Nordic SDK QSPI driver call
Hi all,
             We had implemented Nordic QSPI using "nrf_drv_qspi_write" and "nrf_drv_qspi_read" operation , however I am seeing for page to write in flash of 4096 bytes with 512 bytes of QSPI write size limitation its taking 8.6 milli sec , when many streams (sensor data at stretch to be written into system) streams are getting hanged when flash logging is enabled .
So, wanted to check basic operations "nrf_drv_qspi_write" and "nrf_drv_qspi_read" if it blocks other sensor operations to process data ? Is it blocking call? If so how do we configure into dma mode?
Please help
           Version is
    nRF5_SDK_15.2.0
    I also see drivers are updated in nrfx_1.7.2 . Is it latest one ? Could I use nrfx_qspi.c from 1.7.2?
  • ARPITHA CHANDRASHEKAR said:
    nrf_drv_qspi_init is failing with below mentioned call back; inside
    init function
    m_cb.interrupt_driven = false; is set to false ; so it crashes when assigned call back.
     What do you mean it's failing? Where? What's the error code?
  • Sir, issue is not resolved yet. Are there any settings that has be changed to make it blocking call on sdk config
  • This is what we tried to modify nrfx_qspi_driver file . PLs check.
    #include <nrfx.h>
    #if NRFX_CHECK(NRFX_QSPI_ENABLED)
    #include <nrfx_qspi.h>
    volatile uint8_t ISR_flag  =0;
     * @brief Command byte used to read status register.
    #define QSPI_STD_CMD_RDSR 0x05
     * @brief Byte used to mask status register and retrieve the write-in-progess bit.
    #define QSPI_MEM_STATUSREG_WIP_Pos 0x01
     * @brief Default time used in timeout function.
    #define QSPI_DEF_WAIT_TIME_US 10
     * @brief Default number of tries in timeout function.
    #define QSPI_DEF_WAIT_ATTEMPTS 100
      * @brief Control block - driver instance local data.
    typedef struct
        nrfx_qspi_handler_t handler;          /**< Handler. */
        nrfx_drv_state_t    state;            /**< Driver state. */
        volatile bool       interrupt_driven; /**< Information if the current operation is performed and is interrupt-driven. */
        void *              p_context;        /**< Driver context used in interrupt. */
    } qspi_control_block_t;
    static qspi_control_block_t m_cb;
    static nrfx_err_t qspi_task_perform(nrf_qspi_task_t task)
        // Wait for peripheral
        if (m_cb.interrupt_driven)
            return NRFX_ERROR_BUSY;
        nrf_qspi_event_clear(NRF_QSPI, NRF_QSPI_EVENT_READY);
        if (m_cb.handler)
            m_cb.interrupt_driven = true;
            nrf_qspi_int_enable(NRF_QSPI, NRF_QSPI_INT_READY_MASK);
      ISR_flag =0;
        nrf_qspi_task_trigger(NRF_QSPI, task);
        if (m_cb.handler == NULL)
            while (!nrf_qspi_event_check(NRF_QSPI, NRF_QSPI_EVENT_READY))
        while(!ISR_flag);
        return NRFX_SUCCESS;
    static bool qspi_pins_configure(nrf_qspi_pins_t const * p_config)
        // Check if the user set meaningful values to struct fields. If not, return false.
        if ((p_config->sck_pin == NRF_QSPI_PIN_NOT_CONNECTED) ||
            (p_config->csn_pin == NRF_QSPI_PIN_NOT_CONNECTED) ||
            (p_config->io0_pin == NRF_QSPI_PIN_NOT_CONNECTED) ||
            (p_config->io1_pin == NRF_QSPI_PIN_NOT_CONNECTED))
            return false;
        nrf_qspi_pins_set(NRF_QSPI, p_config);
        return true;
    nrfx_err_t nrfx_qspi_init(nrfx_qspi_config_t const * p_config,
                              nrfx_qspi_handler_t        handler,
                              void *                     p_context)
        NRFX_ASSERT(p_config);
        if (m_cb.state != NRFX_DRV_STATE_UNINITIALIZED)
            return NRFX_ERROR_INVALID_STATE;
        if (!qspi_pins_configure(&p_config->pins))
            return NRFX_ERROR_INVALID_PARAM;
        nrf_qspi_xip_offset_set(NRF_QSPI, p_config->xip_offset);
        nrf_qspi_ifconfig0_set(NRF_QSPI, &p_config->prot_if);
        nrf_qspi_ifconfig1_set(NRF_QSPI, &p_config->phy_if);
        m_cb.handler = handler;
        m_cb.p_context = p_context;
        /* QSPI interrupt is disabled because the device should be enabled in polling mode (wait for activate
           task event ready)*/
        nrf_qspi_int_disable(NRF_QSPI, NRF_QSPI_INT_READY_MASK);
        if (handler)
            NRFX_IRQ_PRIORITY_SET(QSPI_IRQn, p_config->irq_priority);
            NRFX_IRQ_ENABLE(QSPI_IRQn);
        m_cb.state = NRFX_DRV_STATE_INITIALIZED;
        nrf_qspi_enable(NRF_QSPI);
        nrf_qspi_task_trigger(NRF_QSPI, NRF_QSPI_TASK_ACTIVATE);
        // Waiting for the peripheral to activate
        bool result;
        NRFX_WAIT_FOR(nrf_qspi_event_check(NRF_QSPI, NRF_QSPI_EVENT_READY),
                      QSPI_DEF_WAIT_ATTEMPTS,
                      QSPI_DEF_WAIT_TIME_US,
                      result);
        if (!result)
            return NRFX_ERROR_TIMEOUT;
    nrfx_err_t nrfx_qspi_cinstr_xfer(nrf_qspi_cinstr_conf_t const * p_config,
                                     void const *                   p_tx_buffer,
                                     void *                         p_rx_buffer)
        NRFX_ASSERT(m_cb.state != NRFX_DRV_STATE_UNINITIALIZED);
        /* In some cases, only opcode should be sent. To prevent execution, set function code is
         * surrounded by an if.
