Asset Tracker application in NB-IoT mode
Hi everyone.
I'm using a Thingy:91 and the asset tracker application. I can compile and flash (using SES and a Segger J-Link) the application and the device connects to the nRF cloud.
But when I change the "network mode" from LTE-M + GPS to NB-IOT + GPS it stops working. I'm located in Canada where we do not have NB-IOT coverage, but the device should switch to fallback mode which is LTE-M. If I use the asset tracker NB-IOT binaries provided by nRF (thingy91_nbiot_dfu_2020-04-29_bc7ade8b.hex) I see exactly that: the device tries to connect, times out and falls back to LTE-M and then connects just fine.
What configuration settings do I have to change to switch the default asset tracker application from LTE-M to NB-IOT?
Below is the output of the link monitor of my test build with network mode set to NB-IOT:
%CESQ: 255,0,255,0
+CEREG: 2,"FFFE","FFFFFFFF",
[00:00:30.588,684] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"FFFE","FFFFFFFF",9
[0m
[00:00:30.598,144] [1;31m<err> lte_lc: Could not get TAU, error: -22[0m
[00:00:30.604,736] [1;31m<err> lte_lc: Failed to parse PSM configuration, error: -22[0m
[00:00:30.612,792] [1;31m<err> lte_lc: Failed to parse notification (error -22): +CEREG: 2,"FFFE","FFFFFFFF",9
[0m
%CESQ: 255,0,255,0
%CESQ: 255,0,255,0
%CESQ: 255,0,255,0
Thanks
    What NCS version are you compiling the asset tracker with?
     These files were built with nRF Connect SDK version v1.2.0-406-gbc7ade8b.
     How do you change from LTE-M to NB-IoT?
    Øyvind
  • Hi Øyvind
    I used the toolchain manager and installed nRF Connect SDC v1.3.0, looking at my installation it should be ncs-toolchain-v1.3.0-20200618-509f057
    I use the unmodified asset tracker application from the SDK. In SES I open the "Configure nRF Connect SDK Project...", and navigate to
    menuconfig: Zephyr Kernel -> Modules -> Nordic nRF Connect -> Libraries -> nRF91 LTE Link control library -> Select network mode
    and changed "LTE-M and GPS" to "NB-IoT and GPS" and confirm by clicking on "Configure".
    Then I clean and re-build the solution which is successful.
    Finally I flash the new image using the SES menu Target -> Download zephyr/merged.hex. As mentioned earlier, the Thingy91 is programmed to my PC using a SEGGER J-Link. The flash is successful and the Thingy91 starts up (breathing LED).
    Are these the correct steps to change the build to NB-IoT network mode?
    Your help is much appreciated.
    Thanks
  • I just switched to the nRF Connect SDK v1.2.0 and repeated the steps above to switch to NB-IoT mode as the default network mode and now it connects successfully once it switches to the fallback mode.
    It seems like the asset tracker application using NCS toolchain v1.3.0 does only work if the default network mode is configured to LTE-M, but not NB-IoT.
    Also now (with SDK v1.2.0) another issue shows up: If I enable "Automatic start of GPS on CLOUD_EVT_READY event after reset" the GPS doesn't seem to start properly. Looking at it closely I never seem to get the "CLOUD_EVT_READY" event. A long press on the user button produces the output below. There were no other GPS related messages before that. This tells me that the GPS did not start properly. Another long press after that and the GPS module starts (with some initial "Invalid PVT frame, discarding" messages).
    [00:01:59.213,195] [0m<inf> asset_tracker: Stopping GPS[0m
    [00:01:59.218,750] [0m<dbg> nrf9160_gps.stop: Stopping GPS[0m
    [00:01:59.224,487] [1;31m<err> nrf9160_gps: Failed to stop GPS[0m
    [00:01:59.230,560] [1;31m<err> gps_control: GPS could not be stopped, error: -5[0m
    Can you please try to run another sample from NCS v1.3.0, to see if it connects as it should. You could try the at_client sample and issue CFUN? to get more information regarding your connection. Please provide a full log from the LTE Link Monitor. I also recommend running a modem trace to see what is going on under the hood of the modem.
     Can you provide a full log the from LTE Link Monitor when you encounter this issue? What happens if you do not enable "Automatic start of GPS on CLOUD_EVT_READY event after reset"? We might need a modem trace for this as well.
    Øyvind
  • Hi Øyvind
    Will do that later today and post the results here
    Below is a LTE Link Monitor log. The asset tracker application was configured to:
    - Default Network Mode: LTE-M (I'm located in Canada which has LTE-M coverage)
    - "Automatic start of GPS on CLOUD_EVT_READY event after reset": disabled
    The trace looks exactly the same if "Automatic start of GPS on CLOUD_EVT_READY event after reset" is enabled.
    If the default network mode is set to NB-IoT it looks similar, only difference are the failed connection attempts and then the switch to fallback mode upon timeout.
    I left the system sitting for a while after the last log line showed up in LTE Link Monitor, but no other log was registered. The interesting part is that I can see events like button press and flip events show up in the nRF Cloud, but the LTE Link Monitor seems frozen.
    And as you can see below, there is no CLOUD_EVT_READY event.
    2020-07-23T15:33:12.087Z DEBUG modem << *** Booting Zephyr OS build v2.1.99-ncs1 ***
    2020-07-23T15:33:12.202Z DEBUG modem << Flash regionDomainPermissions
    2020-07-23T15:33:12.208Z DEBUG modem << 00 0x00000 0x08000 Securerwxl
    2020-07-23T15:33:12.210Z DEBUG modem << 01 0x08000 0x10000 Securerwxl
    2020-07-23T15:33:12.211Z DEBUG modem << 02 0x10000 0x18000 Securerwxl
    2020-07-23T15:33:12.213Z DEBUG modem << 03 0x18000 0x20000 Non-Securerwxl
    2020-07-23T15:33:12.215Z DEBUG modem << 04 0x20000 0x28000 Non-Securerwxl
    2020-07-23T15:33:12.216Z DEBUG modem << 05 0x28000 0x30000 Non-Securerwxl
    2020-07-23T15:33:12.218Z DEBUG modem << 06 0x30000 0x38000 Non-Securerwxl
    2020-07-23T15:33:12.220Z DEBUG modem << 07 0x38000 0x40000 Non-Securerwxl
    2020-07-23T15:33:12.221Z DEBUG modem << 08 0x40000 0x48000 Non-Securerwxl
    2020-07-23T15:33:12.223Z DEBUG modem << 09 0x48000 0x50000 Non-Securerwxl
    2020-07-23T15:33:12.224Z DEBUG modem << 10 0x50000 0x58000 Non-Securerwxl
    2020-07-23T15:33:12.226Z DEBUG modem << 11 0x58000 0x60000 Non-Securerwxl
    2020-07-23T15:33:12.227Z DEBUG modem << 12 0x60000 0x68000 Non-Securerwxl
    2020-07-23T15:33:12.238Z DEBUG modem << 13 0x68000 0x70000 Non-Securerwxl
    2020-07-23T15:33:12.241Z DEBUG modem << 14 0x70000 0x78000 Non-Securerwxl
    2020-07-23T15:33:12.242Z DEBUG modem << 15 0x78000 0x80000 Non-Securerwxl
    2020-07-23T15:33:12.243Z DEBUG modem << 16 0x80000 0x88000 Non-Securerwxl
    2020-07-23T15:33:12.245Z DEBUG modem << 17 0x88000 0x90000 Non-Securerwxl
    2020-07-23T15:33:12.246Z DEBUG modem << 18 0x90000 0x98000 Non-Securerwxl
    2020-07-23T15:33:12.247Z DEBUG modem << 19 0x98000 0xa0000 Non-Securerwxl
    2020-07-23T15:33:12.248Z DEBUG modem << 20 0xa0000 0xa8000 Non-Securerwxl
    2020-07-23T15:33:12.249Z DEBUG modem << 21 0xa8000 0xb0000 Non-Securerwxl
    2020-07-23T15:33:12.251Z DEBUG modem << 22 0xb0000 0xb8000 Non-Securerwxl
    2020-07-23T15:33:12.252Z DEBUG modem << 23 0xb8000 0xc0000 Non-Securerwxl
    2020-07-23T15:33:12.253Z DEBUG modem << 24 0xc0000 0xc8000 Non-Securerwxl
    2020-07-23T15:33:12.255Z DEBUG modem << 25 0xc8000 0xd0000 Non-Securerwxl
    2020-07-23T15:33:12.256Z DEBUG modem << 26 0xd0000 0xd8000 Non-Securerwxl
    2020-07-23T15:33:12.257Z DEBUG modem << 27 0xd8000 0xe0000 Non-Securerwxl
    2020-07-23T15:33:12.257Z DEBUG modem << 28 0xe0000 0xe8000 Non-Securerwxl
    2020-07-23T15:33:12.258Z DEBUG modem << 29 0xe8000 0xf0000 Non-Securerwxl
    2020-07-23T15:33:12.259Z DEBUG modem << 30 0xf0000 0xf8000 Non-Securerwxl
    2020-07-23T15:33:12.260Z DEBUG modem << 31 0xf8000 0x100000 Non-Securerwxl
    2020-07-23T15:33:12.261Z DEBUG modem << Non-secure callable region 0 placed in flash region 2 with size 32.
