURE_BOOT_CRYPTO is not set # # Secure Boot firmware validation # CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483 CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1 CONFIG_SB_VALIDATION_INFO_VERSION=2 CONFIG_SB_VALIDATION_METADATA_OFFSET=0 CONFIG_SB_VALIDATE_FW_SIGNATURE=y # end of Secure Boot firmware validation # end of Bootloader # # Bluetooth Low Energy # CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024 # end of Bluetooth Low Energy # # DFU # # CONFIG_DFU_TARGET is not set # end of DFU # CONFIG_ESB is not set # # Networking # # # Application protocols # # CONFIG_NRF_CLOUD is not set # CONFIG_DOWNLOAD_CLIENT is not set # CONFIG_AWS_IOT is not set # CONFIG_AWS_JOBS is not set # CONFIG_CLOUD_API is not set # CONFIG_CLOUD_PERSISTENT_SESSIONS is not set # # Self-Registration (Zi ZHu Ce) # # CONFIG_ZZHC is not set # end of Self-Registration (Zi ZHu Ce) # CONFIG_ICAL_PARSER is not set # CONFIG_FTP_CLIENT is not set # end of Application protocols # end of Networking # # NFC # # CONFIG_NFC_NDEF is not set # CONFIG_NFC_NDEF_PARSER is not set # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set # CONFIG_NFC_T2T_PARSER is not set # CONFIG_NFC_T4T_ISODEP is not set # CONFIG_NFC_T4T_APDU is not set # CONFIG_NFC_T4T_CC_FILE is not set # CONFIG_NFC_T4T_HL_PROCEDURE is not set # CONFIG_NFC_PLATFORM is not set # CONFIG_NFC_TNEP_TAG is not set # CONFIG_NFC_TNEP_POLLER is not set # end of NFC # CONFIG_PROFILER is not set # # SPM # CONFIG_SPM=y # CONFIG_SPM_BUILD_STRATEGY_USE_HEX_FILE is not set # CONFIG_SPM_BUILD_STRATEGY_SKIP_BUILD is not set CONFIG_SPM_BUILD_STRATEGY_FROM_SOURCE=y # CONFIG_IS_SPM is not set CONFIG_ARM_ENTRY_VENEERS_LIB_NAME="spm/libspmsecureentries.a" # end of SPM CONFIG_FW_INFO=y CONFIG_FW_INFO_OFFSET=0x200 CONFIG_FW_INFO_FIRMWARE_VERSION=1 CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea CONFIG_FW_INFO_HARDWARE_ID=91 CONFIG_FW_INFO_VERSION=2 CONFIG_FW_INFO_CRYPTO_ID=0 CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0 CONFIG_FW_INFO_MAGIC_LEN=12 CONFIG_FW_INFO_VALID_VAL=0x9102FFFF CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set # CONFIG_PPI_TRACE is not set # CONFIG_CPU_LOAD is not set # # Nordic MPSL # CONFIG_MPSL_THREAD_COOP_PRIO=8 CONFIG_MPSL_SIGNAL_STACK_SIZE=1024 # end of Nordic MPSL # # Partition Manager # # # Zephyr subsystem configurations # # end of Zephyr subsystem configurations # CONFIG_PM_EXTERNAL_FLASH is not set # end of Partition Manager # # Libraries # # # Binary libraries # # end of Binary libraries # # BSD Library for nrf91 # # CONFIG_BSD_LIBRARY is not set # end of BSD Library for nrf91 # CONFIG_ADP536X is not set # # AT Command driver # # end of AT Command driver # CONFIG_LTE_LINK_CONTROL is not set # CONFIG_FPROTECT is not set CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000 CONFIG_FPROTECT_BLOCK_SIZE=0x8000 # # AT Host Library for nrf91 # # CONFIG_AT_HOST_LIBRARY is not set # end of AT Host Library for nrf91 # CONFIG_DK_LIBRARY is not set # CONFIG_AT_CMD_PARSER is not set # CONFIG_MODEM_INFO is not set CONFIG_RESET_ON_FATAL_ERROR=y # CONFIG_SMS is not set # CONFIG_SUPL_CLIENT_LIB