I tried to launch your example "Bluetooth: Mesh Light" using nRF5340 PDK and I failed. I followed this guide developer.nordicsemi.com/.../README.html. Also I tried to launch an example "Bluetooth: Mesh" (docs.zephyrproject.org/.../README.html) using nRF5340 PDK and I failed. I wrote out all combinations of samples in a table below which I tried to build and run, but all of them didn't work properly. But when I built the sample "Bluetooth: Mesh Light" for nRF52840 DK, then everything worked properly. The problems occurred only in the case of nRF5340 PDK.
| Firmwares for application core in rows and firmwares for network core in columns. | Network core had firmware from sample /ncs/zephyr/samples/bluetooth/hci_rpmsg without any modification. | Network core had firmware from sample /ncs/zephyr/samples/bluetooth/hci_rpmsg with modification according to note from developer.nordicsemi.com/.../README.html, adding two lines to prj.conf:CONFIG_BT_CTLR_TX_BUFFER_SIZE=74CONFIG_BT_CTLR_DATA_LENGTH_MAX=74 |
| Application core had firmware from sample /ncs/nrf/samples/bluetooth/mesh/light without any modification. | I followed this instruction developer.nordicsemi.com/.../README.html and after the second step I had such messages for some time: Connecting... Discovering services... And a while it came back to a Scanner page. So I couldn't connect to nRF5340 PDK. It's output into UART: *** Booting Zephyr OS build v2.3.0-rc1-ncs1 *** Initializing... I: No ID address. App must call settings_load() Bluetooth initialized Mesh initialized |
I saw the following problem in output into UART:*** Booting Zephyr OS build v2.3.0-rc1-ncs1 *** Initializing... W: opcode 0x0c33 status 0x12 Bluetooth init failed (err -5) Certainly, I couldn't even see a node in nRF Mesh Scanner. |
Application core had firmware from sample /ncs/nrf/samples/bluetooth/mesh/light with modification according to note from developer.nordicsemi.com/.../README.html, adding two lines to prj.conf:CONFIG_BT_CTLR_TX_BUFFER_SIZE=74CONFIG_BT_CTLR_DATA_LENGTH_MAX=74 |
| Application core had firmware from sample /ncs/zephyr/samples/bluetooth/mesh without any modification. | I followed this instruction developer.nordicsemi.com/.../README.html and after the second step I had such messages for some time: Connecting... Discovering services... And a while it came back to a Scanner page. So I couldn't connect to nRF5340 PDK. It's output into UART: [00:00:00.021,728] <inf> bt_hci_core: HW Variant: nRF53x (0x0003) Bluetooth initialized Mesh initialized [00:00:00.021,728] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 2.3 Build 0 [00:00:00.022,460] <inf> bt_hci_core: No ID address. App must call settings_load() [00:00:00.049,346] <inf> bt_hci_core: Identity: eb:f6:da:7f:da:51 (random) [00:00:00.049,377] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1 [00:00:00.049,377] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff [00:00:00.050,872] <dbg> bt_mesh_settings.mesh_commit: sub[0].net_idx 0xffff [00:00:00.050,994] <inf> bt_mesh_prov: Device UUID: 00000000-0000-0000-0000-0000000~ |
I saw the following problem in output into UART:*** Booting Zephyr OS build v2.3.0-rc1-ncs1 *** Initializing... [00:00:00.008,270] <inf> fs_nvs: 2 Sectors of 4096 bytes [00:00:00.008,270] <inf> fs_nvs: alloc wra: 0, ff0 [00:00:00.008,270] <inf> fs_nvs: data wra: 0, 8 [00:00:00.019,317] <wrn> bt_hci_core: opcode 0x0c33 status 0x12 Bluetooth init failed (err -5) Certainly, I couldn't even see a node in nRF Mesh Scanner. |
