I am using a thingy52 device and in that, added code of advertising and scanning from the sdk 16.
Advertising is run successfully. But getting packet loss issue.
So, I am trying to change advertising interval 20 or 50 for less packet loss. in the first arguments of the below macro.
#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
But, after changing it. I am not able to see the device in scanning and the device is rebooting after it. it only works in 100ms.
Same adverting code I am using in the development kit and beacon and in that it's working properly.
So, Anyone has any idea why advertising interval changes are not working in thingy52 device.
please see attached file. In that thingy functions, I have commented out using #if 0. So, you can see without commented functions.
/* Copyright (c) 2010 - 2017, Nordic Semiconductor ASA All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. 2. Redistributions in binary form, except as embedded into a Nordic Semiconductor ASA integrated circuit in a product or a software update for such product, must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. 3. Neither the name of Nordic Semiconductor ASA nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. 4. This software, with or without modification, must only be used with a Nordic Semiconductor ASA integrated circuit. 5. Any software provided in binary form under this license must not be reverse engineered, decompiled, modified and/or disassembled. THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include <stdint.h> #include <string.h> #include "nordic_common.h" #include "nrf.h" #include "ble_hci.h" #include "ble_advdata.h" #include "ble_advertising.h" #include "ble_conn_params.h" #include "ble_conn_state.h" #include "softdevice_handler_appsh.h" #include "app_timer.h" #include "fstorage.h" #include "m_ble.h" #include "m_ble_flash.h" #include "drv_nfc.h" #include "thingy_config.h" #include "advertiser_beacon.h" #include "pca20020.h" #include "nrf_delay.h" #include "nrf_drv_rng.h" #include "support_func.h" #include "app_scheduler.h" #include "m_ui.h" #include "nrf_log_ctrl.h" #define NRF52_THINGY 0x01 #define NRF_LOG_MODULE_NAME "m_ble " #include "nrf_log.h" #include "macros_common.h" #ifdef BLE_DFU_APP_SUPPORT #include "ble_dfu.h" #endif // BLE_DFU_APP_SUPPORT #ifdef BLE_DFU_APP_SUPPORT #define DFU_REV_MAJOR 0x00 /** DFU Major revision number to be exposed. */ #define DFU_REV_MINOR 0x01 /** DFU Minor revision number to be exposed. */ #define DFU_REVISION ((DFU_REV_MAJOR << 8) | DFU_REV_MINOR) /** DFU Revision number to be exposed. Combined of major and minor versions. */ #define APP_SERVICE_HANDLE_START 0x000C /**< Handle of first application specific service when when service changed characteristic is present. */ #define BLE_HANDLE_MAX 0xFFFF /**< Max handle value in BLE. */ STATIC_ASSERT(IS_SRVC_CHANGED_CHARACT_PRESENT); /** When having DFU Service support in application the Service Changed Characteristic should always be present. */ #endif // BLE_DFU_APP_SUPPORT #define RANDOM_VECTOR_DEVICE_ID_SIZE 4 /** Length of random ID vector. Must be <= 32. */ static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */ static m_ble_evt_handler_t m_evt_handler = 0; static m_ble_service_handle_t * m_service_handles = 0; static uint32_t m_service_num = 0; static ble_tcs_t m_tcs; static ble_tcs_params_t * m_ble_config; static const ble_tcs_params_t m_ble_default_config = THINGY_CONFIG_DEFAULT; static ble_tcs_mtu_t m_mtu; static bool m_flash_disconnect = false; static bool m_major_minor_fw_ver_changed = false; static char m_mac_addr[SUPPORT_FUNC_MAC_ADDR_STR_LEN]; /**< The device MAC address. */ static uint8_t m_random_vector_device_id[RANDOM_VECTOR_DEVICE_ID_SIZE]; /**< Device random ID. Used for NFC BLE pairng on iOS. */ #define NRF_BLE_MAX_MTU_SIZE BLE_GATT_ATT_MTU_DEFAULT*12 /**< MTU size used in the softdevice enabling and to reply to a BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event. */ //#define DEVICE_NAME "SD_ALERT" #define LED_1 17 #define LED_2 18 #define LED_3 19 #define LED_4 20 #define SCHED_MAX_EVENT_DATA_SIZE MAX(APP_TIMER_SCHED_EVENT_DATA_SIZE, BLE_STACK_HANDLER_SCHED_EVT_SIZE) /**< Maximum size of scheduler events. */ #define SCHED_QUEUE_SIZE 60 /**< Maximum number of events in the scheduler queue. */ /**@brief Variable length data encapsulation in terms of length and pointer to data */ typedef struct { uint8_t * p_data; /**< Pointer to data. */ uint16_t data_len; /**< Length of data. */ } data_t; #define APP_CFG_NON_CONN_ADV_TIMEOUT 0 /**< Time for which the device must be advertising in non-connectable mode (in seconds). 0 disables timeout. */ #define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(50, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */ #define SCAN_INTERVAL 0x0064 /**< Determines scan interval in units of 0.625 millisecond. */ #define SCAN_WINDOW 0x0032 /**< Determines scan window in units of 0.625 millisecond. */ #define LIST_LEN 10U /**< Device List Length*/ #define CONN_CFG_TAG_THINGY 1 #define SCAN_EVT_THRESHOLD 50U #define MANUFACTURE_DATA_LEN 4 #define DEAD_BEEF 0xDEADBEEF APP_TIMER_DEF(proximity_app_timer_id); static ble_gap_scan_params_t m_scan_param; /**< Scan parameters requested for scanning and connection. */ static bool scan_evt = false; static uint8_t scan_result_not_avail_count = 0U; static uint8_t manufacure_adv_data[MANUFACTURE_DATA_LEN] = {0x01, 0x3E, 0x46, 0x82}; static ble_gap_adv_params_t m_adv_params; static const nrf_drv_twi_t m_twi_sensors = NRF_DRV_TWI_INSTANCE(TWI_SENSOR_INSTANCE); /**< Parameters to be passed to the stack when starting advertising. */ static m_ble_service_handle_t m_ble_service_handles[THINGY_SERVICES_MAX]; /**@brief Function for the Event Scheduler initialization. */ static void scheduler_init(void) { APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE); } #ifdef BLE_DFU_APP_SUPPORT static ble_dfu_t m_dfus; /**< Structure used to identify the DFU service. */ static void ble_dfu_evt_handler(ble_dfu_t * p_dfu, ble_dfu_evt_t * p_evt) { switch (p_evt->type) { case BLE_DFU_EVT_INDICATION_DISABLED: NRF_LOG_INFO("Indication for BLE_DFU is disabled\r\n"); break; case BLE_DFU_EVT_INDICATION_ENABLED: NRF_LOG_INFO("Indication for BLE_DFU is enabled\r\n"); break; case BLE_DFU_EVT_ENTERING_BOOTLOADER: NRF_LOG_INFO("Device is entering bootloader mode!\r\n"); break; default: NRF_LOG_WARNING("Unknown event from ble_dfu\r\n"); break; } } #endif // BLE_DFU_APP_SUPPORT #define CONN_CFG_TAG_THINGY 1 /**@brief Check if flash is currently being accessed. */ static bool flash_access_ongoing(void) { fs_ret_t err_code; uint32_t flash_op_cnt = 0; err_code = fs_queued_op_count_get(&flash_op_cnt); APP_ERROR_CHECK(err_code); return (flash_op_cnt == 0) ? false : true; } #if 0 /**@brief Generate random number. */ static uint32_t random_vector_generate(uint8_t * p_buff, uint8_t size) { uint32_t err_code; uint8_t bytes_available = 0; nrf_drv_rng_bytes_available(&bytes_available); uint8_t retries = 0; while (bytes_available < size) { retries++; NRF_LOG_WARNING("Too few random bytes available. Trying again \r\n"); nrf_drv_rng_bytes_available(&bytes_available); nrf_delay_ms(5); if (retries > 5) // Return after n attempts. { return NRF_ERROR_TIMEOUT; } } NRF_LOG_INFO("Available random bytes: %d \r\n", bytes_available); err_code = nrf_drv_rng_rand(p_buff, size); RETURN_IF_ERROR(err_code); NRF_LOG_INFO("Random value (hex): "); for (uint8_t i = 0; i < size; i++) { NRF_LOG_RAW_INFO("%02x", p_buff[i]); } NRF_LOG_RAW_INFO("\r\n"); return NRF_SUCCESS; } /**@brief Function for the GAP initialization. * * @details This function will set up all the necessary GAP (Generic Access Profile) parameters of * the device. It also sets the permissions and appearance. */ static uint32_t gap_params_init(void) { uint32_t err_code; ble_gap_conn_params_t gap_conn_params; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, m_ble_config->dev_name.name, strlen((const