nRF Connect SDK 1.3.0 multi-image build stuck
I am switching from standard Zephyr and I am trying out nRF connect SDK v1.3.0. When I am building my app for mcuboot, it hangs after configuring the child image (mcuboot).  If I build mcuboot or the app by itself it works just fine.  It seems like something is hanging in the partition_manager script.  I see a python process spinning in Activity Monitor forever, when I kill it, then the build process fails out.  See my output here:
Any ideas on how to solve this?
  • Strange, it should work out-of-the-box.
    Could you try the following:
    • Install NCS v1.3.0 using the Toolchain Manager
    • Add CONFIG_BOOTLOADER_MCUBOOT=y to <..>\ncs\v1.3.0\zephyr\samples\hello_world\prj.conf
    Open the bash window from the Toolchain Manager, cd into /ncs/v1.3.0/zephyr/samples/hello_world and build the project:
    west build -b nrf52840dk_nrf52840
    If that works, you've successfully built and compiled a project with mcuboot as a child image
    Simon
  • That does work, but I am interested in solving the issue with my project.  I have attached my input files that were used for the output above.
     pm_hang.zip
  • Okay, I was too quick to answer. Thanks for the files, I will try to reproduce the problem.
    Could you provide the exact steps to reproduce it, where in NCS v1.3.0 should he files be placed, and what commands to run?
    Simon
  • I have found an easy way to reproduce the issue with the nrf52840dk.  A simple project is attached.  Build it against the nrf52840dk_nrf52840 board.  The issue happens when both
    CONFIG_FILE_SYSTEM_LITTLEFS=y and CONFIG_NVS=y are used at the same time.  If you comment out one of them then the build works just fine.
    console.zip
  • Hi.
    Simon is on vacation, so I have taken over this ticket.
    Using your sample project, I am able to reproduce the problem.
    After adding some debug-prints to the partition manager, it seems like it gets stuck in this loop, not being able to resolve the nvs_storage_partition.
    I have not yet been able to find the reason why it gets stuck in the loop, and our partition manager expert is on vacation.
    I will continue investigating so that we can find a proper fix.
    In the meantime, I have been able to create a static configuration file for the partition manager that places both the nvs_storage and the littlefs_storage partitions:
    app:
      address: 0xc200
      region: flash_primary
    external_flash:
      address: 0x0
      region: external_flash
    mcuboot:
      address: 0x0
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0xc000
      placement:
        align:
          start: 0x1000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0xc000
      orig_span: &id001
      - app
      - mcuboot_pad
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0xc200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x80000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x1000
      share_size:
      - mcuboot_primary
    nvs_storage:
      address: 0xf4000
      placement:
        before:
        - end
    littlefs_storage:
      address: 0xfa000
      placement:
        before:
        - end
    (you must change the file ending to .yml, and place it in your project folder)
    Note that if you want to re-size any of the partitions, you must calculate new start addresses and sizes for the other partitions.
    Didrik