    2020-07-23T15:33:12.381Z DEBUG modem << SRAM regionDomainPermissions
    2020-07-23T15:33:12.387Z DEBUG modem << 00 0x00000 0x02000Securerwxl
    2020-07-23T15:33:12.388Z DEBUG modem << 01 0x02000 0x04000Securerwxl
    2020-07-23T15:33:12.389Z DEBUG modem << 02 0x04000 0x06000Securerwxl
    2020-07-23T15:33:12.561Z DEBUG modem << 03 0x06000 0x08000Securerwxl
    2020-07-23T15:33:12.565Z DEBUG modem << 04 0x08000 0x0a000Securerwxl
    2020-07-23T15:33:12.583Z DEBUG modem << 05 0x0a000 0x0c000Securerwxl
    2020-07-23T15:33:12.585Z DEBUG modem << 06 0x0c000 0x0e000Securerwxl
    2020-07-23T15:33:12.587Z DEBUG modem << 07 0x0e000 0x10000Securerwxl
    2020-07-23T15:33:12.589Z DEBUG modem << 08 0x10000 0x12000Non-Securerwxl
    2020-07-23T15:33:12.590Z DEBUG modem << 09 0x12000 0x14000Non-Securerwxl
    2020-07-23T15:33:12.591Z DEBUG modem << 10 0x14000 0x16000Non-Securerwxl
    2020-07-23T15:33:12.592Z DEBUG modem << 11 0x16000 0x18000Non-Securerwxl
    2020-07-23T15:33:12.594Z DEBUG modem << 12 0x18000 0x1a000Non-Securerwxl
    2020-07-23T15:33:12.596Z DEBUG modem << 13 0x1a000 0x1c000Non-Securerwxl
    2020-07-23T15:33:12.597Z DEBUG modem << 14 0x1c000 0x1e000Non-Securerwxl
    2020-07-23T15:33:12.598Z DEBUG modem << 15 0x1e000 0x20000Non-Securerwxl
    2020-07-23T15:33:12.599Z DEBUG modem << 16 0x20000 0x22000Non-Securerwxl
    2020-07-23T15:33:12.600Z DEBUG modem << 17 0x22000 0x24000Non-Securerwxl
    2020-07-23T15:33:12.601Z DEBUG modem << 18 0x24000 0x26000Non-Securerwxl
    2020-07-23T15:33:12.601Z DEBUG modem << 19 0x26000 0x28000Non-Securerwxl
    2020-07-23T15:33:12.602Z DEBUG modem << 20 0x28000 0x2a000Non-Securerwxl
    2020-07-23T15:33:12.602Z DEBUG modem << 21 0x2a000 0x2c000Non-Securerwxl
    2020-07-23T15:33:12.603Z DEBUG modem << 22 0x2c000 0x2e000Non-Securerwxl
    2020-07-23T15:33:12.603Z DEBUG modem << 23 0x2e000 0x30000Non-Securerwxl
    2020-07-23T15:33:12.606Z DEBUG modem << 24 0x30000 0x32000Non-Securerwxl
    2020-07-23T15:33:12.607Z DEBUG modem << 25 0x32000 0x34000Non-Securerwxl
    2020-07-23T15:33:12.608Z DEBUG modem << 26 0x34000 0x36000Non-Securerwxl
    2020-07-23T15:33:12.608Z DEBUG modem << 27 0x36000 0x38000Non-Securerwxl
    2020-07-23T15:33:12.610Z DEBUG modem << 28 0x38000 0x3a000Non-Securerwxl
    2020-07-23T15:33:12.610Z DEBUG modem << 29 0x3a000 0x3c000Non-Securerwxl
    2020-07-23T15:33:12.611Z DEBUG modem << 30 0x3c000 0x3e000Non-Securerwxl
    2020-07-23T15:33:12.612Z DEBUG modem << 31 0x3e000 0x40000Non-Securerwxl
    2020-07-23T15:33:12.613Z DEBUG modem << PeripheralDomainStatus
    2020-07-23T15:33:12.614Z DEBUG modem << 00 NRF_P0 Non-SecureOK
    2020-07-23T15:33:12.615Z DEBUG modem << 01 NRF_CLOCK Non-SecureOK
    2020-07-23T15:33:12.615Z DEBUG modem << 02 NRF_RTC0 Non-SecureOK
    2020-07-23T15:33:12.616Z DEBUG modem << 03 NRF_RTC1 Non-SecureOK
    2020-07-23T15:33:12.619Z DEBUG modem << 04 NRF_NVMC Non-SecureOK
    2020-07-23T15:33:12.620Z DEBUG modem << 05 NRF_UARTE1 Non-SecureOK
    2020-07-23T15:33:12.622Z DEBUG modem << 06 NRF_UARTE2 SecureSKIP
    2020-07-23T15:33:12.624Z DEBUG modem << 07 NRF_TWIM2 Non-SecureOK
    2020-07-23T15:33:12.625Z DEBUG modem << 08 NRF_SPIM3 Non-SecureOK
    2020-07-23T15:33:12.625Z DEBUG modem << 09 NRF_TIMER0 Non-SecureOK
    2020-07-23T15:33:12.626Z DEBUG modem << 10 NRF_TIMER1 Non-SecureOK
    2020-07-23T15:33:12.627Z DEBUG modem << 11 NRF_TIMER2 Non-SecureOK
    2020-07-23T15:33:12.628Z DEBUG modem << 12 NRF_SAADC Non-SecureOK
    2020-07-23T15:33:12.629Z DEBUG modem << 13 NRF_PWM0 Non-SecureOK
    2020-07-23T15:33:12.630Z DEBUG modem << 14 NRF_PWM1 Non-SecureOK
    2020-07-23T15:33:12.631Z DEBUG modem << 15 NRF_PWM2 Non-SecureOK
    2020-07-23T15:33:12.632Z DEBUG modem << 16 NRF_PWM3 Non-SecureOK
    2020-07-23T15:33:12.633Z DEBUG modem << 17 NRF_WDT Non-SecureOK
    2020-07-23T15:33:12.633Z DEBUG modem << 18 NRF_IPC Non-SecureOK
    2020-07-23T15:33:12.633Z DEBUG modem << 19 NRF_VMC Non-SecureOK
    2020-07-23T15:33:12.634Z DEBUG modem << 20 NRF_FPU Non-SecureOK
    2020-07-23T15:33:12.635Z DEBUG modem << 21 NRF_EGU1 Non-SecureOK
    2020-07-23T15:33:12.636Z DEBUG modem << 22 NRF_EGU2 Non-SecureOK
    2020-07-23T15:33:12.638Z DEBUG modem << 23 NRF_DPPIC Non-SecureOK
    2020-07-23T15:33:12.639Z DEBUG modem << 24 NRF_GPIOTE1 Non-SecureOK
    2020-07-23T15:33:12.653Z DEBUG modem << 25 NRF_REGULATORS Non-SecureOK
    2020-07-23T15:33:12.655Z DEBUG modem << SPM: NS image at 0x18200
    2020-07-23T15:33:12.656Z DEBUG modem << SPM: NS MSP at 0x2002e848
    2020-07-23T15:33:12.658Z DEBUG modem << SPM: NS reset vector at 0x1fd8d
    2020-07-23T15:33:12.659Z DEBUG modem << SPM: prepare to jump to Non-Secure image.
