LTE network connection fails
Hi guys,
I am trying to connect the NRF9160-DK 0.9.0 to the LTE network with the supplied iBasis sim card.
For this purpose I have executed the following functions
bsdlib_init()
at_cmd_write(AT_SET_OFFLINE, atAns, RESPONSE_LEN, NULL)
err = lte_lc_init()
err = lte_lc_connect()
Unfortunately I could not connect to the LTE network
I receive the following error codes
err -8 for lte_lc_init()
and err -1 for lte_lc_connect()
I even tried to use the AT command AT%XSYSTEMMODE=1,0,0,0
The answer I received was at_cmd_rx 8 bytes, ERROR
In prj.conf i have the following config:
## Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
# CONFIG_NET_SOCKETS_OFFLOAD=y
## BSD library
CONFIG_BSD_LIBRARY=y
## AT host library
CONFIG_AT_HOST_LIBRARY=y
## LTE
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_MODE_LTE_M=y
## Modem
# CONFIG_MODEM_KEY_MGMT=y
Are there any essential settings missing for a successful network connection?
  • Hi.
    What network are you trying to connect to (which country and network operator)?
    What return codes do you get from bsdlib_init(), and at_cmd_write()?
    And what is AT_SET_OFFLINE?
    Also, a couple of notes on your code:
    The bsd library is initialized automatically unless CONFIG_BSD_LIBRARY_SYS_INIT is set to 'n'.
    The modem starts in offline mode after the device has been reset.
    The error code (-8 ENOEXEC) indicates that the LTE link control library are unable to send an AT command (or more) to the modem. If you add
    CONFIG_LOG=y and CONFIG_AT_CMD_LOG_LEVEL_DBG=y to your prj.conf, you can see what AT commands are sent to the modem, and which one of them returns an error.
    Didrik
  • Hello Dirdrik
    Thanks for the reply
    Here my answers to your questions:
    Switzerland, I didn't specify a network operator (I saw in the LTE link monitor when I connected the asset tracker example with Sunrise) (How do I select the network operator, I assumed this happens automatically)
    Both times 0x0
    "AT+CFUN=4"
    Ok this means that I don't need to run bsdlib_init().
    Based on your answer, I assume that the following function calls are sufficient to connect to a network:
    err = lte_lc_init()
    Is this the case?
    If yes, the only step to I need to do to connect to exchange data through TCP would be to create a socket, connect and use the send and receive functionality
      err = getaddrinfo("petstore.swagger.io", NULL, &hints, &res);
      fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
      err = connect(fd, res->ai_addr, sizeof(struct sockaddr_in));
      size_t off = 0;
      int bytes = 0;
      do
        bytes = send(fd, &send_buf[off], HTTP_HEAD_LEN - off, 0);
        off += bytes;
      while (off < HTTP_HEAD_LEN);
      off = 0;
      bytes = 0;
      do
        bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off, 0);
        off += bytes;
      while (bytes != 0);
     You can specify the network to connect to the +COPS AT command. However, as you say, by default it will happen automatically based on your subscription/SIM card.
     Yes, that is correct. If you want to, you can further shorten it to lte_lc_init_and_connect().
     Yes, that looks correct.
    Did you get any log from the at_cmd module to help you identify your problem?
  • Did you get any log from the at_cmd module to help you identify your problem?
    Yes i get the following log messsages now:
    [00:00:00.412,719] <ESC><dbg> at_cmd.at_cmd_driver_init: Common AT socket created<ESC><CR><LF>
    [00:00:00.412,750] <ESC><dbg> at_cmd.at_cmd_driver_init: Common AT socket processing thread created<ESC><CR><LF>
    [00:00:00.412,750] <ESC><dbg> at_notif.module_init: Initialization<ESC><CR><LF>
    [00:00:00.412,780] <ESC><dbg> at_cmd.at_cmd_set_notification_handler: Setting notification handler to 0x00012a25<ESC><CR><LF>
    [00:00:05.246,002] <ESC><dbg> at_cmd.at_write: Sending command AT+CFUN=4<ESC><CR><LF>
    [00:00:05.246,032] <ESC><dbg> at_cmd.socket_thread_fn: AT socket thread started<ESC><CR><LF>
    LteAtCmd_SetModemMode: ANS: <CR><LF>
    [00:00:05.246,063] <ESC><dbg> at_cmd.socket_thread_fn: Allocating memory slab for AT socket<ESC><CR><LF>
    [00:00:05.246,063] <ESC><dbg> at_cmd.socket_thread_fn: Allocation done<ESC><CR><LF>
    [00:00:05.252,258] <ESC><dbg> at_cmd.at_write: Awaiting response for AT+CFUN=4<ESC><CR><LF>
    [00:00:05.260,925] <ESC><dbg> at_cmd.socket_thread_fn: at_cmd_rx 5 bytes, OK<CR><LF>
    <ESC><CR><LF>
    [00:00:05.260,955] <ESC><dbg> at_cmd.at_write: Bytes sent: 9<ESC><CR><LF>
    [00:00:05.261,016] <ESC><dbg> at_cmd.socket_thread_fn: Allocating memory slab for AT socket<ESC><CR><LF>
    [00:00:05.261,047] <ESC><dbg> at_cmd.socket_thread_fn: Allocation done<ESC><CR><LF>
    Lte_Init<CR><LF>
    Lte_NetworkConnect: Waiting for network.. ERR: Lte_NetworkConnect: lte_lc_init, err -8<CR><LF>
    ERR: Lte_NetworkConnect: lte_lc_connect, err -1<CR><LF>
    LteHttp_Init: set modem online <CR><LF>
    LteAtCmd_SetModemMode: 1<CR><LF>
    [00:00:06.302,551] <ESC><dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,0,0<ESC><CR><LF>
    [00:00:06.302,581] <ESC><dbg> at_cmd.at_write: Sending command AT%XSYSTEMMODE=1,0,0,0<ESC><CR><LF>
    [00:00:06.311,218] <ESC><dbg> at_cmd.at_write: Awaiting response for AT%XSYSTEMMODE=1,0,0,0<ESC><CR><LF>
    [00:00:06.311,401] <ESC><dbg> at_cmd.socket_thread_fn: at_cmd_rx 8 bytes, ERROR<CR><LF>
    <ESC><CR><LF>
  • Hmm, for some reason, the %XSYSTEMMODE command fails.
    Do you get the same behavior if you are using the at_client sample, and are sending the following commands?
    AT+CFUN=4
    AT+CFUN?
    If you do, I would appreciate a modem trace to debug further from the modem-side.