is not set # end of Libraries # # Device Drivers # # CONFIG_ETH_RTT is not set # CONFIG_SENSOR is not set # # GPS Drivers # # CONFIG_GPS_SIM is not set # end of GPS Drivers # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set # end of Device Drivers # # External libraries # # end of External libraries # CONFIG_UNITY is not set # end of Nordic nRF Connect # # MCUboot # CONFIG_BOOT_SIGNATURE_KEY_FILE="root-rsa-2048.pem" CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4 # end of MCUboot # # Nordic nrfxlib # # CONFIG_NFC_T2T_NRFXLIB is not set # CONFIG_NFC_T4T_NRFXLIB is not set # # Crypto libraries for nRF5x SOCs. # # CONFIG_NRF_OBERON is not set # CONFIG_NRF_CC310_BL is not set # CONFIG_NRF_CC310_PLATFORM is not set # end of Crypto libraries for nRF5x SOCs. # # Nordic Security # # CONFIG_NORDIC_SECURITY_BACKEND is not set # end of Nordic Security # end of Nordic nrfxlib # # Optional modules. Make sure they're installed, via the project manifest. # # CONFIG_CANOPENNODE is not set # CONFIG_CIVETWEB is not set CONFIG_HAS_CMSIS_CORE=y CONFIG_HAS_CMSIS_CORE_M=y # CONFIG_LIBMETAL is not set # CONFIG_HAS_SEMTECH_LORAMAC is not set # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set # CONFIG_MBEDTLS is not set # CONFIG_HAS_MEC_HAL is not set CONFIG_HAS_NRFX=y # # nrfx drivers # # CONFIG_NRFX_CLOCK is not set # CONFIG_NRFX_DPPI is not set # CONFIG_NRFX_EGU is not set # CONFIG_NRFX_EGU0 is not set # CONFIG_NRFX_EGU1 is not set # CONFIG_NRFX_EGU2 is not set # CONFIG_NRFX_EGU3 is not set # CONFIG_NRFX_EGU4 is not set # CONFIG_NRFX_EGU5 is not set # CONFIG_NRFX_GPIOTE is not set # CONFIG_NRFX_I2S is not set # CONFIG_NRFX_IPC is not set CONFIG_NRFX_NVMC=y # CONFIG_NRFX_PDM is not set # CONFIG_NRFX_POWER is not set # CONFIG_NRFX_PWM is not set # CONFIG_NRFX_PWM0 is not set # CONFIG_NRFX_PWM1 is not set # CONFIG_NRFX_PWM2 is not set # CONFIG_NRFX_PWM3 is not set # CONFIG_NRFX_RTC is not set # CONFIG_NRFX_RTC0 is not set # CONFIG_NRFX_RTC1 is not set # CONFIG_NRFX_SAADC is not set # CONFIG_NRFX_SPIM is not set # CONFIG_NRFX_SPIM0 is not set # CONFIG_NRFX_SPIM1 is not set # CONFIG_NRFX_SPIM2 is not set # CONFIG_NRFX_SPIM3 is not set # CONFIG_NRFX_SPIS is not set # CONFIG_NRFX_SPIS0 is not set # CONFIG_NRFX_SPIS1 is not set # CONFIG_NRFX_SPIS2 is not set # CONFIG_NRFX_SPIS3 is not set # CONFIG_NRFX_SYSTICK is not set # CONFIG_NRFX_TIMER is not set # CONFIG_NRFX_TIMER0 is not set # CONFIG_NRFX_TIMER1 is not set # CONFIG_NRFX_TIMER2 is not set # CONFIG_NRFX_TWIM is not set # CONFIG_NRFX_TWIM0 is not set # CONFIG_NRFX_TWIM1 is not set # CONFIG_NRFX_TWIM2 is not set # CONFIG_NRFX_TWIM3 is not set # CONFIG_NRFX_TWIS is not set # CONFIG_NRFX_TWIS0 is not set # CONFIG_NRFX_TWIS1 is not set # CONFIG_NRFX_TWIS2 is not set # CONFIG_NRFX_TWIS3 is not set # CONFIG_NRFX_UARTE is not set # CONFIG_NRFX_UARTE0 is not set # CONFIG_NRFX_UARTE1 is not set # CONFIG_NRFX_UARTE2 is not set # CONFIG_NRFX_UARTE3 is not set # CONFIG_NRFX_WDT is not set # CONFIG_NRFX_WDT0 is not set # CONFIG_NRFX_PRS is not set # CONFIG_NRFX_PRS_BOX_0 is not set # CONFIG_NRFX_PRS_BOX_1 is not set # CONFIG_NRFX_PRS_BOX_2 