Connecting the nRF9160DK to the nRF52833 over Bluetooth
I would like to set up a couple of boards communicating over Bluetooth; I was hoping someone could provide some pointers.
I would like to connect the nRF9160DK to the nRF52833DK.
I have programmed the nRF52 on the nRF9160DK with the HCI UART code and the nRF9160 with the LTE_BLE_Gateway code.
Is this correct?
What should I program the nRF52833 with?
Rod
  • I have carried out a clean install, installed NCS version 1.3.0  and have tried to build as below. Still seeing errors.
    Watts-MBP-2:lte_ble_gateway Watt$ pwd
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway
    Watts-MBP-2:lte_ble_gateway Watt$ west build -b nrf9160dk_nrf9160ns
    Including boilerplate (Zephyr base (cached)): /Users/Watt/zephyrproject/zephyr/cmake/app/boilerplate.cmake
    -- Application: /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway
    -- Zephyr version: 2.3.0-rc2 (/Users/Watt/zephyrproject/zephyr)
    -- Board: nrf9160dk_nrf9160ns
    -- Found west: /Library/Frameworks/Python.framework/Versions/3.8/bin/west (found suitable version "0.7.2", minimum required is "0.7.1")
    -- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (/Users/Watt/gnuarmemb)
    -- Found BOARD.dts: /Users/Watt/zephyrproject/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
    nrf9160dk_nrf9160ns.dts.pre.tmp:92.42-104.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
    nrf9160dk_nrf9160ns.dts.pre.tmp:341.19-347.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
    -- Generated zephyr.dts: /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/zephyr/include/generated/devicetree_unfixed.h
    Parsing /Users/Watt/zephyrproject/zephyr/Kconfig
    Loaded configuration '/Users/Watt/zephyrproject/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration '/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf'
    warning: UART_2_NRF_FLOW_CONTROL (defined at drivers/serial/Kconfig.nrfx:195) was assigned the value
    'y' but got the value 'n'. Check these unsatisfied dependencies: UART_2_NRF_UARTE (=n). See
    http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_UART_2_NRF_FLOW_CONTROL.html and/or
    look up UART_2_NRF_FLOW_CONTROL in the menuconfig/guiconfig interface. The Application Development
    Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
    might be helpful too.
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:18: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:19: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:22: warning: attempt to assign the value 'y' to the undefined symbol AT_HOST_LIBRARY
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:25: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:28: warning: attempt to assign the value 'n' to the undefined symbol BSD_LIBRARY_TRACE_ENABLED
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:31: warning: attempt to assign the value 'y' to the undefined symbol NRF_CLOUD
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:34: warning: attempt to assign the value 'y' to the undefined symbol GPS_USE_SIM
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:37: warning: attempt to assign the value '30' to the undefined symbol GPS_SEARCH_INTERVAL
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:38: warning: attempt to assign the value '15' to the undefined symbol GPS_SEARCH_TIMEOUT
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:45: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:46: warning: attempt to assign the value 'n' to the undefined symbol DK_LIBRARY_INVERT_LEDS
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:58: warning: attempt to assign the value 'y' to the undefined symbol BT_GATT_DM
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:59: warning: attempt to assign the value 'y' to the undefined symbol BT_SCAN
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:60: warning: attempt to assign the value 'y' to the undefined symbol BT_SCAN_FILTER_ENABLE
    /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf:61: warning: attempt to assign the value '1' to the undefined symbol BT_SCAN_UUID_CNT
    error: Aborting due to Kconfig warnings
    CMake Error at /Users/Watt/zephyrproject/zephyr/cmake/kconfig.cmake:217 (message):
      command failed with return code: 1
      /Users/Watt/zephyrproject/zephyr/cmake/app/boilerplate.cmake:510 (include)
      /Users/Watt/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      /Users/Watt/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
      CMakeLists.txt:20 (find_package)
    FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -B/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/build -S/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway -GNinja
  • I have tried to build another application to see if I can get a clue to what's wrong. (I am managing to build basic stuff such as "blinky" and "button".