    2020-07-23T15:33:12.782Z DEBUG modem << *** Booting Zephyr OS build v2.1.9[00:00:00.194,702] [0m<inf> BH1749: BH1749 initialized[0m
    2020-07-23T15:33:12.783Z DEBUG modem << 9-ncs1 ***
    2020-07-23T15:33:12.823Z DEBUG modem << [00:00:00.216,094] [0m<inf> asset_tracker: Asset tracker started[0m
    2020-07-23T15:33:12.824Z DEBUG modem << [00:00:00.222,381] [0m<inf> watchdog: Watchdog timeout installed. Timeout: 10000[0m
    2020-07-23T15:33:12.825Z DEBUG modem << [00:00:00.230,041] [0m<inf> watchdog: Watchdog started[0m
    2020-07-23T15:33:12.832Z DEBUG modem << [00:00:00.235,443] [0m<inf> watchdog: Watchdog feed enabled. Timeout: 5000[0m
    2020-07-23T15:33:12.926Z DEBUG modem << [00:00:00.249,542] [0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100880619[0m
    2020-07-23T15:33:12.928Z DEBUG modem << [00:00:00.258,789] [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100880619/shadow[0m
    2020-07-23T15:33:12.929Z DEBUG modem << [00:00:00.270,477] [0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656100880619/shadow/get/accepted[0m
    2020-07-23T15:33:12.940Z DEBUG modem << [00:00:00.281,951] [0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100880619/shadow/get/rejected[0m
    2020-07-23T15:33:12.941Z DEBUG modem << [00:00:00.294,525] [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100880619/shadow/update/delta[0m
    2020-07-23T15:33:12.942Z DEBUG modem << [00:00:00.307,434] [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100880619/shadow/update[0m
    2020-07-23T15:33:12.943Z DEBUG modem << [00:00:00.319,305] [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100880619/shadow/get[0m
    2020-07-23T15:33:12.944Z DEBUG modem << [00:00:00.331,481] [0m<inf> asset_tracker: Connecting to LTE network. [0m
    2020-07-23T15:33:12.945Z DEBUG modem << [00:00:00.338,226] [0m<inf> asset_tracker: This may take several minutes.[0m
    2020-07-23T15:33:12.947Z DEBUG modem << [00:00:00.353,607] [0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=1,0,1,0[0m
    2020-07-23T15:33:14.212Z DEBUG modem << +CEREG: 2,"7F58","0642A00A",7,0,0,"11100000","11100000"
    2020-07-23T15:33:14.226Z DEBUG modem << [00:00:01.625,335] [0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 2[0m
    2020-07-23T15:33:16.031Z DEBUG modem << +CEREG: 5,"7F58","0642A00A",7,,,"11100000","11100000"
    2020-07-23T15:33:16.043Z DEBUG modem >> AT+COPS=3,2
    2020-07-23T15:33:16.045Z DEBUG modem << [00:00:03.444,366] [0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 5[0m
    2020-07-23T15:33:16.047Z DEBUG modem << [00:00:03.452,667] [0m<inf> asset_tracker: Connected to LTE network[0m
    2020-07-23T15:33:16.050Z DEBUG modem << OK
    2020-07-23T15:33:16.053Z DEBUG modem >> AT+COPS?
    2020-07-23T15:33:16.062Z DEBUG modem << +COPS: 0,2,"302720",7
    2020-07-23T15:33:16.063Z DEBUG modem << OK
    2020-07-23T15:33:16.069Z DEBUG modem >> AT%XCBAND
    2020-07-23T15:33:16.080Z DEBUG modem << %XCBAND: 12
    2020-07-23T15:33:16.082Z DEBUG modem << OK
    2020-07-23T15:33:16.094Z DEBUG modem >> AT+CGDCONT?
    2020-07-23T15:33:16.105Z DEBUG modem << +CGDCONT: 0,"IP","ibasis.iot","10.165.49.39",0,0
    2020-07-23T15:33:16.107Z DEBUG modem << OK
    2020-07-23T15:33:16.118Z DEBUG modem >> AT+CGACT?
