Nordic SDK QSPI driver call
Hi all,
             We had implemented Nordic QSPI using "nrf_drv_qspi_write" and "nrf_drv_qspi_read" operation , however I am seeing for page to write in flash of 4096 bytes with 512 bytes of QSPI write size limitation its taking 8.6 milli sec , when many streams (sensor data at stretch to be written into system) streams are getting hanged when flash logging is enabled .
So, wanted to check basic operations "nrf_drv_qspi_write" and "nrf_drv_qspi_read" if it blocks other sensor operations to process data ? Is it blocking call? If so how do we configure into dma mode?
Please help
  • What's the write speed of the flash?
    The read and write functions are blocking or non-blocking depending on whether you supplied an event handler to nrfx_qspi_init or not.
  • Hi ,
             Please find the driver code init.
    #define QSPI_NAND_FLASH_CONFIG                                        \
        .xip_offset  = 0,                         \
        .pins = {                                                           \
           .sck_pin     = QSPI_NAND_FLASH_SCK_PIN,                                \
           .csn_pin     = QSPI_NAND_FLASH_CSN_PIN,                                \
           .io0_pin     = QSPI_NAND_FLASH_IO0_PIN,                                \
           .io1_pin     = QSPI_NAND_FLASH_IO1_PIN,                                \
           .io2_pin     = QSPI_NAND_FLASH_IO2_PIN,                                \
           .io3_pin     = QSPI_NAND_FLASH_IO3_PIN,                                \
        .irq_priority   = (uint8_t)NRFX_QSPI_CONFIG_IRQ_PRIORITY,           \
        .prot_if = {                                                        \
            .readoc     = QSPI_IFCONFIG0_READOC_READ4O,       \
            .writeoc    = QSPI_IFCONFIG0_WRITEOC_PP4O,     \
            .addrmode   = (nrf_qspi_addrmode_t)NRFX_QSPI_CONFIG_ADDRMODE,   \
            .dpmconfig  = false,                                            \
        .phy_if = {                                                         \
            .sck_freq   = NRF_QSPI_FREQ_32MDIV1, \
            .sck_delay  = (uint8_t)NRFX_QSPI_CONFIG_SCK_DELAY,              \
            .spi_mode   = (nrf_qspi_spi_mode_t)NRFX_QSPI_CONFIG_MODE,       \
            .dpmen      = false                                             \
        select: 1=512byte,0=256byte.
    __STATIC_INLINE void nrf_qspi_ifconfig0_set_page_size(uint8_t select)
        if(select == 0)
            NRF_QSPI->IFCONFIG0 &= 0xffffefff;
            NRF_QSPI->IFCONFIG0 |= 0x00001000;
    uint32_t nand_flash_qspi_init(void)
        uint32_t err_code = NAND_SUCCESS;
        nrf_drv_qspi_config_t config = QSPI_NAND_FLASH_CONFIG;
        err_code = nrf_drv_qspi_init(&config, NULL, NULL);
        if(NRFX_SUCCESS != err_code)
            NRF_LOG_INFO("QSPI init error,err_code=%d",err_code);
            return err_code;
        nrf_qspi_ifconfig0_set_page_size(1);
        return NRFX_SUCCESS;
  • Also,
            We are using MT29F4G01ABBFDWB, MT29F4G01ABBFD12 flash series .
    Array performance
    – 83 MHz clock frequency (MAX)
    – Page read: 25μs (MAX) with on-die ECC disabled;
    135μs (MAX) with on-die ECC enabled
    – Page program: 200μs (TYP) with on-die ECC disabled;
    240μs (TYP) with on-die ECC enabled
    – Block erase: 2ms (TYP)
    What i have profiled time to write single page of 4096 bytes is 8.6 milli sec. and we have streams running at 100 to 500 Hz , 50 Hz , also we have combination.
    Another observation is with ECC being enabled , since i believe it takes more time to write streams hang faster. So i wanted to know if driver is blocking call, because we have system which needs to support multiple sensors  and interrupts.
     The second argument lacks a pointer to an event handler, so this driver runs in blocking mode.
    void qspi_init_call_back(nrfx_qspi_evt_t event, void *p_context)
    if (event == NRFX_QSPI_EVENT_DONE) {
    //add flag to distr
    adi_osal_SemPost(file_update_task_evt_sem);
    //create semaphore
    adi_osal_SemCreate(&file_update_task_evt_sem, 0);
    err_code = nrf_drv_qspi_init(&config, qspi_init_call_back, NULL);
    return err_code;
    In this case , call back will be called any operation read/write/erase?
