Hello!
I am currently trying to use the watchdog driver from the Zephyr library. I have enabled the CONFIG_WATCHDOG and set it up similarly to the asset_tracker application example.
The problems I am experiencing is that the max time window I set does not seem to be close to correct. Setting it to 300ms results in restarts after about 20 seconds, while 6000ms results in restarts after around 400s. Am I missing something?
This is how I set it up in the application:
#include <zephyr.h>
#include <device.h>
#include <drivers/watchdog.h>
static struct device *wdt_dev;
static int wdt_main_channel;
static struct wdt_timeout_cfg wdt_cfg = {
.window =
.min = 0,
.max = CONFIG_WDT_MAX_TIMEOUT_MS, // This is set to 6000
.callback = NULL,
.flags = WDT_FLAG_RESET_SOC,
int main() {
wdt_dev = device_get_binding(DT_LABEL(DT_NODELABEL(wdt)));
if (wdt_dev == NULL) {
LOG_ERR("Could not set up watchdog");
return -1;
wdt_main_channel = wdt_install_timeout(wdt_dev, &wdt_cfg);
if (wdt_main_channel < 0) {
LOG_ERR("Could not install wdt timeout. (error: %d)", wdt_main_channel);
return wdt_main_channel;
ret = wdt_setup(wdt_dev,
WDT_OPT_PAUSE_HALTED_BY_DBG | WDT_OPT_PAUSE_IN_SLEEP);
if (ret < 0) {
LOG_ERR("Could not setup WDT");
return ret;
LOG_INF("Watchdog set up with a %ds interval", CONFIG_WDT_MAX_TIMEOUT_MS/1000);
My SDK is at this commit: 7c35ef35fe604c8d69096f93a460852c5023eae4 as I require manual modem toggling, and I have a v0.9.0 devkit.