char *)m_ble_config->dev_name.name)); APP_ERROR_CHECK(err_code); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = m_ble_config->conn_params.min_conn_int; gap_conn_params.max_conn_interval = m_ble_config->conn_params.max_conn_int; gap_conn_params.slave_latency = m_ble_config->conn_params.slave_latency; gap_conn_params.conn_sup_timeout = m_ble_config->conn_params.sup_timeout; err_code = sd_ble_gap_ppcp_set(&gap_conn_params); if (err_code == NRF_ERROR_INVALID_PARAM) { // Use default config m_ble_config->conn_params.min_conn_int = (uint16_t)MSEC_TO_UNITS(MIN_CONN_INTERVAL_MS, UNIT_1_25_MS); m_ble_config->conn_params.max_conn_int = MSEC_TO_UNITS(MAX_CONN_INTERVAL_MS, UNIT_1_25_MS); m_ble_config->conn_params.slave_latency = SLAVE_LATENCY; m_ble_config->conn_params.sup_timeout = MSEC_TO_UNITS(CONN_SUP_TIMEOUT_MS, UNIT_10_MS); err_code = m_ble_flash_config_store(m_ble_config); if (err_code != NRF_SUCCESS) { return err_code; } gap_conn_params.min_conn_interval = (uint16_t)MSEC_TO_UNITS(MIN_CONN_INTERVAL_MS, UNIT_1_25_MS); gap_conn_params.max_conn_interval = MSEC_TO_UNITS(MAX_CONN_INTERVAL_MS, UNIT_1_25_MS); gap_conn_params.slave_latency = SLAVE_LATENCY; gap_conn_params.conn_sup_timeout = MSEC_TO_UNITS(CONN_SUP_TIMEOUT_MS, UNIT_10_MS); err_code = sd_ble_gap_ppcp_set(&gap_conn_params); if (err_code != NRF_SUCCESS) { return err_code; } } else if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } /**@brief Function for handling an event from the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module * which are passed to the application. * * @note All this function does is to disconnect. This could have been done by simply setting * the disconnect_on_fail config parameter, but instead we use the event handler * mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void on_conn_params_evt(ble_conn_params_evt_t * p_evt) { uint32_t err_code; if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { NRF_LOG_ERROR("on_conn_params_evt: BLE_CONN_PARAMS_EVT_FAILED\r\n"); err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } else if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_SUCCEEDED) { NRF_LOG_INFO("on_conn_params_evt: BLE_CONN_PARAMS_EVT_SUCCEEDED\r\n"); } else { } } /**@brief Function for handling errors from the Connection Parameters module. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void conn_params_error_handler(uint32_t nrf_error) { NRF_LOG_ERROR("conn_params_error_handler: %d\r\n", nrf_error); APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing the Connection Parameters module. */ static uint32_t conn_params_init(void) { uint32_t err_code; ble_conn_params_init_t cp_init; ble_gap_conn_params_t gap_conn_params; memset(&cp_init, 0, sizeof(cp_init)); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = m_ble_config->conn_params.min_conn_int; gap_conn_params.max_conn_interval = m_ble_config->conn_params.max_conn_int; gap_conn_params.slave_latency = m_ble_config->conn_params.slave_latency; gap_conn_params.conn_sup_timeout = m_ble_config->conn_params.sup_timeout; cp_init.p_conn_params = &gap_conn_params; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID; cp_init.disconnect_on_fail = false; cp_init.evt_handler = on_conn_params_evt; cp_init.error_handler = conn_params_error_handler; err_code = ble_conn_params_init(&cp_init); if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } #endif /**@brief Function for starting timer. */ static void timer_start (void) { ret_code_t err_code; } /**@brief Function for initializing timers. */ static void timer_init (void) { ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing the Advertising functionality. * * @details Encodes the required advertising data and passes it to the stack. * Also builds a structure to be passed to the stack when starting advertising. */ static void advertising_init(void) { uint32_t err_code; ble_advdata_t advdata; ble_gap_conn_sec_mode_t