    I have tried to build "at_client", I can only get this to build when I remove the following lines from the prj.conf file
    CONFIG_AT_HOST_LIBRARY=y
    CONFIG_LTE_NETWORK_MODE_NBIOT=y
    CONFIG_LTE_NETWORK_MODE_LTE_M=n
    CONFIG_BSD_LIBRARY=y
    Looking at other tickets, most have had success when they recreate a brand new work space. So, I unset the ZEPHYR_BASE variable and carry out the following.
    https://raw.githubusercontent.com/Homebrew/install/master/install)"
    brew install cmake ninja gperf python3 ccache qemu dtc
    pip3 install west
    west init ~/newinstall
    cd ~/newinstall
    west update
    west zephyr-export
    pip3 install -r ~/newinstall/zephyr/scripts/requirements.txt
    pip3 install -U west
    Watts-MBP-2:newinstall Watt$ pwd
    /Users/Watt/newinstall
    Watts-MBP-2:newinstall Watt$ ls
    bootloader	modules		tools		zephyr
    Watts-MBP-2:newinstall Watt$ mkdir ncs
    Watts-MBP-2:ewinstall Watt$ cd ncs
    Watts-MBP-2:ncs Watt$ west init -m https://github.com/nrfconnect/sdk-nrf --mr v1.3.0
    FATAL ERROR: already initialized in /Users/Watt/newinstall, aborting.
    Unfortunately this reports and error, even though this is a new workspace.
    Would appreciate your thoughts?
    Rod
  • Rod, you must create NCS outside of zephyrproject. (/Users/Watt/NCS/). And you must not run "west init ~/newinstall" and "west update", as this causes confusion and initializes zephyr. NCS includes zephyr inside, and will not be able to initialize if already initialized.
    Unless you are using the zephyrproject folder, please delete this along with other folders that you have created.
    Then do the following steps:
    cd ~
    mkdir ncs && cd ncs
    west update
    west zephyr-export
    pip3 install -r zephyr/scripts/requirements.txt
    pip3 install -r nrf/scripts/requirements.txt
    pip3 install -r bootloader/mcuboot/scripts/requirements.txt
    If this still does not work, please install the Toolchain Manager from the nRF Connect for Desktop.
    Øyvind
  • Hi Øyvind,
    Ok, that worked, thanks. I was able to build and flash "at_client".
    When I tried to build "lte_ble_gateway", the code is looping continually.
    /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway
    Including boilerplate (Zephyr base): /Users/Watt/ncs/zephyr/cmake/app/boilerplate.cmake
    -- Application: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway
    -- Zephyr version: 2.3.0-rc1 (/Users/Watt/ncs/zephyr)
    -- Found Python3: /Library/Frameworks/Python.framework/Versions/3.8/bin/python3.8 (found suitable exact version "3.8.1") found components: Interpreter
    -- Found toolchain: gnuarmemb (/Users/Watt/gcc-arm-none-eabi-8-2019-q3-update)
    -- Found BOARD.dts: /Users/Watt/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
    -- Found devicetree overlay: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/nrf9160dk_nrf9160ns.overlay
    nrf9160dk_nrf9160ns.dts.pre.tmp:394.32-398.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
    nrf9160dk_nrf9160ns.dts.pre.tmp:93.42-105.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
    nrf9160dk_nrf9160ns.dts.pre.tmp:202.18-208.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/uart@a000: duplicate unit-address (also used in node /soc/peripheral@40000000/i2c@a000)
      also defined at nrf9160dk_nrf9160ns.dts.pre.tmp:504.8-507.3
      also defined at nrf9160dk_nrf9160ns.dts.pre.tmp:611.8-619.3
    nrf9160dk_nrf9160ns.dts.pre.tmp:342.19-348.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
    -- Generated zephyr.dts: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/zephyr/include/generated/devicetree_unfixed.h
    Parsing /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/Kconfig
    Loaded configuration '/Users/Watt/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration '/Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/prj.conf'
    Configuration saved to '/Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/zephyr/.config'
    Kconfig header saved to '/Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 8.3.1
    -- The CXX compiler identification is GNU 8.3.1
    -- Found assembler: /Users/Watt/gcc-arm-none-eabi-8-2019-q3-update/bin/arm-none-eabi-gcc
    -- Cache files will be written to: /Users/Watt/Library/Caches/zephyr
    Changed board to secure nrf9160dk_nrf9160 (NOT NS)
    === child image spm - nrf9160dk_nrf9160 begin ===
