There is a bug in sdk 1.3.0. When compile the "mbedtls" under the path of "modules\nrfxlib\nrf_security\src\mbedtls\" . I get the following error : mbedtls/library/chacha20.c:29:10: error: #include expects "FILENAME" or
I think there is a bug in the west tool.  If only one -Dxxxx=”xx.h"  parameter  in the command-line, the quotes will be filtered.  So update the  "nrfxlib\nrf_security\src\mbedtls\shared\CMakeLists.txt" , add a ‘NONE’ micro into the command-line:
-  target_compile_definitions(mbedcrypto_shared PRIVATE
-     MBEDTLS_CONFIG_FILE="nrf-config-noglue.h"
+  target_compile_definitions(mbedcrypto_shared PRIVATE
+   NONE PRIVATE MBEDTLS_CONFIG_FILE="nrf-config-noglue.h"
it looks work for me
Parents Reply
    This work around does not work for me, but I have another one
    I have analyzed in gcc command line which failed:
    IC:/Users/myname/ncs/v1.3.0/nrfxlib/crypto/nrf_cc310_platform/include
    -IC:/Users/myname/ncs/v1.3.0/mbedtls/include
    -IC:/Users/myname/ncs/v1.3.0/mbedtls/include/mbedtls
    -Imodules/nrfxlib/nrf_security/include
    One path one relative and not absolute
    To force absolute path, I update followinf file (line 33):
    in ncs\v1.3.0\nrfxlib\nrf_security\src\mbedtls\cc310\CMakeLists.txt
    target_include_directories(mbedcrypto_cc310_noglue PRIVATE
    ${NRF_CC310_MBEDCRYPTO_INCLUDE_PATH}
    ${common_includes}
    ${APPLICATION_BINARY_DIR}/${config_include}
    I guess this fix shall be applied to several mbedtls\XXXX\CMakeLists.txt
    (shared/vanilla/and oberon)
    Hope it will help you
    JeanFi