    2020-07-23T15:33:16.126Z DEBUG modem << +CGACT: 0,1
    2020-07-23T15:33:16.127Z DEBUG modem << OK
    2020-07-23T15:33:17.007Z DEBUG modem << [00:00:04.418,334] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 0x8c81d136[0m
    2020-07-23T15:33:24.280Z DEBUG modem << [00:00:11.633,178] [0m<inf> aws_jobs: Subscribe: $aws/things/nrf-352656100880619/jobs/notify-next[0m
    2020-07-23T15:33:24.281Z DEBUG modem << [00:00:11.643,554] [0m<inf> aws_jobs: Subscribe: $aws/things/nrf-352656100880619/jobs/$next/get/#[0m
    2020-07-23T15:33:24.282Z DEBUG modem << [00:00:11.653,503] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK[0m
    2020-07-23T15:33:24.294Z DEBUG modem << [00:00:11.661,651] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2[0m
    2020-07-23T15:33:24.298Z DEBUG modem << [00:00:11.669,372] [0m<dbg> nrf_cloud.event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED[0m
    2020-07-23T15:33:24.299Z DEBUG modem << [00:00:11.677,490] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTED[0m
    2020-07-23T15:33:24.300Z DEBUG modem << [00:00:11.683,593] [0m<dbg> nrf_cloud_transport.nct_cc_connect: nct_cc_connect[0m
    2020-07-23T15:33:24.303Z DEBUG modem << [00:00:11.691,741] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 3[0m
    2020-07-23T15:33:24.559Z DEBUG modem << [00:00:11.955,017] [0m<inf> aws_fota: subscribed to notify-next topic[0m
    2020-07-23T15:33:24.561Z DEBUG modem << [00:00:11.961,822] [0m<inf> aws_jobs: Publish topic: $aws/things/nrf-352656100880619/jobs/$next/get[0m
    2020-07-23T15:33:24.562Z DEBUG modem << [00:00:11.971,099] [0m<inf> aws_jobs: Publish payload {"clientToken": ""}[0m
    2020-07-23T15:33:24.865Z DEBUG modem << [00:00:12.275,054] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2114 result = 0[0m
    2020-07-23T15:33:24.933Z DEBUG modem << [00:00:12.316,528] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 1234 result = 0[0m
    2020-07-23T15:33:24.933Z DEBUG modem << [00:00:12.326,507] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4[0m
    2020-07-23T15:33:24.935Z DEBUG modem << [00:00:12.334,197] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0[0m
    2020-07-23T15:33:24.937Z DEBUG modem << [00:00:12.344,512] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
    2020-07-23T15:33:25.184Z DEBUG modem << [00:00:12.593,048] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 64819 result = 0[0m
    2020-07-23T15:33:25.226Z DEBUG modem << [00:00:12.633,666] [0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656100880619/jobs/$next/get/accepted[0m
    2020-07-23T15:33:25.246Z DEBUG modem << [00:00:12.645,111] [0m<inf> aws_fota: Checking for an available job[0m
    Thanks in advance
  • I was finally able to test asset_tracker application (NCS v1.3.0) regarding the fallback issue, and I did not have any issues. Do remember that the default time before it uses fallback is 10 minutes (600 sec). This can be overrun by adding CONFIG_LTE_NETWORK_TIMEOUT=30 (seconds) in prj.conf. See min below:
    # Copyright (c) 2019 Nordic Semiconductor ASA
    # SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    # General config
    CONFIG_NEWLIB_LIBC=y
    CONFIG_ASSERT=y
    CONFIG_REBOOT=y
    CONFIG_LOG=y
    CONFIG_LOG_IMMEDIATE=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    # LTE link control
    CONFIG_POWER_OPTIMIZATION_ENABLE=n
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=n
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=y
    CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
    CONFIG_LTE_LEGACY_PCO_MODE=n
    CONFIG_LTE_PSM_REQ_RPTAU="00000110"
    CONFIG_LTE_PSM_REQ_RAT="00000010"
    #Fallback timer
    # Modem info
    CONFIG_MODEM_INFO=y
    # BSD library
    CONFIG_BSD_LIBRARY=y
    CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
    # nRF Cloud
    CONFIG_CLOUD_API=y
    CONFIG_NRF_CLOUD=y
    CONFIG_NRF_CLOUD_LOG_LEVEL_DBG=y
    CONFIG_NRF_CLOUD_AGPS=y
    CONFIG_NRF_CLOUD_CONNECTION_POLL_THREAD=y
    CONFIG_NRF_CLOUD_NONBLOCKING_SEND=y
    # Needed for the cloud codec
    CONFIG_CJSON_LIB=y
    # Shorter to prevent NAT timeouts
    CONFIG_MQTT_KEEPALIVE=120
    # Don't resubscribe to topics if broker remembers them
    CONFIG_CLOUD_PERSISTENT_SESSIONS=y
    # Sensors
    CONFIG_ACCEL_USE_SIM=y
    CONFIG_TEMP_USE_SIM=y
    CONFIG_CLOUD_BUTTON=n
    # GPS
    CONFIG_NRF9160_GPS=y
    # CONFIG_GPS_USE_SIM=y
    CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y
    CONFIG_GPS_USE_EXTERNAL=y
    CONFIG_GPS_DEV_NAME="NRF9160_GPS"
    CONFIG_GPS_CONTROL_PSM_ENABLE_ON_START=y
    CONFIG_GPS_CONTROL_FIRST_FIX_CHECK_DELAY=10
    CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL=30
    CONFIG_GPS_CONTROL_FIX_TRY_TIME=360
    CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP=n
    # Library for buttons and LEDs
    CONFIG_DK_LIBRARY=y
    CONFIG_DK_LIBRARY_INVERT_LEDS=n
    # Console
    CONFIG_CONSOLE_SUBSYS=y
    CONFIG_CONSOLE_HANDLER=y
    CONFIG_CONSOLE_GETCHAR=y
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_MAIN_STACK_SIZE=8192
    CONFIG_HW_STACK_PROTECTION=y
    # MCUBOOT
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # Flash
    CONFIG_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # AWS FOTA
    CONFIG_AWS_FOTA=y
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_AWS_FOTA_LOG_LEVEL_DBG=y
    CONFIG_AWS_JOBS_LOG_LEVEL_DBG=y
    CONFIG_DFU_TARGET=y
    # Download client (needed by AWS FOTA)
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    # Fatal error
    CONFIG_RESET_ON_FATAL_ERROR=n
    CONFIG_WATCHDOG=y
    I have not edited any else but network mode and network timeout.
    Below is the output from LTE Link Monitor:
    2020-07-24T09:36:25.029Z INFO Application data folder: C:\Users\oysa\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2020-07-24T09:36:25.078Z DEBUG App pc-nrfconnect-linkmonitor v1.1.3 official
    2020-07-24T09:36:25.079Z DEBUG App path: C:\Users\oysa\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2020-07-24T09:36:25.079Z DEBUG nRFConnect 3.4.1 is supported by the app (^3.2.0)
    2020-07-24T09:36:25.079Z DEBUG nRFConnect path: C:\Users\oysa\AppData\Local\Programs\nrfconnect\resources\app.asar
    2020-07-24T09:36:25.079Z DEBUG HomeDir: C:\Users\oysa
    2020-07-24T09:36:25.079Z DEBUG TmpDir: C:\Users\oysa\AppData\Local\Temp
    2020-07-24T09:36:25.086Z VERBOSE Could not fetch serial number for serial port at COM3
    2020-07-24T09:36:26.633Z INFO Modem port is opened
    2020-07-24T09:36:26.645Z DEBUG modem >> AT+CFUN?
    2020-07-24T09:36:29.654Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
    2020-07-24T09:36:29.673Z DEBUG modem << [00:00:00.003,204] [0m<inf> mcuboot: Starting bootloader[0m
    2020-07-24T09:36:29.677Z DEBUG modem << [00:00:00.008,911] [0m<inf> mcuboot: Primary image: magic=bad, swap_type=0x0, copy_done=0x2, image_ok=0x2[0m
    2020-07-24T09:36:29.679Z DEBUG modem << [00:00:00.018,005] [0m<inf> mcuboot: Boot source: none[0m
    2020-07-24T09:36:29.682Z DEBUG modem << [00:00:00.023,010] [0m<inf> mcuboot: Swap type: none[0m
    2020-07-24T09:36:30.016Z DEBUG modem << [00:00:00.335,845] [0m<inf> mcuboot: Bootloader chainload address offset: 0x10000[0m
    2020-07-24T09:36:30.024Z DEBUG modem << [00:00:00.342,987] [0m<inf> mcuboot: Jumping to the first image slot[0m
    2020-07-24T09:36:30.031Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
    2020-07-24T09:36:30.032Z DEBUG modem << Flash regionsDomainPermissions
    2020-07-24T09:36:30.044Z DEBUG modem << 00 02 0x00000 0x18000 Securerwxl
    2020-07-24T09:36:30.048Z DEBUG modem << 03 31 0x18000 0x100000 Non-Securerwxl
    2020-07-24T09:36:30.051Z DEBUG modem << Non-secure callable region 0 placed in flash region 2 with size 32.
