nRF52832 reset and RESETREAS is 0x00000008(LOCKUP)
Hi,DevZone
I'm not Native English , sometimes can not express exactly, So, I'll provide a concise description about  the question
1, platform: nRF52832_QFAA _E1, nRF5_SDK_13.0
2, question: nRF52832 RESET(erratic and rare) and RESETREAS is 0x00000008(LOCKUP)
3, I have read some post at devzone
https://devzone.nordicsemi.com/f/nordic-q-a/32894/what-does-cpu-lock-up-mean-and-how-should-i-debug-this-issue/126706#126706
and
Cortex-M4 Lockup search result from google
4, my HardFualt _Handler code and WDT_Handler code:
void HardFault_Handler(void)
	/* Go to infinite loop when Hard Fault exception occurs */
	if (CoreDebug->DHCSR & 1)    //check C_DEBUGEN == 1 -> Debugger Connected
		__breakpoint(0);  // halt program execution here
	while (1)
void wdt_event_handler(void)
	while (1)
Hope someone can point out what's happen and how to dig further
Thank You
  • You can start by dumping the CPU registers into a log or reading them out via a debugger when you get a hardfault.
    so far the most likely cause of the CPU lockup is a hardfault while the CPU is executing the hardfault handler. So finding the original hardfault is necessary.
    Also, why have you not migrated to a newer SDK yet?
  • Thanks for your timely reply! and I want to consult you further.
    1) I will try to print, but i'm afraid can not do it, because It's difficult to reproduce the Reset.
    2) why can a new hardfault occur after hardfault was processing already? I'm confused, my HardFault_Handler is nothing except a empty loop, maybe a new interrupt was generated here, But any interrupt priority can be higher than hardfault?
    3) do you mean newer SDK is more stabler? and now, Is it necessary to change the SDK before  figuring out the Root cause of Reset? (maybe i can't capture reset anymore, therefore, the specific reason cannot be verified)
    1. I understand
    2. I'm not quite sure how, but it was mentioned in the devzone post you linked to.
    Yes, a lot more stable.
    The root cause might have been fixed already, SDK13 is very old.
    If the issue disappears after a migration to a newer SDK then it's not really an issue anymore right?
  • RESETREAS is 0x00000008(LOCKUP)
    How do you know that?
    I am asking because Segger RTT logging internally enables debug registers. Which means those breakpoint instruction will be executed, and directly trigger the Lockup (fault in Hard Fault condition).
    In thsi case, the Reset was capture from daily use of product instead of simulation debug. I make a simple flash system on extern-SPI-flash, which can save RESETREAS and other necessary message as soon as chip reset. the LUCKUP shown to you is readback from flash.