sec_mode; BLE_GAP_CONN_SEC_MODE_SET_OPEN(&sec_mode); err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *) DEVICE_NAME, strlen(DEVICE_NAME)); // Manufacturer specific data in advertising packet. ble_advdata_manuf_data_t adv_manuf_data; adv_manuf_data.data.p_data = manufacure_adv_data; adv_manuf_data.data.size = MANUFACTURE_DATA_LEN; // Build advertising data struct to pass into @ref ble_advertising_init. memset(&advdata, 0, sizeof(advdata)); advdata.name_type = BLE_ADVDATA_FULL_NAME; advdata.include_appearance = false; advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; advdata.p_manuf_specific_data = &adv_manuf_data; err_code = ble_advdata_set(&advdata, NULL); APP_ERROR_CHECK(err_code); // Initialize advertising parameters (used when starting advertising). memset(&m_adv_params, 0, sizeof(m_adv_params)); m_adv_params.type = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND; m_adv_params.p_peer_addr = NULL; // Undirected advertisement. m_adv_params.fp = BLE_GAP_ADV_FP_ANY; m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL; m_adv_params.timeout = APP_CFG_NON_CONN_ADV_TIMEOUT; m_adv_params.channel_mask.ch_38_off = 0x01; m_adv_params.channel_mask.ch_39_off = 0x01; err_code = sd_ble_gap_tx_power_set(-20); APP_ERROR_CHECK(err_code); } /**@brief Function for starting advertising. */ static void advertising_start(void) { ret_code_t err_code; err_code = sd_ble_gap_adv_start(&m_adv_params, BLE_CONN_CFG_TAG_DEFAULT); APP_ERROR_CHECK(err_code); } static void scan_init (void) { m_scan_param.active = 1; m_scan_param.interval = SCAN_INTERVAL; m_scan_param.window = SCAN_WINDOW; m_scan_param.use_whitelist = 0; m_scan_param.adv_dir_report = 0; m_scan_param.timeout = 0x0000; } static void scan_start (void) { uint32_t err_code; err_code = sd_ble_gap_scan_start(&m_scan_param); APP_ERROR_CHECK(err_code); } /**@brief Function for initializing logging. */ static void log_init(void) { ret_code_t err_code = NRF_LOG_INIT(NULL); APP_ERROR_CHECK(err_code); } #if 0 /**@brief Function for handling advertising events. * * @details This function will be called for advertising events which are passed to the application. * * @param[in] ble_adv_evt Advertising event. */ static void on_adv_evt(ble_adv_evt_t ble_adv_evt) { uint32_t err_code; m_ble_evt_t evt; switch (ble_adv_evt) { case BLE_ADV_EVT_FAST: NRF_LOG_INFO("on_adv_evt: BLE_ADV_EVT_FAST\r\n"); break; case BLE_ADV_EVT_IDLE: NRF_LOG_INFO("on_adv_evt: BLE_ADV_EVT_IDLE\r\n"); evt.evt_type = thingy_ble_evt_timeout; m_evt_handler(&evt); err_code = ble_advertising_start(BLE_ADV_MODE_FAST); APP_ERROR_CHECK(err_code); break; default: break; } } #endif /**@brief Function for the application's SoftDevice event handler. * * @param[in] p_ble_evt SoftDevice event. */ static void on_ble_evt(ble_evt_t * p_ble_evt) { uint32_t err_code; m_ble_evt_t evt; static uint8_t orange_zone_pkt_count = 0U; int8_t rssi = 0U; bool bRet = false; switch (p_ble_evt->header.evt_id) { case BLE_GAP_EVT_ADV_REPORT: break; default: // No implementation needed. break; } } /**@brief Function for dispatching a SoftDevice event to all modules with a SoftDevice * event handler. * * @details This function is called from the SoftDevice event interrupt handler after a * SoftDevice event has been received. * * @param[in] p_ble_evt SoftDevice event. */ static void ble_evt_dispatch(ble_evt_t * p_ble_evt) { ble_conn_state_on_ble_evt(p_ble_evt); ble_conn_params_on_ble_evt(p_ble_evt); for (uint32_t i = 0; i < m_service_num; i++) { if (m_service_handles[i].ble_evt_cb != NULL) { m_service_handles[i].ble_evt_cb(p_ble_evt); } } ble_tcs_on_ble_evt(&m_tcs, p_ble_evt); #ifdef BLE_DFU_APP_SUPPORT ble_dfu_on_ble_evt(&m_dfus, p_ble_evt); #endif // BLE_DFU_APP_SUPPORT on_ble_evt(p_ble_evt); ble_advertising_on_ble_evt(p_ble_evt); } /**@brief Function for dispatching system events from the SoftDevice. * * @details This function is called from the SoftDevice event interrupt handler after a * SoftDevice event has been received. * * @param[in] evt_id