I'm using saadc library to measure the voltage on nrf52832 DK. also I'm using soft device s132 on the project. I have several questions and will list below,
I want to measure the voltage on pins AIN0 and AIN1 between 0 - 3.0. I'm currently using VDD4 reference and 12-bit ADC with 1/6 gain.
I have tried the scan mode to measure the voltages simultaneously, but I find that both pins voltage shows inaccurate readings like If I apply 3 volts on pin AIN0 and no voltage on the AIN1 then the digital readings on both pins are like
AIN0 = 2483, AIN1 = 1135
As I did not apply any voltage on AIN1 but it still shows the value. I have tried using a single sample reading for both and multiple sample readings then took the average for the samples of corresponding changes but in both cases, I get the same pattern of results.
1) I tried to measure only pin AIN0 reading and it's giving me 2500 on 3V but when I remove 3V it still gives me 150 - 200 values which turn out to be some 0.4 0.5V but I need the mv accuracy in analog reading and that I think I have not achieved. Can you guide me on how I can achieve the millivolts sensitivity in measurement?
2) I want to measure the voltage using the 10useconds interval for each sample for AIN0 pin. How can I do that?
3) I want to measure the voltage on AIN1 after every 5 min and on AIN0 continuously, what you suggest would be the best practice to measure these. like measure using scan mode which is not giving me good results or should I measure 1 continuously and when I want to measure others after every 5 minutes disable the AIN0 enable AIN1 and measure voltage then again disable AIN1, enable AIN0. So please suggest how to do the second method if adopt it?
I have tried all the available data and examples on this forum but didn't succeed in measuring both voltages and measuring accurately.
Thanks
