Add Timer to ble_app_uart
Hello.
I am using nrf52832 and Segeer Embedded Studio.
I want to add a timer function to the ble_app_uart example so that the sensor value is read every 50 ms.
So I added the contents of the timer example to the ble_app_uart example.
ble_app_uart example  : nRF5_SDK_15.3.0_59ac345\examples\ble_central\ble_app_uart_c\pca10040\s132\ses
timer example : nRF5_SDK_15.3.0_59ac345\examples\peripheral\timer\pca10040\blank\ses
There is no error when building.
And when I click the go button after debugging, there is no error.
However, if I click the break button to stop the program and then click the go button again, the program stops at NRF_BREAKPOINT_COND.
I don't know how to combine the timer in the ble_app_uart  example.
I have seen comments that using Timer 0 may be a problem. So now I am using Timer1.
I would be grateful if you could help me with my problem.
The main.c code is attached.
    uint32_t time_ms = 50; //Time(in miliseconds) between consecutive compare events.
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    buttons_leds_init();
    db_discovery_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    nus_c_init();
    scan_init();
    //GYR_Init();
    //Configure TIMER for generating simple light effect - leds on board will invert his state one after the other.
    err_code = nrf_drv_timer_init(&TIMER, &timer_cfg, timer_led_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER, time_ms);
    nrf_drv_timer_extended_compare(
         &TIMER, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    nrf_drv_timer_enable(&TIMER);
    // Start execution.
    printf("BLE UART central example started.\r\n");
    NRF_LOG_INFO("BLE UART central example started.");
    scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
