FreeRTOS+WDT+SDK17 problem
I have added WDT to the blinky_freertos sample.
/** add **/
static nrf_drv_wdt_channel_id m_channel_id;
static void wdt_event_handler(void)
    ret_code_t err_code;
    /* Initialize clock driver for better time accuracy in FREERTOS */
    err_code = nrf_drv_clock_init();
    /* Configure LED-pins as outputs */
    /* Create task for LED0 blinking with priority set to 2 */
    UNUSED_VARIABLE(xTaskCreate(led_toggle_task_function, "LED0", configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task_handle));
    /* Start timer for LED1 blinking */
    led_toggle_timer_handle = xTimerCreate( "LED1", TIMER_PERIOD, pdTRUE, NULL, led_toggle_timer_callback);
    UNUSED_VARIABLE(xTimerStart(led_toggle_timer_handle, 0));
    /* Activate deep sleep mode */
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
/** add **/
    nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
    err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
    err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
    nrf_drv_wdt_enable();
	/* Start FreeRTOS scheduler. */
    vTaskStartScheduler();
    while (true)
        /* FreeRTOS should not be here... FreeRTOS goes back to the start of stack
         * in vTaskStartScheduler function. */
And I am debugging with SEGGER ozone.
building with SDK17:
If you reset the software in the debugger and start it, the application freezes.
t stops in the following loop.
And RTC1 is not counting up.
port_cmsis_systick.c
     /* No SD -  we would just block interrupts globally.
      * BASEPRI cannot be used for that because it would prevent WFE from wake up.
      do{
         __WFE();
      } while (0 == (NVIC->ISPR[0] | NVIC->ISPR[1]));
However, after WDT reset, blinky works normally.
I have built the same application with SDK15.
It was perfectly fine.
SDK17 seems to have a problem.
I found a difference with SDK15.
SDK17 nrf_drv_clock.c
    if (nrf_wdt_started())
        m_clock_cb.lfclk_on = true;
If a software reset occurs after WDT is activated, WDT remains activated after the reset. However, LFCLK is stopped.
As a result, the above process does not start LFCLK, so even if RTC1 is started, it will not be counted up.
  • Syuji,
    Sorry for late response, we started coming back from summer holidays. I will take a look at this problem today, will come back to you soon.
  • Where are you feeding the watchdog? (where is your application calling nrf_drv_wdt_channel_feed?)
    For me it is working fine if i feed the wdt in the bsp_event_callback with a button press. the wdt reset happens if i do not press the button.
  • I add feeding the watchdog in led_toggle_task_function.
    But the problem is not there.
    The problem is that if a software reset occurs while WtchDog is running, FreeRTOS will not work properly.
    And the cause is that LFCLK is not initialized properly.
    i cannot see this behavior in my quick test on the desk. No software resets have happened in my test. Can you please attach your project so that i can test this.
  • Target board is PCA10056(nRF52840).
     * Copyright (c) 2015 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup blinky_example_main main.c
     * @ingroup blinky_example_freertos
     * @brief Blinky FreeRTOS Example Application main file.
     * This file contains the source code for a sample application using FreeRTOS to blink LEDs.
    #include <stdbool.h>
    #include <stdint.h>
    #include "FreeRTOS.h"
    #include "task.h"
    #include "timers.h"
    #include "bsp.h"
    #include "nordic_common.h"
    #include "nrf_drv_clock.h"
    #include "sdk_errors.h"
    #include "app_error.h"
    #include "nrf_drv_wdt.h"
    #define	WDT_ENABLE			1
    #if LEDS_NUMBER <= 2
    #error "Board is not equipped with enough amount of LEDs"
    #define TASK_DELAY        200           /**< Task delay. Delays a LED0 task for 200 ms */
    #define TIMER_PERIOD      1000          /**< Timer period. LED1 timer will expire after 1000 ms */
    TaskHandle_t  led_toggle_task_handle;   /**< Reference to LED0 toggling FreeRTOS task. */
    TimerHandle_t led_toggle_timer_handle;  /**< Reference to LED1 toggling FreeRTOS timer. */
    /**@brief LED0 task entry function.
     * @param[in] pvParameter   Pointer that will be used as the parameter for the task.
    static void led_toggle_task_function (void * pvParameter)
        UNUSED_PARAMETER(pvParameter);
        while (true)
    #if WDT_ENABLE
        	nrf_drv_wdt_feed();
            bsp_board_led_invert(BSP_BOARD_LED_0);
            /* Delay a task for a given number of ticks */
            vTaskDelay(TASK_DELAY);
            /* Tasks must be implemented to never return... */
    /**@brief The function to call when the LED1 FreeRTOS timer expires.
     * @param[in] pvParameter   Pointer that will be used as the parameter for the timer.
    static void led_toggle_timer_callback (void * pvParameter)
        bsp_board_led_invert(BSP_BOARD_LED_1);
    #if WDT_ENABLE
    static void bsp_evt_handler(bsp_event_t evt)
        switch (evt)
            case BSP_EVENT_KEY_0:
        	NVIC_SystemReset(); /* Software Reset */
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_evt_handler);
    #if WDT_ENABLE
        while (true)
    And sdk_config.h modified
    #define NRFX_WDT_CONFIG_RELOAD_VALUE 10000
    If #define WDT_ENABLE 1.  (WDT enabled)
    1. When PoweOnReset, LED is blinking.
    2. When Button 1 pushed(execute SoftwareReset), LED blinking is stopped.
    3. After 10 seconds, LED blinking is started.
    If #define WDT_ENABLE 0. (WDT disabled)
    2. When Button 1 pushed(execute SoftwareReset), LED blinking is restarted quickly.