is not set # CONFIG_NRFX_PRS_BOX_3 is not set # CONFIG_NRFX_PRS_BOX_4 is not set # end of nrfx drivers # CONFIG_OPENAMP is not set # CONFIG_MIPI_SYST_LIB is not set # CONFIG_BUILD_WITH_TFM is not set # CONFIG_TINYCBOR is not set # CONFIG_TINYCRYPT is not set # end of Modules # CONFIG_SPI is not set # CONFIG_TEST_RANDOM_GENERATOR is not set # CONFIG_I2C is not set # CONFIG_MODEM is not set CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_2_NRF_FLOW_CONTROL=y CONFIG_BOARD="nrf9160dk_nrf9160" CONFIG_FLASH_LOAD_SIZE=0x40000 CONFIG_FLASH_LOAD_OFFSET=0x40000 CONFIG_SOC="nRF9160_SICA" CONFIG_SOC_SERIES="nrf91" CONFIG_NUM_IRQS=65 CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768 # CONFIG_WATCHDOG is not set # CONFIG_UART_NS16550 is not set CONFIG_GPIO=y CONFIG_SYS_POWER_MANAGEMENT=y # CONFIG_SYS_POWER_DEEP_SLEEP_STATES is not set CONFIG_HAS_SYS_POWER_STATE_DEEP_SLEEP_1=y # CONFIG_DEVICE_POWER_MANAGEMENT is not set CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y # CONFIG_CORTEX_M_SYSTICK is not set CONFIG_CLOCK_CONTROL=y CONFIG_NRF_RTC_TIMER=y CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768 CONFIG_BUILD_OUTPUT_HEX=y # CONFIG_FPU is not set CONFIG_TEXT_SECTION_OFFSET=0 CONFIG_FLASH_SIZE=1024 CONFIG_FLASH_BASE_ADDRESS=0x0 CONFIG_SRAM_SIZE=128 CONFIG_SRAM_BASE_ADDRESS=0x20020000 # CONFIG_GPIO_MCUX is not set # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set CONFIG_SOC_GECKO_EMU=y CONFIG_HEAP_MEM_POOL_SIZE=0 # CONFIG_BOARD_NRF9160DK_NRF9160 is not set CONFIG_BOARD_NRF9160DK_NRF9160NS=y # # Board Options # # CONFIG_BOARD_NRF52840_GPIO_RESET is not set # end of Board Options # CONFIG_SOC_SERIES_BEETLE is not set # CONFIG_SOC_SERIES_MPS2 is not set # CONFIG_SOC_SERIES_MUSCA is not set # CONFIG_SOC_SERIES_MUSCA_B1 is not set # CONFIG_SOC_SERIES_SAMD20 is not set # CONFIG_SOC_SERIES_SAMD21 is not set # CONFIG_SOC_SERIES_SAMD51 is not set # CONFIG_SOC_SERIES_SAME51 is not set # CONFIG_SOC_SERIES_SAME53 is not set # CONFIG_SOC_SERIES_SAME54 is not set # CONFIG_SOC_SERIES_SAMR21 is not set # CONFIG_SOC_SERIES_SAM3X is not set # CONFIG_SOC_SERIES_SAM4E is not set # CONFIG_SOC_SERIES_SAM4S is not set # CONFIG_SOC_SERIES_SAME70 is not set # CONFIG_SOC_SERIES_SAMV71 is not set # CONFIG_SOC_SERIES_VALKYRIE is not set # CONFIG_SOC_SERIES_VIPER is not set # CONFIG_SOC_SERIES_PSOC62 is not set # CONFIG_SOC_SERIES_XMC_4XXX is not set # CONFIG_SOC_SERIES_MEC1501X is not set # CONFIG_SOC_SERIES_MEC1701X is not set # CONFIG_SOC_SERIES_NRF51X is not set # CONFIG_SOC_SERIES_NRF52X is not set # CONFIG_SOC_SERIES_NRF53X is not set CONFIG_SOC_SERIES_NRF91X=y # CONFIG_SOC_SERIES_IMX_6X_M4 is not set # CONFIG_SOC_SERIES_IMX7_M4 is not set # CONFIG_SOC_SERIES_IMX_RT is not set # CONFIG_SOC_SERIES_KINETIS_K2X is not set # CONFIG_SOC_SERIES_KINETIS_K6X is not set # CONFIG_SOC_SERIES_KINETIS_K8X is not set # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set # CONFIG_SOC_SERIES_KINETIS_KL2X is not set # CONFIG_SOC_SERIES_KINETIS_KV5X is not set # CONFIG_SOC_SERIES_KINETIS_KWX is not set # CONFIG_SOC_SERIES_LPC54XXX is not set # CONFIG_SOC_SERIES_LPC55XXX is