Connecting the nRF9160DK to the nRF52833 over Bluetooth
I would like to set up a couple of boards communicating over Bluetooth; I was hoping someone could provide some pointers.
I would like to connect the nRF9160DK to the nRF52833DK.
I have programmed the nRF52 on the nRF9160DK with the HCI UART code and the nRF9160 with the LTE_BLE_Gateway code.
Is this correct?
What should I program the nRF52833 with?
Rod
  • Hi Øyvind,
    I have captured the terminal output below. Its reporting it can't find an LTE Link and them seems to reboot.
    As I have just got this working, I have not set up the server side (nfcloud etc) I guess that's what causing the failure? Sorry, when I saw this initially I thought it was not finding a bootable image or similar.
    As I'm not interested in writing to the cloud, I just want to get BLE working between the boards, I have commented out the code in main as below
    	buttons_leds_init();
    	ble_init();
    	work_init();
    //	cloud_init();
    //	modem_configure();
    //	cloud_connect(NULL);
    	while (true) {
    //		nrf_cloud_process();
    //		send_aggregated_data();
    		k_sleep(K_MSEC(10));
    		k_cpu_idle();
    This has enabled me to connect the nRF9160Dk to Thing52, I'm seeing this.
    SPM: NS image at 0xc000
    SPM: NS MSP at 0x2002bae0
    SPM: NS reset vector at 0x1245d
    SPM: prepare to jump to Non-Secure image.
    *** Booting Zephyr OS build v2.3.0-rc1-ncs1  ***
    Bluetooth Receiver Demo Started
    Initializing Bluetooth..
    Bluetooth ready
    Scanning...
    Device found: e0:54:b8:7a:61:9d (random)
    Connected: e0:54:b8:7a:61:9d (random)
    Orientation: 2
    So, I'm now back to my initial problem of connecting the nRF52833DK to the nRF9160DK
    Rod
  • Hi Rod,
    I haven't been able to look much into your case, however, things are starting to normalize in the support department and that will leave more time to help you.
    Øyvind
  • Hi Øyvind,
    That would be great, thank you. (Since we talked, I modified some of the code on the Sensor gateway example so I could get an nRF52833 board to connect over BLE, I didn't get as far as sending data )
    I have also bought an NRF52840 dongle which seems to be a good fit for me.
    So, ideally I would like to be able to send sensor data from a sensor connected to the nRF52840 board (for example, a simple temperature sensor connected over I2C) back to the nRF9160DK.
    Any pointers you could provide would be much appreciated.
    Rod
  • Hi Rod,
    Sorry for the lack of answers, it's just been a busy week.
    I've tested with nRF52840DK and nRF52833DK, running respectively Central HIDS and Peripheral HIDS Keyboard. Those work perfectly together. However, I have not been successful in running the Central HIDS on the nRF9160DK. Will keep testing and get back to you.
    There has been an ongoing discussion regarding BLE and NCS in this Git thread, please read through this as well.
    Yes, this should work fine, just remember to use nRF52840dongle_nrf52840.
    Øyvind
  • Hi Øyvind,
    Thanks for your feedback and support, much appreciated. I have hooked up the dongle to and external debugger and UART but am not getting any Printf() output, I have opened a separate ticket.,
    https://devzone.nordicsemi.com/f/nordic-q-a/64627/no-uart-output-from-printf
    Once I have this working, I can try the code you mentioned
    Rod