System event id. */ static void sys_evt_dispatch(uint32_t evt_id) { fs_sys_event_handler(evt_id); app_beacon_on_sys_evt(evt_id); ble_advertising_on_sys_evt(evt_id); if ( (evt_id == NRF_EVT_FLASH_OPERATION_SUCCESS) || (evt_id == NRF_EVT_FLASH_OPERATION_ERROR) ) { if (!flash_access_ongoing()) { if (m_flash_disconnect) { m_ble_evt_t evt; evt.evt_type = thingy_ble_evt_disconnected; m_evt_handler(&evt); } } } } /**@brief Function for the SoftDevice initialization. * * @details This function initializes the SoftDevice and the BLE event interrupt. */ static uint32_t ble_stack_init(void) { uint32_t err_code; nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC; // Initialize SoftDevice. SOFTDEVICE_HANDLER_APPSH_INIT(&clock_lf_cfg, true); //SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL); uint32_t app_ram_start = 0; err_code = softdevice_app_ram_start_get(&app_ram_start); APP_ERROR_CHECK(err_code); ble_cfg_t ble_cfg; // Configure long MTU. memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.conn_cfg.conn_cfg_tag = CONN_CFG_TAG_THINGY; ble_cfg.conn_cfg.params.gatt_conn_cfg.att_mtu = 276; err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATT, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); // Configure event length (7.5ms) memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.conn_cfg.conn_cfg_tag = CONN_CFG_TAG_THINGY; ble_cfg.conn_cfg.params.gap_conn_cfg.conn_count = 1; ble_cfg.conn_cfg.params.gap_conn_cfg.event_length = 6; err_code = sd_ble_cfg_set(BLE_CONN_CFG_GAP, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); // Configure HVN queue size memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.conn_cfg.conn_cfg_tag = CONN_CFG_TAG_THINGY; ble_cfg.conn_cfg.params.gatts_conn_cfg.hvn_tx_queue_size = 16; err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATTS, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); // Configure WRITE_CMD queue size memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.conn_cfg.conn_cfg_tag = CONN_CFG_TAG_THINGY; ble_cfg.conn_cfg.params.gattc_conn_cfg.write_cmd_tx_queue_size = 2; err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATTC, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.common_cfg.vs_uuid_cfg.vs_uuid_count = 2; err_code = sd_ble_cfg_set(BLE_COMMON_CFG_VS_UUID, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.gap_cfg.role_count_cfg.periph_role_count = 1; err_code = sd_ble_cfg_set(BLE_GAP_CFG_ROLE_COUNT, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.gatts_cfg.attr_tab_size.attr_tab_size = 3000; err_code = sd_ble_cfg_set(BLE_GATTS_CFG_ATTR_TAB_SIZE, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); memset(&ble_cfg, 0, sizeof(ble_cfg)); ble_cfg.gatts_cfg.service_changed.service_changed = 1; err_code = sd_ble_cfg_set(BLE_GATTS_CFG_SERVICE_CHANGED, &ble_cfg, app_ram_start); APP_ERROR_CHECK(err_code); err_code = softdevice_enable(&app_ram_start); APP_ERROR_CHECK(err_code); // Subscribe for BLE events. err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch); if (err_code != NRF_SUCCESS) { return err_code; } err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch); if (err_code != NRF_SUCCESS) { return err_code; } err_code = sd_power_mode_set(NRF_POWER_MODE_LOWPWR); if (err_code != NRF_SUCCESS) { return err_code; } err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE); if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } #if 0 /**@brief Function for initializing the Advertising functionality. */ static uint32_t advertising_init(void) { uint32_t err_code; ble_advdata_t advdata; ble_uuid_t adv_uuids = {BLE_UUID_TCS_SERVICE, m_tcs.uuid_type}; // Build advertising data struct to pass into @ref ble_advertising_init. memset(&advdata, 0, sizeof(advdata)); advdata.name_type = BLE_ADVDATA_FULL_NAME; advdata.include_appearance = false; advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; advdata.uuids_more_available.uuid_cnt = 1; advdata.uuids_more_available.p_uuids = &adv_uuids; ble_adv_modes_config_t options = {0}; options.ble_adv_fast_enabled = true; options.ble_adv_fast_interval = m_ble_config->adv_params.interval; options.ble_adv_fast_timeout = m_ble_config->adv_params.timeout; // Build scan response data struct to pass into @ref ble_advertising_init. ble_advdata_t scan_response_data; memset(&scan_response_data, 0, sizeof(scan_response_data)); // Manufacturer specific data in advertising packet. ble_advdata_manuf_data_t adv_manuf_data; uint8_t random_vector_device_id_reversed[RANDOM_VECTOR_DEVICE_ID_SIZE]; for (uint8_t i = 0; i < RANDOM_VECTOR_DEVICE_ID_SIZE; i++) { random_vector_device_id_reversed[i] = m_random_vector_device_id[RANDOM_VECTOR_DEVICE_ID_SIZE - i - 1]; } adv_manuf_data.company_identifier = NORDIC_COMPANY_ID; adv_manuf_data.data.p_data = random_vector_device_id_reversed; adv_manuf_data.data.size = RANDOM_VECTOR_DEVICE_ID_SIZE; scan_response_data.name_type = BLE_ADVDATA_NO_NAME; scan_response_data.p_manuf_specific_data = &adv_manuf_data; // Set both advertisement data and scan response data. err_code = ble_advertising_init(&advdata, &scan_response_data, &options, on_adv_evt, NULL); RETURN_IF_ERROR(err_code); ble_advertising_conn_cfg_tag_set(CONN_CFG_TAG_THINGY); return NRF_SUCCESS; } /**@brief Function for handling a BeaconAdvertiser error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void beacon_advertiser_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for initializing the beacon timeslot functionality. */ static uint32_t timeslot_init(void) { uint32_t err_code; static ble_beacon_init_t beacon_init; if (m_ble_config->eddystone_url.len < BLE_TCS_BEACON_LEN_MIN) { app_beacon_stop(); return NRF_SUCCESS; } beacon_init.adv_interval = THINGY_BEACON_ADV_INTERVAL; beacon_init.p_data = m_ble_config->eddystone_url.data; beacon_init.data_size = m_ble_config->eddystone_url.len; beacon_init.error_handler = beacon_advertiser_error_handler; err_code = sd_ble_gap_addr_get(&beacon_init.beacon_addr); if (err_code != NRF_SUCCESS) { return err_code; } // Increment device address by 2 for beacon advertising. beacon_init.beacon_addr.addr[0] += 2; app_beacon_init(&beacon_init); app_beacon_start(); return NRF_SUCCESS; } /**@brief Function for handling thingy configuration events. */ static void tcs_evt_handler (ble_tcs_t * p_tcs, ble_tcs_evt_type_t evt_type, uint8_t * p_data, uint16_t length) { bool update_flash = false; switch (evt_type) { case BLE_TCS_EVT_DEV_NAME: if (length <= BLE_TCS_DEVICE_NAME_LEN_MAX) { memcpy(m_ble_config->dev_name.name, p_data, length); m_ble_config->dev_name.name[length] = 0; m_ble_config->dev_name.len = length; update_flash = true; } break; case BLE_TCS_EVT_ADV_PARAM: if (length == sizeof(ble_tcs_adv_params_t)) { memcpy(&m_ble_config->adv_params, p_data, length); update_flash = true; } break; case BLE_TCS_EVT_CONN_PARAM: if (length == sizeof(ble_tcs_conn_params_t)) { uint32_t err_code; ble_gap_conn_params_t gap_conn_params; memcpy(&m_ble_config->conn_params, p_data, length); memset(&gap_conn_params, 0, sizeof(gap_conn_params)); gap_conn_params.min_conn_interval = m_ble_config->conn_params.min_conn_int; gap_conn_params.max_conn_interval = m_ble_config->conn_params.max_conn_int; gap_conn_params.slave_latency = m_ble_config->conn_params.slave_latency; gap_conn_params.conn_sup_timeout = m_ble_config->conn_params.sup_timeout; err_code = ble_conn_params_change_conn_params(&gap_conn_params); APP_ERROR_CHECK(err_code); update_flash = true; } break; case BLE_TCS_EVT_BEACON: if (length <= BLE_TCS_BEACON_LEN_MAX) { uint32_t err_code; memcpy(m_ble_config->eddystone_url.data, p_data, length); m_ble_config->eddystone_url.len = length; update_flash = true; err_code = timeslot_init(); APP_ERROR_CHECK(err_code); } break; case BLE_TCS_EVT_CLOUD_TOKEN: if (length <= BLE_TCS_CLOUD_LEN_MAX) { memcpy(m_ble_config->cloud_token.token, p_data, length); m_ble_config->cloud_token.len = length; update_flash = true; } break; case BLE_TCS_EVT_MTU: if (length == sizeof(ble_tcs_mtu_t)) { uint32_t err_code; ble_tcs_mtu_t * p_mtu = (ble_tcs_mtu_t *)p_data; if (p_mtu->req == TCS_MTU_REQ_EXCHANGE) { NRF_LOG_INFO("tcs_evt_handler: TCS_MTU_REQ_EXCHANGE - %d\r\n", p_mtu->size); err_code = sd_ble_gattc_exchange_mtu_request(m_conn_handle, p_mtu->size); if (err_code == NRF_SUCCESS) { memcpy(&m_mtu, p_data, length); } else { err_code = ble_tcs_mtu_set(&m_tcs, &m_mtu); APP_ERROR_CHECK(err_code); } } else { err_code = ble_tcs_mtu_set(&m_tcs, &m_mtu); APP_ERROR_CHECK(err_code); } } break; } if (update_flash) { uint32_t err_code; err_code = m_ble_flash_config_store(m_ble_config); APP_ERROR_CHECK(err_code); } } /**@brief Checks the current version of the FW against the previous version stored in flash. * If a major or minor FW change is detected, modules must reinitialize their flash storage. * * @note: If the FW version is changed while erasing all flash, a FW change cannot be detected. */ static uint32_t thingy_config_verify(void) { bool update_flash = false; uint32_t err_code; bool fw_version_major_changed = ( m_ble_config->fw_version.major != m_ble_default_config.fw_version.major ); bool fw_version_minor_changed = ( m_ble_config->fw_version.minor != m_ble_default_config.fw_version.minor ); bool fw_version_patch_changed = ( m_ble_config->fw_version.patch != m_ble_default_config.fw_version.patch ); ble_tcs_fw_version_t prev_fw_version = m_ble_config->fw_version; if ( fw_version_major_changed || fw_version_minor_changed || fw_version_patch_changed) { m_ble_config->fw_version.major = m_ble_default_config.fw_version.major; m_ble_config->fw_version.minor = m_ble_default_config.fw_version.minor; m_ble_config->fw_version.patch = m_ble_default_config.fw_version.patch; update_flash = true; if(fw_version_major_changed || fw_version_minor_changed) { update_flash = false; m_major_minor_fw_ver_changed = true; err_code = m_ble_flash_config_store(&m_ble_default_config); APP_ERROR_CHECK(err_code); } } NRF_LOG_INFO(NRF_LOG_COLOR_CODE_GREEN"m_ble: Current FW: v%d.%d.%d \r\n", m_ble_default_config.fw_version.major, m_ble_default_config.fw_version.minor, m_ble_default_config.fw_version.patch); if(m_major_minor_fw_ver_changed) { NRF_LOG_INFO(NRF_LOG_COLOR_CODE_YELLOW"m_ble: Major or minor FW version changed. Prev. FW (from flash): v%d.%d.%d \r\n", prev_fw_version.major, prev_fw_version.minor, prev_fw_version.patch); } // Check Eddystone URL length. if (m_ble_config->eddystone_url.len > 17) { memcpy(m_ble_config->eddystone_url.data, m_ble_default_config.eddystone_url.data, m_ble_default_config.eddystone_url.len); m_ble_config->eddystone_url.len = m_ble_default_config.eddystone_url.len; update_flash = true; } // Check Cloud Token length. if (m_ble_config->cloud_token.len > BLE_TCS_CLOUD_LEN_MAX) { memcpy(m_ble_config->cloud_token.token, m_ble_default_config.cloud_token.token, m_ble_default_config.cloud_token.len); m_ble_config->cloud_token.len = m_ble_default_config.cloud_token.len; update_flash = true; } if (update_flash) { err_code = m_ble_flash_config_store(m_ble_config); APP_ERROR_CHECK(err_code); } return NRF_SUCCESS; } static uint32_t thingy_config_init(void) { ble_tcs_init_t params; uint32_t err_code; params.p_init_vals = m_ble_config; params.evt_handler = tcs_evt_handler; err_code = ble_tcs_init(&m_tcs, ¶ms); if (err_code != NRF_SUCCESS) { return err_code; } return NRF_SUCCESS; } #endif /**@brief Function for initializing the ble services. */ static uint32_t services_init(m_ble_service_handle_t * p_service_handles, uint32_t num_services) { uint32_t err_code; //err_code = thingy_config_init(); //APP_ERROR_CHECK(err_code); for (uint32_t i = 0; i < num_services; i++) { if (p_service_handles[i].init_cb != NULL) { err_code = p_service_handles[i].init_cb(m_major_minor_fw_ver_changed); if (err_code != NRF_SUCCESS) { return err_code; } } } #ifdef BLE_DFU_APP_SUPPORT ble_dfu_init_t dfus_init; // Initialize the Device Firmware Update Service. memset(&dfus_init, 0, sizeof(dfus_init)); dfus_init.evt_handler = ble_dfu_evt_handler; dfus_init.ctrl_point_security_req_write_perm = SEC_OPEN; dfus_init.ctrl_point_security_req_cccd_write_perm = SEC_OPEN; err_code = ble_dfu_init(&m_dfus, &dfus_init); APP_ERROR_CHECK(err_code); #endif // BLE_DFU_APP_SUPPORT return NRF_SUCCESS; } uint32_t nfc_init(void) { uint32_t err_code; err_code = drv_nfc_init(); RETURN_IF_ERROR(err_code); err_code = drv_nfc_app_launch_android_record_add(THINGY_NFC_APP_ANDROID_NAME_DEFAULT, THINGY_NFC_APP_ANDROID_NAME_LEN); RETURN_IF_ERROR(err_code); uint8_t NFC_STR_LEN = SUPPORT_FUNC_MAC_ADDR_STR_LEN + (RANDOM_VECTOR_DEVICE_ID_SIZE * 2) + 1; // MAC (with '\0') + space + random vector. char nfc_string[NFC_STR_LEN]; nfc_string[0] = '\0'; strcat(nfc_string, m_mac_addr); strcat(nfc_string, " "); for (uint8_t i = 0; i < RANDOM_VECTOR_DEVICE_ID_SIZE; i++) { char tmp[3] = {0}; sprintf(tmp, "%02x", m_random_vector_device_id[i]); strcat(nfc_string, tmp); } NRF_LOG_INFO("nfc string: %s \r\n", nrf_log_push(nfc_string)); err_code = drv_nfc_string_record_add(nfc_string, NFC_STR_LEN); RETURN_IF_ERROR(err_code); err_code = drv_nfc_uri_record_add(NFC_URI_HTTP_WWW, THINGY_NFC_URI_DEFAULT, THINGY_NFC_URI_LEN); RETURN_IF_ERROR(err_code); err_code = drv_nfc_enable(); RETURN_IF_ERROR(err_code); return NRF_SUCCESS; } uint32_t m_ble_init(m_ble_init_t * p_params) { uint32_t err_code; m_evt_handler = p_params->evt_handler; m_service_handles = p_params->p_service_handles; m_service_num = p_params->service_num; err_code = ble_stack_init(); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("ble_stack_init failed - %d\r\n", err_code); return err_code; } #if 0 /* Enable FPU again due to SD issue */ #if (__FPU_USED == 1) SCB->CPACR |= (3UL << 20) | (3UL << 22); __DSB(); __ISB(); #endif err_code = random_vector_generate(m_random_vector_device_id, RANDOM_VECTOR_DEVICE_ID_SIZE); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("random_vector_generate failed - %d\r\n", err_code); return err_code; } /**@brief Load configuration from flash. */ err_code = m_ble_flash_init(&m_ble_default_config, &m_ble_config); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR(" m_ble_flash_init failed - %d\r\n", err_code); return err_code; } err_code = thingy_config_verify(); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("Thingy_config_verify failed - %d\r\n", err_code); return err_code; } err_code = gap_params_init(); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("gap_params_init failed - %d\r\n", err_code); return err_code; } #endif err_code = services_init(m_service_handles, m_service_num); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("Thingy_ble_init: services_init failed - %d\r\n", err_code); return err_code; } #if 0 err_code = advertising_init(); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("Advertising_init failed - %d\r\n", err_code); return err_code; } err_code = conn_params_init(); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("Conn_params_init failed - %d\r\n", err_code); return err_code; } err_code = ble_advertising_start(BLE_ADV_MODE_FAST); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("ble_advertising_start failed - %d\r\n", err_code); return err_code; } err_code = support_func_ble_mac_address_get(m_mac_addr); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("mac address get failed - %d\r\n", err_code); return err_code; } NRF_LOG_RAW_INFO("MAC addr-> %s \r\n", nrf_log_push(m_mac_addr)); err_code = nfc_init(); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("nfc init failed - %d\r\n", err_code); return err_code; } nrf_delay_ms (10); err_code = timeslot_init(); if (err_code != NRF_SUCCESS) { NRF_LOG_ERROR("timeslot_init failed - %d\r\n", err_code); return err_code; } #endif // Initialize. log_init(); scheduler_init(); timer_init(); advertising_init(); scan_init(); timer_start(); advertising_start(); scan_start(); // Start execution. NRF_LOG_INFO("Beacon example started.\r\n"); return NRF_SUCCESS; }