    -- Application: /Users/Watt/ncs/nrf/samples/nrf9160/spm
    -- Found BOARD.dts: /Users/Watt/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: /Users/Watt/ncs/nrf/samples/nrf9160/spm/nrf9160dk_nrf9160.overlay
    nrf9160dk_nrf9160.dts.pre.tmp:95.42-107.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
    nrf9160dk_nrf9160.dts.pre.tmp:344.19-350.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
    -- Generated zephyr.dts: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/spm/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/spm/zephyr/include/generated/devicetree_unfixed.h
    Parsing /Users/Watt/ncs/zephyr/Kconfig
    Loaded configuration '/Users/Watt/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
    Merged configuration 'prj.conf'
    Merged configuration '/Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/child_secure_partition_manager.conf'
    Configuration saved to '/Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/spm/zephyr/.config'
    Kconfig header saved to '/Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/spm/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/spm
    === child image spm - nrf9160dk_nrf9160 end ===
    CMake Warning at /Users/Watt/ncs/zephyr/CMakeLists.txt:1384 (message):
    -- Configuring done
    -- Generating done
    [6/210] Performing build step for 'spm_subimage'
    [7/193] Preparing syscall dependency handling
    [188/193] Linking C executable zephyr/zephyr_prebuilt.elf
               FLASH:         32 KB        48 KB     66.67%
                SRAM:        5416 B        64 KB      8.26%
            IDT_LIST:          40 B         2 KB      1.95%
    [193/193] Linking C executable zephyr/zephyr.elf
    [203/210] Linking C executable zephyr/zephyr_prebuilt.elf
               FLASH:      163848 B       976 KB     16.39%
                SRAM:       58422 B       128 KB     44.57%
            IDT_LIST:         152 B         2 KB      7.42%
    [210/210] Generating zephyr/merged_domains.hex
    Watts-MBP-2:lte_ble_gateway Watt$ west flash
    -- west flash: rebuilding
    [0/9] Performing build step for 'spm_subimage'
    ninja: no work to do.
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: Flashing file: /Users/Watt/ncs/nrf/samples/nrf9160/lte_ble_gateway/build/zephyr/merged.hex
    Parsing hex file.
    Erasing page at address 0x0.
    Erasing page at address 0x1000.
    Erasing page at address 0x2000.
    Erasing page at address 0x3000.
    Erasing page at address 0x4000.
    Erasing page at address 0x5000.
    Erasing page at address 0x6000.
    Erasing page at address 0x7000.
    Erasing page at address 0xC000.
    Erasing page at address 0xD000.
    Erasing page at address 0xE000.
    Erasing page at address 0xF000.
    Erasing page at address 0x10000.
    Erasing page at address 0x11000.
    Erasing page at address 0x12000.
    Erasing page at address 0x13000.
    Erasing page at address 0x14000.
    Erasing page at address 0x15000.
    Erasing page at address 0x16000.
    Erasing page at address 0x17000.
    Erasing page at address 0x18000.
    Erasing page at address 0x19000.
    Erasing page at address 0x1A000.
    Erasing page at address 0x1B000.
    Erasing page at address 0x1C000.
    Erasing page at address 0x1D000.
    Erasing page at address 0x1E000.
    Erasing page at address 0x1F000.
    Erasing page at address 0x20000.
    Erasing page at address 0x21000.
    Erasing page at address 0x22000.
    Erasing page at address 0x23000.
    Erasing page at address 0x24000.
    Erasing page at address 0x25000.
    Erasing page at address 0x26000.
    Erasing page at address 0x27000.
    Erasing page at address 0x28000.
    Erasing page at address 0x29000.
    Erasing page at address 0x2A000.
    Erasing page at address 0x2B000.
    Erasing page at address 0x2C000.
    Erasing page at address 0x2D000.
    Erasing page at address 0x2E000.
    Erasing page at address 0x2F000.
    Erasing page at address 0x30000.
    Erasing page at address 0x31000.
    Erasing page at address 0x32000.
    Erasing page at address 0x33000.
    Erasing page at address 0x34000.
    Applying system reset.
    Checking that the area to write is not protected.
    Programming device.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 960040578 flashed successfully.
    That's good news!
     I'm not sure I'm following, the output that you have attached looks good. Can you please elaborate?
    Thank you!
    Øyvind
