I setup nrfutil to use VALIDATE_ECDSA_P256_SHA256 and have this output from the pkg display output:
|- hash_type: SHA256
|- hash (little-endian): 60de8328530e5882b789259309c47d20dc1a9482f89606ad2cb70d9ad6456b1b
|- boot_validation_type: ['VALIDATE_ECDSA_P256_SHA256']
|- boot_validation_signature (little-endian): ['46bce1a61fda3d5aa8c3619d22b06d476f9462daeac753b563553e25eb8c0fe9b748763052e1390cf979e9d53ec043b894b1509a16c84b2829a7f9f1a49e941b']
Now I want to take the boot_validation_signature and transform it back into something that openssl dgst command can validate.
I have tried echo 46bce...941b | xxd -r -p > nrfutil.sign (following the hint from openssl).
However the resulting signature is a different length than what openssl actually generates
xxd nrfutil.sign
00000000: 46bc e1a6 1fda 3d5a a8c3 619d 22b0 6d47 F.....=Z..a.".mG
00000010: 6f94 62da eac7 53b5 6355 3e25 eb8c 0fe9 o.b...S.cU>%....
00000020: b748 7630 52e1 390c f979 e9d5 3ec0 43b8 .Hv0R.9..y..>.C.
00000030: 94b1 509a 16c8 4b28 29a7 f9f1 a49e 941b ..P...K().......
xxd openssl-signature.bin
00000000: 3045 0220 5526 372b 0415 026c 2308 f42d 0E. U&7+...l#..-
00000010: e1b6 5040 f7d0 a9bb 3755 9b4d 2954 c44b [email protected])T.K
00000020: e4a6 f79c 0221 00ae ec64 d704 a716 83b0 .....!...d......
00000030: db84 d9dd 58a2 588f be9c 5a52 8e25 4ea8 ....X.X...ZR.%N.
00000040: 1349 5c8d 07a8 5e .I\...^
As a reference, I am using these openssl commands to sign and verify (using openssl version 1.1.1g in case that matters)
openssl dgst -sha256 -sign private.pem < test.bin > openssl-signature.bin
openssl dgst -sha256 -verify public.pem -signature openssl-signature.bin < test.bin
And this commands verify okay if I am using the openssl-signature.bin
When I use the same -verify command with the nrfutil.sign, I got this error
Error Verifying Data
4540624320:error:0D07207B:asn1 encoding routines:ASN1_get_object:header too long:crypto/asn1/asn1_lib.c:101:
4540624320:error:0D068066:asn1 encoding routines:asn1_check_tlen:bad object header:crypto/asn1/tasn_dec.c:1118:
4540624320:error:0D07803A:asn1 encoding routines:asn1_item_embed_d2i:nested asn1 error:crypto/asn1/tasn_dec.c:290:Type=ECDSA_SIG
What is the correct way to transform boot_validation_signature into something that openssl can cross-check?
Thank you for everyone's time!