    2020-07-24T09:36:30.212Z DEBUG modem << SRAM regionDomainPermissions
    2020-07-24T09:36:30.219Z DEBUG modem << 00 07 0x00000 0x10000 Securerwxl
    2020-07-24T09:36:30.222Z DEBUG modem << 08 31 0x10000 0x40000 Non-Securerwxl
    2020-07-24T09:36:30.224Z DEBUG modem << PeripheralDomainStatus
    2020-07-24T09:36:30.227Z DEBUG modem << 00 NRF_P0               Non-SecureOK
    2020-07-24T09:36:30.230Z DEBUG modem << 01 NRF_CLOCK            Non-SecureOK
    2020-07-24T09:36:30.233Z DEBUG modem << 02 NRF_RTC0             Non-SecureOK
    2020-07-24T09:36:30.243Z DEBUG modem << 03 NRF_RTC1             Non-SecureOK
    2020-07-24T09:36:30.246Z DEBUG modem << 04 NRF_NVMC             Non-SecureOK
    2020-07-24T09:36:30.249Z DEBUG modem << 05 NRF_UARTE1           Non-SecureOK
    2020-07-24T09:36:30.252Z DEBUG modem << 06 NRF_UARTE2           SecureSKIP
    2020-07-24T09:36:30.260Z DEBUG modem << 07 NRF_TWIM2            Non-SecureOK
    2020-07-24T09:36:30.263Z DEBUG modem << 08 NRF_SPIM3            Non-SecureOK
    2020-07-24T09:36:30.265Z DEBUG modem << 09 NRF_TIMER0           Non-SecureOK
    2020-07-24T09:36:30.268Z DEBUG modem << 10 NRF_TIMER1           Non-SecureOK
    2020-07-24T09:36:30.271Z DEBUG modem << 11 NRF_TIMER2           Non-SecureOK
    2020-07-24T09:36:30.273Z DEBUG modem << 12 NRF_SAADC            Non-SecureOK
    2020-07-24T09:36:30.281Z DEBUG modem << 13 NRF_PWM0             Non-SecureOK
    2020-07-24T09:36:30.283Z DEBUG modem << 14 NRF_PWM1             Non-SecureOK
    2020-07-24T09:36:30.287Z DEBUG modem << 15 NRF_PWM2             Non-SecureOK
    2020-07-24T09:36:30.290Z DEBUG modem << 16 NRF_PWM3             Non-SecureOK
    2020-07-24T09:36:30.292Z DEBUG modem << 17 NRF_WDT              Non-SecureOK
    2020-07-24T09:36:30.293Z DEBUG modem << 18 NRF_IPC              Non-SecureOK
    2020-07-24T09:36:30.299Z DEBUG modem << 19 NRF_VMC              Non-SecureOK
    2020-07-24T09:36:30.301Z DEBUG modem << 20 NRF_FPU              Non-SecureOK
    2020-07-24T09:36:30.302Z DEBUG modem << 21 NRF_EGU1             Non-SecureOK
    2020-07-24T09:36:30.303Z DEBUG modem << 22 NRF_EGU2             Non-SecureOK
    2020-07-24T09:36:30.312Z DEBUG modem << 23 NRF_DPPIC            Non-SecureOK
    2020-07-24T09:36:30.316Z DEBUG modem << 24 NRF_GPIOTE1          Non-SecureOK
    2020-07-24T09:36:30.322Z DEBUG modem << 25 NRF_REGULATORS       Non-SecureOK
    2020-07-24T09:36:30.325Z DEBUG modem << SPM: NS image at 0x1c200
    2020-07-24T09:36:30.326Z DEBUG modem << SPM: NS MSP at 0x20030ff8
    2020-07-24T09:36:30.334Z DEBUG modem << SPM: NS reset vector at 0x25511
    2020-07-24T09:36:30.336Z DEBUG modem << SPM: prepare to jump to Non-Secure image.
    2020-07-24T09:36:30.529Z DEBUG modem << *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
    2020-07-24T09:36:30.541Z DEBUG modem << [00:00:00.203,521] [0m<dbg> nrf9160_gps.setup: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577[0m
    2020-07-24T09:36:30.547Z DEBUG modem << [00:00:00.212,371] [0m<dbg> nrf9160_gps.setup: COEX0 set: AT%XCOEX0=1,1,1570,1580[0m
    2020-07-24T09:36:30.559Z DEBUG modem << [00:00:00.220,062] [0m<inf> asset_tracker: Asset tracker started[0m
    2020-07-24T09:36:30.566Z DEBUG modem << [00:00:00.226,287] [0m<inf> watchdog: Watchdog timeout installed. Timeout: 10000[0m
    2020-07-24T09:36:30.569Z DEBUG modem << [00:00:00.233,856] [0m<inf> watchdog: Watchdog started[0m
    2020-07-24T09:36:30.581Z DEBUG modem << [00:00:00.239,196] [0m<inf> watchdog: Watchdog feed enabled. Timeout: 5000[0m
    2020-07-24T09:36:30.591Z DEBUG modem << [00:00:00.253,753] [0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656102628123[0m
    2020-07-24T09:36:30.601Z DEBUG modem << [00:00:00.262,908] [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656102628123/shadow[0m
    2020-07-24T09:36:30.619Z DEBUG modem << [00:00:00.274,475] [0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656102628123/shadow/get/accepted[0m
    2020-07-24T09:36:30.625Z DEBUG modem << [00:00:00.285,888] [0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656102628123/shadow/get/rejected[0m
    2020-07-24T09:36:30.645Z DEBUG modem << [00:00:00.298,309] [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656102628123/shadow/update/delta[0m
    2020-07-24T09:36:30.650Z DEBUG modem << [00:00:00.311,096] [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656102628123/shadow/update[0m
    2020-07-24T09:36:30.662Z DEBUG modem << [00:00:00.322,845] [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656102628123/shadow/get[0m
    2020-07-24T09:36:30.674Z DEBUG modem << [00:00:00.334,899] [0m<inf> asset_tracker: Connecting to LTE network.[0m
    2020-07-24T09:36:30.677Z DEBUG modem << [00:00:00.341,522] [0m<inf> asset_tracker: This may take several minutes.[0m
    2020-07-24T09:36:30.691Z DEBUG modem << [00:00:00.348,541] [0m<dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0[0m
    2020-07-24T09:36:30.711Z DEBUG modem << [00:00:00.368,377] [0m<dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=0,1,1,0[0m
