GPIOTE event not coming
I have enable 4 Low power events for 4 button in NRF52832 board. when i press a button board is waking up due to low power event
but when it is waiting in low power mode using sequence __sev(); __wfe(); __wfe(); events are not coming.
if i enable GPIOTE IRQ interrupt, i am getting the interrupts in low power mode but I don't want use interrupts.
main.c
#include "nrf_esb.h"
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "sdk_common.h"
#include "nrf.h"
#include "nrf_error.h"
#include "nrf_esb_error_codes.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "app_util.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define BTN_PRESSED     0                       /**< Value of a pressed button. */
#define BTN_RELEASED    1                       /**< Value of a released button. */
static uint32_t button_state_1;
static uint32_t button_state_2;
static uint32_t button_state_3;
static uint32_t button_state_4;
uint32_t gpio_check()
    uint32_t err_code;
		if(NRF_GPIOTE->EVENTS_PORT)
			NRF_LOG_INFO("NRF_GPIOTE->EVENTS_PORT %d\n",NRF_GPIOTE->EVENTS_PORT);
			NRF_LOG_PROCESS();
			NRF_GPIOTE->EVENTS_PORT = 0;
		nrf_delay_ms(100);
    button_state_1 = nrf_gpio_pin_read(BUTTON_1);
    button_state_2 = nrf_gpio_pin_read(BUTTON_2);
    button_state_3 = nrf_gpio_pin_read(BUTTON_3);
    button_state_4 = nrf_gpio_pin_read(BUTTON_4);
    if (button_state_1 == BTN_PRESSED)
        bsp_board_led_invert(0);
    if (button_state_2 == BTN_PRESSED)
        bsp_board_led_invert(1);
    if (button_state_3 == BTN_PRESSED)
        bsp_board_led_invert(2);
    if (button_state_4 == BTN_PRESSED)
        bsp_board_led_invert(3);
		nrf_delay_ms(100);
    return NRF_SUCCESS;
#define   MY_BUTTON 			BUTTON_1
#define 	MY_LED 					LED_2
void gpio_init( void )
    nrf_gpio_cfg_sense_input(BUTTON_1, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    nrf_gpio_cfg_sense_input(BUTTON_2, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    nrf_gpio_cfg_sense_input(BUTTON_3, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    nrf_gpio_cfg_sense_input(BUTTON_4, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    // Workaround for PAN_028 rev1.1 anomaly 22 - System: Issues with disable System OFF mechanism
    nrf_delay_ms(1);
		NRF_GPIOTE->EVENTS_PORT |= (1 << BUTTON_1);
  // Enable interrupt:
  //NVIC_EnableIRQ(GPIOTE_IRQn);
  //NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Set << GPIOTE_INTENSET_PORT_Pos;
static void log_init(void)
    uint32_t err_code;
		log_init();
    gpio_init();
    while (true)
			 // Check state of all buttons  with the button press, and toggle LED
				err_code = gpio_check();
#if 1
				__SEV();
				__WFE();
				__WFE();
/*lint -restore */
I have attached simple test file main.c
