SDK16 BLE HID, how to set a value to HID report feature?
I have used nRF5 SDK ver.16 for BLE HID digtiger.
I want to set up some feature value to HID report . Such as Contact count maximum.
I have followed keyboard example, but this not mention.
Is there any example to guide how to do it?
This is feature report descriptor
0x85, FEATURE_REP_MAX_COUNT_ID,     //   REPORT_ID (Feature)
0x09, 0x55,                         //   USAGE(Contact Count Maximum)
0x75, 0x08,                         //   REPORT_SIZE (8)
0x95, 0x01,                         //   REPORT_COUNT (1)
0x25, 0x0A,                         //   LOGICAL_MAXIMUM (10)
0xB1, 0x02,                         //   FEATURE (Data,Var,Abs)
Thank you.
    There are two options to set the feature report, only choose one of them.
    ---------- OPTIONS 1 - modify ble_hids.c: ----------
    Open ble_hids.c and go to on_report_value_read_auth(), then change:
    auth_read_params.params.read.update = 0; // Set to 0.
    Then calling sd_ble_gatts_value_set() after ble_hids_init() should work, for instance:
    err_code= sd_ble_gatts_value_set(m_conn_handle,
    m_hids.feature_rep_array[FEATURE_REPORT_INDEX]->char_handles.value_handle, &gatts_value);
    ---------- OPTIONS 2 - use ble_hids_feat_rep_set(): ----------
    The HIDS module keeps track of attribute values for each connection object (handle) and uses this tracked state to respond to a GATT client read / write operations.
    If you want to set a non-zero value for feature reports, you need to use the following function:
    https://gist.github.com/kapi-no/ce902e1aed6aac57eae2c6a3eabf7b58
    You need to call ble_hids_feat_rep_set() for each new connection when you handle the connected event from Softdevice.
    I hope this will help you.
    Kenneth