    2020-07-24T09:36:53.935Z DEBUG modem << +CEREG: 2,"9DD1","014A0303",9,0,0,"11100000","11100000"
    2020-07-24T09:36:53.950Z DEBUG modem << [00:00:23.609,283] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"9DD1","014A0303",9,0,0,"11100000","11100000"
    2020-07-24T09:36:53.951Z DEBUG modem << [0m
    2020-07-24T09:36:53.954Z DEBUG modem << [00:00:23.621,032] [0m<dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    2020-07-24T09:36:53.955Z DEBUG modem << [0m
    2020-07-24T09:36:54.269Z DEBUG modem << +CSCON: 1
    2020-07-24T09:36:54.273Z DEBUG modem << [00:00:23.941,467] [0m<dbg> lte_lc.at_handler: +CSCON notification[0m
    2020-07-24T09:36:55.243Z DEBUG modem << +CEREG: 4,"9DD1","014A0303",9,0,15,"11100000","11100000"
    2020-07-24T09:36:55.254Z DEBUG modem << [00:00:24.916,961] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 4,"9DD1","014A0303",9,0,15,"11100000","11100000"
    2020-07-24T09:36:55.256Z DEBUG modem << [0m
    2020-07-24T09:36:55.262Z DEBUG modem << [00:00:24.928,771] [0m<dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    2020-07-24T09:36:55.263Z DEBUG modem << [0m
    2020-07-24T09:36:55.292Z DEBUG modem << +CSCON: 0
    2020-07-24T09:36:55.297Z DEBUG modem << [00:00:24.965,637] [0m<dbg> lte_lc.at_handler: +CSCON notification[0m
    2020-07-24T09:36:55.514Z DEBUG modem << +CEREG: 4,"FFFE","FFFFFFFF",9,0,15,"11100000","11100000"
    2020-07-24T09:36:55.527Z DEBUG modem << [00:00:25.188,964] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 4,"FFFE","FFFFFFFF",9,0,15,"11100000","11100000"
    2020-07-24T09:36:55.529Z DEBUG modem << [0m
    2020-07-24T09:36:55.534Z DEBUG modem << [00:00:25.200,775] [0m<dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    2020-07-24T09:36:55.539Z DEBUG modem << [0m
    2020-07-24T09:37:00.752Z DEBUG modem << [00:00:30.419,860] [0m<inf> lte_lc: Network connection attempt timed out[0m
    2020-07-24T09:37:00.775Z DEBUG modem << +CEREG: 0,"FFFE","FFFFFFFF",9,0,15,"11100000","11100000"
    2020-07-24T09:37:00.786Z DEBUG modem << [00:00:30.449,157] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 0,"FFFE","FFFFFFFF",9,0,15,"11100000","11100000"
    2020-07-24T09:37:00.787Z DEBUG modem << [0m
    2020-07-24T09:37:00.793Z DEBUG modem << [00:00:30.460,998] [0m<dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    2020-07-24T09:37:00.795Z DEBUG modem << [0m
    2020-07-24T09:37:00.801Z DEBUG modem << [00:00:30.469,024] [0m<inf> lte_lc: Using fallback network mode[0m
    2020-07-24T09:37:00.816Z DEBUG modem << [00:00:30.475,158] [0m<dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,1,0[0m
    2020-07-24T09:37:08.497Z DEBUG modem << +CEREG: 2,"76C1","014ACE00",7,0,15,"11100000","11100000"
    2020-07-24T09:37:08.507Z DEBUG modem << [00:00:38.171,691] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"76C1","014ACE00",7,0,15,"11100000","11100000"
    2020-07-24T09:37:08.509Z DEBUG modem << [0m
    2020-07-24T09:37:08.516Z DEBUG modem << [00:00:38.183,502] [0m<dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    2020-07-24T09:37:08.518Z DEBUG modem << [0m
    2020-07-24T09:37:08.540Z DEBUG modem << +CSCON: 1
    2020-07-24T09:37:08.547Z DEBUG modem << [00:00:38.214,874] [0m<dbg> lte_lc.at_handler: +CSCON notification[0m
    2020-07-24T09:37:09.428Z DEBUG modem << +CEREG: 1,"76C1","014ACE00",7,,,"11100000","00001111"
    2020-07-24T09:37:09.438Z DEBUG modem >> AT+COPS=3,2
    2020-07-24T09:37:09.441Z DEBUG modem << [00:00:39.102,844] [0m<dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 1,"76C1","014ACE00",7,,,"11100000","00001111"
    2020-07-24T09:37:09.442Z DEBUG modem << [0m
    2020-07-24T09:37:09.447Z DEBUG modem << [00:00:39.114,410] [0m<dbg> lte_lc.parse_psm_cfg: TAU: 9000 sec, active time: -1 sec
    2020-07-24T09:37:09.449Z DEBUG modem << [0m
    2020-07-24T09:37:09.457Z DEBUG modem << [00:00:39.122,589] [0m<inf> asset_tracker: Connected to LTE network.[0m
    2020-07-24T09:37:09.462Z DEBUG modem << [00:00:39.129,180] [0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m
    2020-07-24T09:37:09.473Z DEBUG modem << [00:00:39.136,627] [0m<inf> asset_tracker: Cloud connection request sent.[0m
    2020-07-24T09:37:09.477Z DEBUG modem << [00:00:39.143,585] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
    2020-07-24T09:37:09.490Z DEBUG modem << [00:00:39.152,343] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
    2020-07-24T09:37:09.495Z DEBUG modem << OK
    2020-07-24T09:37:09.499Z DEBUG modem >> AT+COPS?
    2020-07-24T09:37:09.510Z DEBUG modem << +COPS: 0,2,"24201",7
    2020-07-24T09:37:09.512Z DEBUG modem << OK
    2020-07-24T09:37:09.526Z DEBUG modem >> AT%XCBAND
    2020-07-24T09:37:09.531Z DEBUG modem << %XCBAND: 20
    2020-07-24T09:37:09.541Z DEBUG modem << OK
    2020-07-24T09:37:09.546Z DEBUG modem >> AT+CGDCONT?
    2020-07-24T09:37:09.558Z DEBUG modem << +CGDCONT: 0,"IPV4V6","telenor.iot","10.241.98.34 2A02:2121:0208:1741:0000:0036:57B8:C401",0,0
    2020-07-24T09:37:09.561Z DEBUG modem << OK
    2020-07-24T09:37:09.565Z DEBUG modem >> AT+CGACT?