Application core had firmware from sample /ncs/zephyr/samples/bluetooth/mesh with modification according to an answer from devzone.nordicsemi.com/.../254172, adding two lines to prj.conf:CONFIG_BT_TINYCRYPT_ECC=yCONFIG_BT_L2CAP_RX_MTU=69 |
I followed this instruction developer.nordicsemi.com/.../README.html and after the second step I had such messages for some time: Connecting... Discovering services... And a while it came back to a Scanner page. So I couldn't connect to nRF5340 PDK. It's output into UART: *** Booting Zephyr OS build v2.3.0-rc1-ncs1 *** Initializing... [00:00:00.008,270] <inf> fs_nvs: 2 Sectors of 4096 bytes [00:00:00.008,270] <inf> fs_nvs: alloc wra: 0, fd0 [00:00:00.008,270] <inf> fs_nvs: data wra: 0, 2c [00:00:00.021,484] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002) Bluetooth initialized Mesh initialized [00:00:00.021,484] <inf> bt_hci_core: HW Variant: nRF53x (0x0003) [00:00:00.021,514] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 2.3 Build 0 [00:00:00.022,216] <inf> bt_hci_core: No ID address. App must call settings_load() [00:00:00.042,907] <inf> bt_hci_core: Identity: eb:f6:da:7f:da:51 (random) [00:00:00.042,907] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1 [00:00:00.042,907] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff [00:00:00.044,403] <dbg> bt_mesh_settings.mesh_commit: sub[0].net_idx 0xffff [00:00:00.044,494] <inf> bt_mesh_prov: Device UUID: 00000000-0000-0000-0000-0000000~ |
Application core had firmware from sample /ncs/zephyr/samples/bluetooth/mesh with modification according to note from developer.nordicsemi.com/.../README.html, adding two lines to prj.conf:CONFIG_BT_CTLR_TX_BUFFER_SIZE=74CONFIG_BT_CTLR_DATA_LENGTH_MAX=74 |
I followed this instruction developer.nordicsemi.com/.../README.html and after the second step I had such messages for some time: Connecting... Discovering services... And a while it came back to a Scanner page. So I couldn't connect to nRF5340 PDK. It's output into UART: *** Booting Zephyr OS build v2.3.0-rc1-ncs1 *** Initializing... [00:00:00.008,239] <inf> fs_nvs: 2 Sectors of 4096 bytes [00:00:00.008,270] <inf> fs_nvs: alloc wra: 0, f90 [00:00:00.008,270] <inf> fs_nvs: data wra: 0, f4 [00:00:00.021,820] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002) Bluetooth initialized Mesh initialized [00:00:00.021,820] <inf> bt_hci_core: HW Variant: nRF53x (0x0003) [00:00:00.021,820] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 2.3 Build 0 [00:00:00.022,552] <inf> bt_hci_core: No ID address. App must call settings_load() [00:00:00.038,055] <inf> bt_hci_core: Identity: eb:f6:da:7f:da:51 (random) [00:00:00.038,085] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1 [00:00:00.038,085] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff [00:00:00.039,581] <dbg> bt_mesh_settings.mesh_commit: sub[0].net_idx 0xffff [00:00:00.039,703] <inf> bt_mesh_prov: Device UUID: 00000000-0000-0000-0000-0000000~ |
I saw the following problem in output into UART: *** Booting Zephyr OS build v2.3.0-rc1-ncs1 *** Initializing... [00:00:00.008,270] <inf> fs_nvs: 2 Sectors of 4096 bytes [00:00:00.008,270] <inf> fs_nvs: alloc wra: 0, ff0 [00:00:00.008,270] <inf> fs_nvs: data wra: 0, 0 [00:00:00.019,470] <wrn> bt_hci_core: opcode 0x0c33 status 0x12 Bluetooth init failed (err -5) Certainly, I couldn't even see a node in nRF Mesh Scanner. |
I used nRF Connect v3.4.1 Programmer to firmware a network core.
Explain to me, please, how to launch any sample of BLE mesh for nRF5340 PDK? Does the working sample exist at least?