not set # CONFIG_SOC_QEMU_CORTEX_A53 is not set # CONFIG_SOC_SERIES_EFM32GG11B is not set # CONFIG_SOC_SERIES_EFM32HG is not set # CONFIG_SOC_SERIES_EFM32JG12B is not set # CONFIG_SOC_SERIES_EFM32PG12B is not set # CONFIG_SOC_SERIES_EFM32WG is not set # CONFIG_SOC_SERIES_EFR32BG13P is not set # CONFIG_SOC_SERIES_EFR32FG1P is not set # CONFIG_SOC_SERIES_EFR32MG12P is not set # CONFIG_SOC_SERIES_STM32F0X is not set # CONFIG_SOC_SERIES_STM32F1X is not set # CONFIG_SOC_SERIES_STM32F2X is not set # CONFIG_SOC_SERIES_STM32F3X is not set # CONFIG_SOC_SERIES_STM32F4X is not set # CONFIG_SOC_SERIES_STM32F7X is not set # CONFIG_SOC_SERIES_STM32G0X is not set # CONFIG_SOC_SERIES_STM32G4X is not set # CONFIG_SOC_SERIES_STM32H7X is not set # CONFIG_SOC_SERIES_STM32L0X is not set # CONFIG_SOC_SERIES_STM32L1X is not set # CONFIG_SOC_SERIES_STM32L4X is not set # CONFIG_SOC_SERIES_STM32L5X is not set # CONFIG_SOC_SERIES_STM32MP1X is not set # CONFIG_SOC_SERIES_STM32WBX is not set # CONFIG_SOC_TI_LM3S6965 is not set # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set # CONFIG_SOC_SERIES_CC32XX is not set # CONFIG_SOC_SERIES_MSP432P4XX is not set # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set # # Hardware Configuration # CONFIG_CPU_HAS_ARM_MPU=y CONFIG_CPU_HAS_NRF_IDAU=y CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000 CONFIG_SOC_FAMILY="nordic_nrf" CONFIG_SOC_FAMILY_NRF=y CONFIG_HAS_HW_NRF_CC310=y CONFIG_HAS_HW_NRF_CLOCK=y CONFIG_HAS_HW_NRF_DPPIC=y CONFIG_HAS_HW_NRF_EGU0=y CONFIG_HAS_HW_NRF_EGU1=y CONFIG_HAS_HW_NRF_EGU2=y CONFIG_HAS_HW_NRF_EGU3=y CONFIG_HAS_HW_NRF_EGU4=y CONFIG_HAS_HW_NRF_EGU5=y CONFIG_HAS_HW_NRF_GPIO0=y CONFIG_HAS_HW_NRF_GPIOTE=y CONFIG_HAS_HW_NRF_I2S=y CONFIG_HAS_HW_NRF_IPC=y CONFIG_HAS_HW_NRF_NVMC_PE=y CONFIG_HAS_HW_NRF_PDM=y CONFIG_HAS_HW_NRF_POWER=y CONFIG_HAS_HW_NRF_PWM0=y CONFIG_HAS_HW_NRF_PWM1=y CONFIG_HAS_HW_NRF_PWM2=y CONFIG_HAS_HW_NRF_PWM3=y CONFIG_HAS_HW_NRF_RTC0=y CONFIG_HAS_HW_NRF_RTC1=y CONFIG_HAS_HW_NRF_SAADC=y CONFIG_HAS_HW_NRF_SPIM0=y CONFIG_HAS_HW_NRF_SPIM1=y CONFIG_HAS_HW_NRF_SPIM2=y CONFIG_HAS_HW_NRF_SPIM3=y CONFIG_HAS_HW_NRF_SPIS0=y CONFIG_HAS_HW_NRF_SPIS1=y CONFIG_HAS_HW_NRF_SPIS2=y CONFIG_HAS_HW_NRF_SPIS3=y CONFIG_HAS_HW_NRF_SPU=y CONFIG_HAS_HW_NRF_TIMER0=y CONFIG_HAS_HW_NRF_TIMER1=y CONFIG_HAS_HW_NRF_TIMER2=y CONFIG_HAS_HW_NRF_TWIM0=y CONFIG_HAS_HW_NRF_TWIM1=y CONFIG_HAS_HW_NRF_TWIM2=y CONFIG_HAS_HW_NRF_TWIM3=y CONFIG_HAS_HW_NRF_TWIS0=y CONFIG_HAS_HW_NRF_TWIS1=y CONFIG_HAS_HW_NRF_TWIS2=y CONFIG_HAS_HW_NRF_TWIS3=y CONFIG_HAS_HW_NRF_UARTE0=y CONFIG_HAS_HW_NRF_UARTE1=y CONFIG_HAS_HW_NRF_UARTE2=y CONFIG_HAS_HW_NRF_UARTE3=y CONFIG_HAS_HW_NRF_WDT=y CONFIG_NRF_ENABLE_ICACHE=y CONFIG_SOC_NRF9160=y CONFIG_SOC_NRF9160_SICA=y # end of Hardware Configuration CONFIG_SOC_COMPATIBLE_NRF=y # # ARM Options # CONFIG_ARCH="arm" CONFIG_CPU_CORTEX=y CONFIG_CPU_CORTEX_M=y CONFIG_ISA_THUMB2=y CONFIG_ASSEMBLER_ISA_THUMB2=y CONFIG_COMPILER_ISA_THUMB2=y CONFIG_STACK_ALIGN_DOUBLE_WORD=y # CONFIG_RUNTIME_NMI is not set CONFIG_PLATFORM_SPECIFIC_INIT=y CONFIG_FAULT_DUMP=2 # CONFIG_BUILTIN_STACK_GUARD is not set CONFIG_ARM_NONSECURE_FIRMWARE=y