    2020-07-24T09:37:09.577Z DEBUG modem << +CGACT: 0,1
    2020-07-24T09:37:09.580Z DEBUG modem << OK
    2020-07-24T09:37:09.592Z DEBUG modem << [00:00:39.255,645] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 52.21.78.210[0m
    2020-07-24T09:37:09.599Z DEBUG modem << [00:00:39.263,854] [0m<dbg> nrf_cloud_transport.nct_mqtt_connect: mqtt_connect requesting persistent session[0m
    2020-07-24T09:37:13.841Z DEBUG modem << [00:00:43.509,185] [0m<inf> nrf_cloud_transport: Using non-blocking socket[0m
    2020-07-24T09:37:13.849Z DEBUG modem << [00:00:43.516,265] [0m<dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.[0m
    2020-07-24T09:37:14.113Z DEBUG modem << [00:00:43.777,740] [0m<dbg> aws_fota.aws_fota_mqtt_evt_handler: Previous session valid; skipping FOTA subscriptions[0m
    2020-07-24T09:37:14.123Z DEBUG modem << [00:00:43.788,391] [0m<inf> aws_fota: Created notify_next_topic $aws/things/nrf-352656102628123/jobs/notify-next[0m
    2020-07-24T09:37:14.138Z DEBUG modem << [00:00:43.798,797] [0m<inf> aws_fota: Created get_topic $aws/things/nrf-352656102628123/jobs/$next/get/#[0m
    2020-07-24T09:37:14.141Z DEBUG modem << [00:00:43.808,441] [0m<inf> aws_fota: previously subscribed to notify-next topic[0m
    2020-07-24T09:37:14.150Z DEBUG modem << [00:00:43.816,101] [0m<inf> aws_jobs: Publish topic: $aws/things/nrf-352656102628123/jobs/$next/get[0m
    2020-07-24T09:37:14.160Z DEBUG modem << [00:00:43.825,317] [0m<inf> aws_jobs: Publish payload {"clientToken": ""}[0m
    2020-07-24T09:37:14.167Z DEBUG modem << [00:00:43.833,343] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK: result 0[0m
    2020-07-24T09:37:14.176Z DEBUG modem << [00:00:43.842,315] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2[0m
    2020-07-24T09:37:14.183Z DEBUG modem << [00:00:43.849,975] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED[0m
    2020-07-24T09:37:14.191Z DEBUG modem << [00:00:43.858,428] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTED[0m
    2020-07-24T09:37:14.196Z DEBUG modem << [00:00:43.864,440] [0m<inf> asset_tracker: Persistent Sessions = 1[0m
    2020-07-24T09:37:14.207Z DEBUG modem << [00:00:43.870,819] [0m<dbg> nrf_cloud_fsm.connection_handler: Previous session valid; skipping nct_cc_connect()[0m
    2020-07-24T09:37:14.214Z DEBUG modem << [00:00:43.881,072] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4[0m
    2020-07-24T09:37:14.224Z DEBUG modem << [00:00:43.888,732] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0[0m
    2020-07-24T09:37:14.231Z DEBUG modem << [00:00:43.899,230] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
    2020-07-24T09:37:14.322Z DEBUG modem << [00:00:43.986,633] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 60040 result = 0[0m
    2020-07-24T09:37:14.357Z DEBUG modem << [00:00:44.020,416] [0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656102628123/jobs/$next/get/accepted[0m
    2020-07-24T09:37:14.363Z DEBUG modem << [00:00:44.031,768] [0m<inf> aws_fota: Checking for an available job[0m
    2020-07-24T09:37:14.374Z DEBUG modem << [00:00:44.038,330] [0m<dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1595583434}[0m
    2020-07-24T09:37:14.380Z DEBUG modem << [00:00:44.048,400] [0m<dbg> aws_fota.get_job_execution: Got only one field[0m
    2020-07-24T09:37:14.390Z DEBUG modem << [00:00:44.055,450] [0m<inf> aws_fota: No queued jobs for this device[0m
    2020-07-24T09:37:14.481Z DEBUG modem << [00:00:44.145,751] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5678 result = 0[0m
    2020-07-24T09:37:14.488Z DEBUG modem << [00:00:44.155,670] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
    2020-07-24T09:37:14.751Z DEBUG modem << [00:00:44.415,863] [0m<dbg> aws_fota.on_publish_evt: Received topic: nrf-352656102628123/shadow/get/accepted[0m
    2020-07-24T09:37:14.764Z DEBUG modem << [00:00:44.425,842] [0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: nrf-352656102628123/shadow/get/accepted[0m
    2020-07-24T09:37:14.774Z DEBUG modem << [00:00:44.438,842] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 0 len = 50[0m
    2020-07-24T09:37:14.792Z DEBUG modem << [00:00:44.450,164] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 1 opcode = 1 len = 136[0m
    2020-07-24T09:37:14.794Z DEBUG modem << [00:00:44.461,578] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 6[0m
    2020-07-24T09:37:14.807Z DEBUG modem << [00:00:44.469,238] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATION_REQUEST[0m
    2020-07-24T09:37:14.809Z DEBUG modem << [00:00:44.478,118] [0m<inf> asset_tracker: CLOUD_EVT_PAIR_REQUEST[0m
    2020-07-24T09:37:14.816Z DEBUG modem << [00:00:44.484,375] [0m<inf> asset_tracker: Add device to cloud account.[0m
    2020-07-24T09:37:14.824Z DEBUG modem << [00:00:44.491,180] [0m<inf> asset_tracker: Waiting for cloud association...[0m
    2020-07-24T09:37:15.203Z DEBUG modem << [00:00:44.868,804] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0[0m
    2020-07-24T09:38:08.022Z DEBUG modem << [00:01:37.687,591] [0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656102628123/shadow/update/delta[0m
    2020-07-24T09:38:08.036Z DEBUG modem << [00:01:37.698,638] [0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: $aws/things/nrf-352656102628123/shadow/update/delta[0m
    2020-07-24T09:38:08.045Z DEBUG modem << [00:01:37.712,677] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 1 len = 502[0m
    2020-07-24T09:38:08.061Z DEBUG modem << [00:01:37.729,919] [0m<dbg> nrf_cloud_transport.nct_dc_endpoint_set: nct_dc_endpoint_set[0m
    2020-07-24T09:38:08.077Z DEBUG modem << [00:01:37.738,372] [0m<dbg> nrf_cloud_transport.nct_dc_endpoint_get: nct_dc_endpoint_get[0m
    2020-07-24T09:38:08.082Z DEBUG modem << [00:01:37.748,016] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 7890 opcode = 1 len = 329[0m
    2020-07-24T09:38:08.091Z DEBUG modem << [00:01:37.759,735] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 7[0m
    2020-07-24T09:38:08.098Z DEBUG modem << [00:01:37.767,425] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATED[0m
    2020-07-24T09:38:08.111Z DEBUG modem << [00:01:37.775,512] [0m<inf> asset_tracker: CLOUD_EVT_PAIR_DONE[0m
    2020-07-24T09:38:08.113Z DEBUG modem << [00:01:37.781,524] [0m<inf> asset_tracker: Device associated with cloud.[0m
    2020-07-24T09:38:08.124Z DEBUG modem << [00:01:37.788,421] [0m<inf> asset_tracker: Reconnecting for cloud policy to take effect.[0m
    2020-07-24T09:38:08.126Z DEBUG modem << [00:01:37.796,691] [0m<inf> asset_tracker: Disconnecting from cloud...[0m
    2020-07-24T09:38:08.134Z DEBUG modem << [00:01:37.803,405] [0m<dbg> nrf_cloud_transport.nct_disconnect: nct_disconnect[0m
    2020-07-24T09:38:08.150Z DEBUG modem << [00:01:37.813,659] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = 0[0m
    2020-07-24T09:38:08.154Z DEBUG modem << [00:01:37.823,089] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 1[0m
    2020-07-24T09:38:08.162Z DEBUG modem << [00:01:37.830,749] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED[0m
    2020-07-24T09:38:08.670Z DEBUG modem << [00:01:38.339,660] [0m<dbg> nrf_cloud.nrf_cloud_run: Expected disconnect event.[0m
    2020-07-24T09:38:08.679Z DEBUG modem << [00:01:38.347,229] [0m<inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 0[0m