        if (p_tx_buffer)
            nrf_qspi_cinstrdata_set(NRF_QSPI, p_config->length, p_tx_buffer);
        /* modify begin by Leo, 2020-06-28,not need to disable interrupt if no use it*/
        if(m_cb.handler)
        /* modify end by Leo, 2020-06-28 */
        nrf_qspi_cinstr_transfer_start(NRF_QSPI, p_config);
        bool result;
                      result);
        if (!result)
            // This timeout should never occur when WIPWAIT is not active, since in this
            // case the QSPI peripheral should send the command immediately, without any
            // waiting for previous write to complete.
            NRFX_ASSERT(p_config->wipwait);
        /* modify begin by Leo, 2020-06-28 not need to disable interrupt if no use it*/
        if(m_cb.handler)
        if (p_rx_buffer)
            nrf_qspi_cinstrdata_get(NRF_QSPI, p_config->length, p_rx_buffer);
    nrfx_err_t nrfx_qspi_cinstr_quick_send(uint8_t               opcode,
                                           nrf_qspi_cinstr_len_t length,
                                           void const *          p_tx_buffer)
        nrf_qspi_cinstr_conf_t config = NRFX_QSPI_DEFAULT_CINSTR(opcode, length);
        return nrfx_qspi_cinstr_xfer(&config, p_tx_buffer, NULL);
    nrfx_err_t nrfx_qspi_mem_busy_check(void)
        nrfx_err_t ret_code;
        uint8_t status_value = 0;
        nrf_qspi_cinstr_conf_t const config =
            NRFX_QSPI_DEFAULT_CINSTR(QSPI_STD_CMD_RDSR,
                                     NRF_QSPI_CINSTR_LEN_2B);
        ret_code = nrfx_qspi_cinstr_xfer(&config, &status_value, &status_value);
        if (ret_code != NRFX_SUCCESS)
            return ret_code;
        if ((status_value & QSPI_MEM_STATUSREG_WIP_Pos) != 0x00)
    void nrfx_qspi_uninit(void)
        nrf_qspi_task_trigger(NRF_QSPI, NRF_QSPI_TASK_DEACTIVATE);
        // Workaround for nRF52840 anomaly 122: Current consumption is too high.
        *(volatile uint32_t *)0x40029054ul = 1ul;
        nrf_qspi_disable(NRF_QSPI);
        NRFX_IRQ_DISABLE(QSPI_IRQn);
        m_cb.state = NRFX_DRV_STATE_UNINITIALIZED;
    nrfx_err_t nrfx_qspi_write(void const * p_tx_buffer,
                               size_t       tx_buffer_length,
                               uint32_t     dst_address)
        NRFX_ASSERT(p_tx_buffer != NULL);
        if (!nrfx_is_in_ram(p_tx_buffer))
            return NRFX_ERROR_INVALID_ADDR;
        nrf_qspi_write_buffer_set(NRF_QSPI, p_tx_buffer, tx_buffer_length, dst_address);
        return qspi_task_perform(NRF_QSPI_TASK_WRITESTART);
    nrfx_err_t nrfx_qspi_read(void *   p_rx_buffer,
                              size_t   rx_buffer_length,
                              uint32_t src_address)
        NRFX_ASSERT(p_rx_buffer != NULL);
        if (!nrfx_is_in_ram(p_rx_buffer))
        nrf_qspi_read_buffer_set(NRF_QSPI, p_rx_buffer, rx_buffer_length, src_address);
        return qspi_task_perform(NRF_QSPI_TASK_READSTART);
    nrfx_err_t nrfx_qspi_erase(nrf_qspi_erase_len_t length,
                               uint32_t             start_address)
        nrf_qspi_erase_ptr_set(NRF_QSPI, start_address, length);
        return qspi_task_perform(NRF_QSPI_TASK_ERASESTART);
    nrfx_err_t nrfx_qspi_chip_erase(void)
        return nrfx_qspi_erase(NRF_QSPI_ERASE_LEN_ALL, 0);
    void nrfx_qspi_irq_handler(void)
        // Catch Event ready interrupts
        if (nrf_qspi_event_check(NRF_QSPI, NRF_QSPI_EVENT_READY))
            ISR_flag = 1;
            m_cb.handler(NRFX_QSPI_EVENT_DONE, m_cb.p_context);