CONFIG_CPU_CORTEX_M33=y CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y CONFIG_CPU_CORTEX_M_HAS_DWT=y CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y CONFIG_CPU_CORTEX_M_HAS_VTOR=y CONFIG_CPU_CORTEX_M_HAS_SPLIM=y CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y CONFIG_CPU_CORTEX_M_HAS_CMSE=y CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_SE=y CONFIG_ARMV7_M_ARMV8_M_FP=y CONFIG_ARMV8_M_DSP=y CONFIG_XIP=y # # ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options # CONFIG_GEN_ISR_TABLES=y # CONFIG_ZERO_LATENCY_IRQS is not set # end of ARM Cortex-M0/M0+/M3/M4/M7/M23/M33 options CONFIG_ARM_MPU=y CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32 # CONFIG_MPU_STACK_GUARD is not set # CONFIG_MPU_ALLOW_FLASH_WRITE is not set # CONFIG_CUSTOM_SECTION_ALIGN is not set CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32 CONFIG_ARM_TRUSTZONE_M=y # # ARM TrustZone-M Options # # # Non-secure firmware # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS=y # end of ARM TrustZone-M Options CONFIG_GEN_IRQ_VECTOR_TABLE=y CONFIG_MAIN_STACK_SIZE=1024 CONFIG_IDLE_STACK_SIZE=320 CONFIG_ISR_STACK_SIZE=2048 CONFIG_TEST_EXTRA_STACKSIZE=0 # end of ARM Options CONFIG_ARM=y CONFIG_ARCH_IS_SET=y # # General Architecture Options # # CONFIG_TRUSTED_EXECUTION_SECURE is not set CONFIG_TRUSTED_EXECUTION_NONSECURE=y # CONFIG_HW_STACK_PROTECTION is not set # CONFIG_USERSPACE is not set CONFIG_PRIVILEGED_STACK_SIZE=1024 CONFIG_KOBJECT_TEXT_AREA=256 CONFIG_GEN_PRIV_STACKS=y # CONFIG_STACK_GROWS_UP is not set # # Interrupt Configuration # # CONFIG_DYNAMIC_INTERRUPTS is not set CONFIG_GEN_SW_ISR_TABLE=y CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0 CONFIG_GEN_IRQ_START_VECTOR=0 # end of Interrupt Configuration # end of General Architecture Options CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y CONFIG_ARCH_HAS_STACK_PROTECTION=y CONFIG_ARCH_HAS_USERSPACE=y CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y CONFIG_ARCH_HAS_THREAD_ABORT=y CONFIG_CPU_HAS_TEE=y CONFIG_CPU_HAS_FPU=y CONFIG_CPU_HAS_MPU=y CONFIG_MEMORY_PROTECTION=y CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y CONFIG_MPU_GAP_FILLING=y # # Floating Point Options # # end of Floating Point Options # # General Kernel Options # CONFIG_MULTITHREADING=y CONFIG_NUM_COOP_PRIORITIES=16 CONFIG_NUM_PREEMPT_PRIORITIES=15 CONFIG_MAIN_THREAD_PRIORITY=0 CONFIG_COOP_ENABLED=y CONFIG_PREEMPT_ENABLED=y CONFIG_PRIORITY_CEILING=0 CONFIG_NUM_METAIRQ_PRIORITIES=0 # CONFIG_SCHED_DEADLINE is not set # CONFIG_SCHED_CPU_MASK is not set CONFIG_THREAD_STACK_INFO=y # CONFIG_THREAD_CUSTOM_DATA is not set CONFIG_ERRNO=y CONFIG_SCHED_DUMB=y # CONFIG_SCHED_SCALABLE is not set # CONFIG_SCHED_MULTIQ is not set # CONFIG_WAITQ_SCALABLE is not set CONFIG_WAITQ_DUMB=y # # Kernel Debugging and Metrics # # CONFIG_INIT_STACKS is not set # CONFIG_KERNEL_DEBUG is not set CONFIG_BOOT_BANNER=y CONFIG_BOOT_DELAY=0 # CONFIG_EXECUTION_BENCHMARKING is not set # CONFIG_THREAD_MONITOR is not set # CONFIG_THREAD_NAME is not set # end of Kernel Debugging and Metrics # # Work Queue Options # CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1 # end of Work Queue Options # # Atomic Operations # CONFIG_ATOMIC_OPERATIONS_BUILTIN=y # end of Atomic Operations # # Timer API Options # CONFIG_TIMESLICING=y CONFIG_TIMESLICE_SIZE=0 CONFIG_TIMESLICE_PRIORITY=0 # CONFIG_POLL is not set # end of Timer API Options # # Other Kernel Object Options # CONFIG_NUM_MBOX_ASYNC_MSGS=10 CONFIG_NUM_PIPE_ASYNC_MSGS=10 CONFIG_MEM_POOL_HEAP_BACKEND=y # end of Other Kernel Object Options CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y CONFIG_SWAP_NONATOMIC=y CONFIG_SYS_CLOCK_EXISTS=y # CONFIG_LEGACY_TIMEOUT_API is not set CONFIG_TIMEOUT_64BIT=y # # Initialization Priorities # CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30 CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40 CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50 CONFIG_APPLICATION_INIT_PRIORITY=90 # end of Initialization Priorities # # Security Options # # end of Security Options # # SMP Options # CONFIG_MP_NUM_CPUS=1 # end of SMP Options CONFIG_TICKLESS_IDLE=y CONFIG_TICKLESS_IDLE_THRESH=3 CONFIG_TICKLESS_KERNEL=y # CONFIG_SYS_PM_STATE_LOCK is not set # CONFIG_SYS_PM_DIRECT_FORCE_MODE is not set # CONFIG_SYS_PM_DEBUG is not set CONFIG_SYS_PM_POLICY_RESIDENCY=y # CONFIG_SYS_PM_POLICY_DUMMY is not set # CONFIG_SYS_PM_POLICY_APP is not set CONFIG_SYS_PM_POLICY_RESIDENCY_DEFAULT=y CONFIG_SYS_PM_MIN_RESIDENCY_DEEP_SLEEP_1=60000 # end of General Kernel Options CONFIG_HAS_DTS=y CONFIG_HAS_DTS_GPIO=y # # Device Drivers # # CONFIG_IEEE802154 is not set CONFIG_UART_CONSOLE_ON_DEV_NAME="UART_0" CONFIG_CONSOLE=y CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128 CONFIG_CONSOLE_HAS_DRIVER=y # CONFIG_CONSOLE_HANDLER is not set CONFIG_UART_CONSOLE=y CONFIG_UART_CONSOLE_INIT_PRIORITY=60 # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set # CONFIG_UART_CONSOLE_MCUMGR is not set # CONFIG_USB_UART_CONSOLE is not set # CONFIG_RAM_CONSOLE is not set # CONFIG_IPM_CONSOLE_SENDER is not set # CONFIG_IPM_CONSOLE_RECEIVER is not set CONFIG_UART_PIPE=y CONFIG_UART_PIPE_ON_DEV_NAME="UART_2" # CONFIG_UART_MCUMGR is not set # CONFIG_SEMIHOST_CONSOLE is not set # CONFIG_GSM_MUX is not set CONFIG_UART_MUX_RX_STACK_SIZE=512 CONFIG_UART_MUX_RX_PRIORITY=7 CONFIG_HAS_SEGGER_RTT=y # CONFIG_USE_SEGGER_RTT is not set # CONFIG_NET_LOOPBACK is not set CONFIG_SERIAL=y # # Capabilities # CONFIG_SERIAL_HAS_DRIVER=y CONFIG_SERIAL_SUPPORT_ASYNC=y CONFIG_SERIAL_SUPPORT_INTERRUPT=y CONFIG_UART_ASYNC_API=y # CONFIG_UART_ASYNC_API is not set # CONFIG_UART_LINE_CTRL is not set # CONFIG_UART_DRV_CMD is not set # # Serial Drivers # # CONFIG_UART_NSIM is not set CONFIG_UART_NRFX=y CONFIG_UART_0_NRF_UARTE=y CONFIG_UART_0_INTERRUPT_DRIVEN=y # CONFIG_UART_0_NRF_PARITY_BIT is not set # CONFIG_UART_0_NRF_FLOW_CONTROL is not set CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32 CONFIG_UART_2_NRF_UARTE=y CONFIG_UART_2_INTERRUPT_DRIVEN=y CONFIG_UART_2_NRF_FLOW_CONTROL=y # CONFIG_UART_1_NRF_PARITY_BIT is not set CONFIG_UART_2_NRF_TX_BUFFER_SIZE=64 #CONFIG_NRF_UARTE_PERIPHERAL=y #CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y # CONFIG_UART_ALTERA_JTAG