    2020-07-24T09:38:08.684Z DEBUG modem << [00:01:38.353,790] [0m<inf> asset_tracker: Attempting reconnect in 10 seconds...[0m
    2020-07-24T09:38:18.692Z DEBUG modem << [00:01:48.361,450] [0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m
    2020-07-24T09:38:18.699Z DEBUG modem << [00:01:48.368,896] [0m<inf> asset_tracker: Cloud connection request sent.[0m
    2020-07-24T09:38:18.706Z DEBUG modem << [00:01:48.375,854] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
    2020-07-24T09:38:18.713Z DEBUG modem << [00:01:48.384,521] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
    2020-07-24T09:38:18.778Z DEBUG modem << [00:01:48.448,120] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 54.88.128.192[0m
    2020-07-24T09:38:22.711Z DEBUG modem << [00:01:52.381,866] [0m<inf> nrf_cloud_transport: Using non-blocking socket[0m
    2020-07-24T09:38:22.719Z DEBUG modem << [00:01:52.388,946] [0m<dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.[0m
    2020-07-24T09:38:23.022Z DEBUG modem << [00:01:52.689,605] [0m<dbg> aws_fota.aws_fota_mqtt_evt_handler: Previous session valid; skipping FOTA subscriptions[0m
    2020-07-24T09:38:23.034Z DEBUG modem << [00:01:52.700,256] [0m<inf> aws_fota: Created notify_next_topic $aws/things/nrf-352656102628123/jobs/notify-next[0m
    2020-07-24T09:38:23.042Z DEBUG modem << [00:01:52.710,662] [0m<inf> aws_fota: Created get_topic $aws/things/nrf-352656102628123/jobs/$next/get/#[0m
    2020-07-24T09:38:23.050Z DEBUG modem << [00:01:52.720,336] [0m<inf> aws_fota: previously subscribed to notify-next topic[0m
    2020-07-24T09:38:23.060Z DEBUG modem << [00:01:52.727,966] [0m<inf> aws_jobs: Publish topic: $aws/things/nrf-352656102628123/jobs/$next/get[0m
    2020-07-24T09:38:23.066Z DEBUG modem << [00:01:52.737,182] [0m<inf> aws_jobs: Publish payload {"clientToken": ""}[0m
    2020-07-24T09:38:23.076Z DEBUG modem << [00:01:52.745,300] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK: result 0[0m
    2020-07-24T09:38:23.092Z DEBUG modem << [00:01:52.754,272] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2[0m
    2020-07-24T09:38:23.094Z DEBUG modem << [00:01:52.761,932] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED[0m
    2020-07-24T09:38:23.099Z DEBUG modem << [00:01:52.770,355] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTED[0m
    2020-07-24T09:38:23.109Z DEBUG modem << [00:01:52.776,397] [0m<inf> asset_tracker: Persistent Sessions = 1[0m
    2020-07-24T09:38:23.115Z DEBUG modem << [00:01:52.782,775] [0m<dbg> nrf_cloud_fsm.connection_handler: Previous session valid; skipping nct_cc_connect()[0m
    2020-07-24T09:38:23.127Z DEBUG modem << [00:01:52.793,029] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4[0m
    2020-07-24T09:38:23.132Z DEBUG modem << [00:01:52.800,720] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0[0m
    2020-07-24T09:38:23.143Z DEBUG modem << [00:01:52.811,096] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
    2020-07-24T09:38:23.278Z DEBUG modem << [00:01:52.946,563] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 24384 result = 0[0m
    2020-07-24T09:38:23.290Z DEBUG modem << [00:01:52.956,939] [0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656102628123/jobs/$next/get/accepted[0m
    2020-07-24T09:38:23.296Z DEBUG modem << [00:01:52.968,292] [0m<inf> aws_fota: Checking for an available job[0m
    2020-07-24T09:38:23.307Z DEBUG modem << [00:01:52.974,853] [0m<dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1595583503}[0m
    2020-07-24T09:38:23.313Z DEBUG modem << [00:01:52.984,954] [0m<dbg> aws_fota.get_job_execution: Got only one field[0m
    2020-07-24T09:38:23.324Z DEBUG modem << [00:01:52.992,004] [0m<inf> aws_fota: No queued jobs for this device[0m
    2020-07-24T09:38:23.433Z DEBUG modem << [00:01:53.101,654] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5678 result = 0[0m
    2020-07-24T09:38:23.441Z DEBUG modem << [00:01:53.111,572] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
    2020-07-24T09:38:23.616Z DEBUG modem << [00:01:53.285,247] [0m<dbg> aws_fota.on_publish_evt: Received topic: nrf-352656102628123/shadow/get/accepted[0m
    2020-07-24T09:38:23.629Z DEBUG modem << [00:01:53.295,227] [0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: nrf-352656102628123/shadow/get/accepted[0m
    2020-07-24T09:38:23.641Z DEBUG modem << [00:01:53.308,227] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 0 len = 283[0m
    2020-07-24T09:38:23.657Z DEBUG modem << [00:01:53.320,831] [0m<dbg> nrf_cloud_transport.nct_dc_endpoint_set: nct_dc_endpoint_set[0m
    2020-07-24T09:38:23.660Z DEBUG modem << [00:01:53.329,284] [0m<dbg> nrf_cloud_transport.nct_dc_endpoint_get: nct_dc_endpoint_get[0m
    2020-07-24T09:38:23.680Z DEBUG modem << [00:01:53.338,897] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 7890 opcode = 1 len = 329[0m
    2020-07-24T09:38:23.681Z DEBUG modem << [00:01:53.350,555] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 7[0m
    2020-07-24T09:38:23.688Z DEBUG modem << [00:01:53.358,245] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATED[0m
    2020-07-24T09:38:23.694Z DEBUG modem << [00:01:53.366,333] [0m<inf> asset_tracker: CLOUD_EVT_PAIR_DONE[0m
    2020-07-24T09:38:24.084Z DEBUG modem << [00:01:53.753,631] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 7890 result = 0[0m
    2020-07-24T09:38:24.095Z DEBUG modem << [00:01:53.763,549] [0m<dbg> nrf_cloud_fsm.cc_tx_ack_handler: Previous session valid; skipping nct_dc_connect()[0m
    2020-07-24T09:38:24.106Z DEBUG modem << [00:01:53.773,712] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 9[0m
    2020-07-24T09:38:24.110Z DEBUG modem << [00:01:53.781,402] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_READY[0m
    2020-07-24T09:38:24.116Z DEBUG modem << [00:01:53.788,604] [0m<inf> asset_tracker: CLOUD_EVT_READY[0m
    2020-07-24T09:38:24.131Z DEBUG modem << [00:01:53.795,166] [0m<dbg> nrf9160_gps.init: GPS socket created, fd: 1232491587[0m
    2020-07-24T09:38:24.140Z DEBUG modem << [00:01:53.809,906] [0m<inf> gps_control: GPS initialized[0m
    2020-07-24T09:38:24.170Z DEBUG modem << [00:01:53.838,348] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 1 opcode = 1 len = 621[0m
    2020-07-24T09:38:24.182Z DEBUG modem << [00:01:53.851,135] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 2 opcode = 1 len = 58[0m
    2020-07-24T09:38:24.481Z DEBUG modem << [00:01:54.150,665] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 2 result = 0[0m
    2020-07-24T09:38:24.491Z DEBUG modem << [00:01:54.160,583] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0[0m
    2020-07-24T09:38:32.180Z DEBUG modem << %CESQ: 50,2,23,3
    2020-07-24T09:39:16.755Z DEBUG modem >> AT%XSYSTEMMODE?
    2020-07-24T09:39:16.764Z DEBUG modem << %XSYSTEMMODE: 1,0,1,0
    2020-07-24T09:39:16.766Z DEBUG modem << OK
    # General config
    CONFIG_ASSERT=y
    CONFIG_REBOOT=y
    CONFIG_LOG=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    # LTE link control
    #Fallback timer
    # Modem info
    CONFIG_MODEM_INFO=y
    # BSD library
    # nRF Cloud
    CONFIG_CLOUD_API=y
    CONFIG_NRF_CLOUD=y
    CONFIG_CJSON_LIB=y
    # Sensors
    # GPS
    CONFIG_DK_LIBRARY=y
    # Console
    # Heap and stacks
    # MCUBOOT
    # Flash
    CONFIG_FLASH=y
    # AWS FOTA
    CONFIG_AWS_FOTA=y
    CONFIG_DFU_TARGET=y
    # Fatal error
    CONFIG_WATCHDOG=y