is not set # CONFIG_UART_PL011 is not set #CONFIG_SPM_NRF_UARTE2_NS=y # # Interrupt Controllers # # CONFIG_SWERV_PIC is not set # CONFIG_MULTI_LEVEL_INTERRUPTS is not set # end of Interrupt Controllers # # Timer Drivers # # CONFIG_SYSTEM_CLOCK_DISABLE is not set # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0 CONFIG_TICKLESS_CAPABLE=y # end of Timer Drivers # CONFIG_ENTROPY_GENERATOR is not set # CONFIG_GPIO_SHELL is not set # CONFIG_GPIO_DW is not set CONFIG_GPIO_NRFX=y CONFIG_GPIO_NRF_INIT_PRIORITY=40 CONFIG_GPIO_NRF_P0=y # CONFIG_GPIO_INTEL_APL is not set # CONFIG_SHARED_IRQ is not set # CONFIG_I2S is not set # CONFIG_PWM is not set # CONFIG_PINMUX is not set # CONFIG_ADC is not set # CONFIG_DAC is not set CONFIG_CLOCK_CONTROL_NRF=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y # CONFIG_PTP_CLOCK is not set # CONFIG_IPM is not set # CONFIG_FLASH is not set # CONFIG_COUNTER is not set # CONFIG_DMA is not set # CONFIG_USB is not set # CONFIG_CRYPTO is not set # CONFIG_DISPLAY is not set # CONFIG_LED_STRIP is not set # CONFIG_WIFI is not set # CONFIG_LED is not set # CONFIG_CAN is not set # CONFIG_AUDIO is not set # CONFIG_NEURAL_NET_ACCEL is not set # CONFIG_HWINFO is not set # CONFIG_ESPI is not set # CONFIG_PS2 is not set # CONFIG_KSCAN is not set # CONFIG_VIDEO is not set # CONFIG_EEPROM is not set # CONFIG_PECI is not set # CONFIG_PECI_INTERRUPT_DRIVEN is not set # end of Device Drivers # # C Library # CONFIG_MINIMAL_LIBC=y # CONFIG_NEWLIB_LIBC is not set # CONFIG_EXTERNAL_LIBC is not set CONFIG_HAS_NEWLIB_LIBC_NANO=y CONFIG_MINIMAL_LIBC_MALLOC=y CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0 CONFIG_MINIMAL_LIBC_CALLOC=y CONFIG_MINIMAL_LIBC_REALLOCARRAY=y # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set CONFIG_STDOUT_CONSOLE=y # end of C Library # # Additional libraries # # CONFIG_FNMATCH is not set # CONFIG_LVGL is not set # # OS Support Library # # CONFIG_JSON_LIBRARY is not set # CONFIG_RING_BUFFER is not set # CONFIG_BASE64 is not set # CONFIG_SYS_HEAP_VALIDATE is not set CONFIG_SYS_HEAP_ALLOC_LOOPS=3 # end of OS Support Library CONFIG_POSIX_MAX_FDS=4 # CONFIG_POSIX_API is not set # CONFIG_PTHREAD_IPC is not set # CONFIG_POSIX_CLOCK is not set CONFIG_MAX_TIMER_COUNT=5 # CONFIG_POSIX_MQUEUE is not set # CONFIG_EVENTFD is not set # CONFIG_UPDATEHUB is not set # CONFIG_OPENAMP_RSC_TABLE is not set # end of Additional libraries # CONFIG_BT is not set # CONFIG_CONSOLE_SUBSYS is not set # CONFIG_CPLUSPLUS is not set # # System Monitoring Options # # CONFIG_BOOT_TIME_MEASUREMENT is not set # CONFIG_STATS is not set # end of System Monitoring Options # # Debugging Options # # CONFIG_DEBUG is not set # CONFIG_STACK_USAGE is not set # CONFIG_STACK_SENTINEL is not set CONFIG_PRINTK=y CONFIG_EARLY_CONSOLE=y # CONFIG_ASSERT is not set # CONFIG_FORCE_NO_ASSERT is not set CONFIG_ASSERT_VERBOSE=y # CONFIG_ASSERT_NO_FILE_INFO is not set # CONFIG_ASSERT_NO_COND_INFO is not set # CONFIG_ASSERT_NO_MSG_INFO is not set # CONFIG_OBJECT_TRACING is not set # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set # CONFIG_DEBUG_INFO is not set # CONFIG_OPENOCD_SUPPORT is not set # end of Debugging Options # CONFIG_THREAD_ANALYZER is not set # CONFIG_DISK_ACCESS is not set # # File Systems # # CONFIG_FILE_SYSTEM is not set # CONFIG_NVS is not set # end of File Systems # CONFIG_LOG is not set # # Management # # CONFIG_MCUMGR_SMP_BT is not set # CONFIG_MCUMGR_SMP_SHELL is not set # CONFIG_MCUMGR_SMP_UART is not set # CONFIG_MCUMGR is not set # CONFIG_MCUMGR_SMP_UDP is not set # end of Management # # Networking # # CONFIG_NET_BUF is not set # CONFIG_NETWORKING is not set # end of Networking # CONFIG_SHELL is not set # CONFIG_IMG_MANAGER is not set # # Random subsystem # # end of Random subsystem # # Storage # # CONFIG_STREAM_FLASH is not set # end of Storage # CONFIG_SETTINGS is not set # # Testing # # CONFIG_ZTEST is not set # CONFIG_ZTEST_MOCKING is not set # CONFIG_TEST is not set # CONFIG_TEST_SHELL is not set # CONFIG_TEST_USERSPACE is not set CONFIG_TEST_ARM_CORTEX_M=y # end of Testing # CONFIG_TRACING is not set # CONFIG_CHARACTER_FRAMEBUFFER is not set # CONFIG_JWT is not set # # Controller Area Network (CAN) bus subsystem # # CONFIG_ISOTP is not set # end of Controller Area Network (CAN) bus subsystem CONFIG_TOOLCHAIN_GNUARMEMB=y # # Build and Link Features # # # Linker Options # # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set CONFIG_LINKER_ORPHAN_SECTION_WARN=y # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set # CONFIG_CODE_DATA_RELOCATION is not set CONFIG_HAS_FLASH_LOAD_OFFSET=y # CONFIG_USE_DT_CODE_PARTITION is not set # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set # CONFIG_CUSTOM_RODATA_LD is not set # CONFIG_CUSTOM_RWDATA_LD is not set # CONFIG_CUSTOM_SECTIONS_LD is not set CONFIG_KERNEL_ENTRY="__start" CONFIG_LINKER_SORT_BY_ALIGNMENT=y # end of Linker Options # # Compiler Options # # CONFIG_NATIVE_APPLICATION is not set CONFIG_SIZE_OPTIMIZATIONS=y # CONFIG_SPEED_OPTIMIZATIONS is not set # CONFIG_DEBUG_OPTIMIZATIONS is not set # CONFIG_NO_OPTIMIZATIONS is not set CONFIG_COMPILER_OPT="" # end of Compiler Options # CONFIG_ASSERT_ON_ERRORS is not set # CONFIG_NO_RUNTIME_CHECKS is not set CONFIG_RUNTIME_ERROR_CHECKS=y # # Build Options # CONFIG_KERNEL_BIN_NAME="zephyr" CONFIG_OUTPUT_STAT=y CONFIG_OUTPUT_DISASSEMBLY=y # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y CONFIG_BUILD_OUTPUT_BIN=y # CONFIG_BUILD_OUTPUT_EXE is not set # CONFIG_BUILD_OUTPUT_S19 is not set # CONFIG_BUILD_NO_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_STRIPPED is not set # CONFIG_APPLICATION_DEFINED_SYSCALL is not set # CONFIG_MAKEFILE_EXPORTS is not set # CONFIG_LEGACY_DEVICETREE_MACROS is not set # end of Build Options # end of Build and Link Features # # Boot Options # # CONFIG_IS_BOOTLOADER is not set # CONFIG_BOOTLOADER_MCUBOOT is not set # CONFIG_REBOOT is not set # CONFIG_MISRA_SANE is not set # end of Boot Options # # Compatibility # CONFIG_COMPAT_INCLUDES=y # end of Compatibility
chosen {
&uart2 {
current-speed = <115200>;
status = "okay";
tx-pin = <18>;
rx-pin = <17>;
rts-pin = <21>;
cts-pin = <19>;
Both overlay and config files are attached
using V1.3.0 rc1 sdk and segger 4.52
