FreeRTOS+WDT+SDK17 problem
I have added WDT to the blinky_freertos sample.
/** add **/
static nrf_drv_wdt_channel_id m_channel_id;
static void wdt_event_handler(void)
    ret_code_t err_code;
    /* Initialize clock driver for better time accuracy in FREERTOS */
    err_code = nrf_drv_clock_init();
    /* Configure LED-pins as outputs */
    /* Create task for LED0 blinking with priority set to 2 */
    UNUSED_VARIABLE(xTaskCreate(led_toggle_task_function, "LED0", configMINIMAL_STACK_SIZE + 200, NULL, 2, &led_toggle_task_handle));
    /* Start timer for LED1 blinking */
    led_toggle_timer_handle = xTimerCreate( "LED1", TIMER_PERIOD, pdTRUE, NULL, led_toggle_timer_callback);
    UNUSED_VARIABLE(xTimerStart(led_toggle_timer_handle, 0));
    /* Activate deep sleep mode */
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
/** add **/
    nrf_drv_wdt_config_t config = NRF_DRV_WDT_DEAFULT_CONFIG;
    err_code = nrf_drv_wdt_init(&config, wdt_event_handler);
    err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
    nrf_drv_wdt_enable();
	/* Start FreeRTOS scheduler. */
    vTaskStartScheduler();
    while (true)
        /* FreeRTOS should not be here... FreeRTOS goes back to the start of stack
         * in vTaskStartScheduler function. */
And I am debugging with SEGGER ozone.
building with SDK17:
If you reset the software in the debugger and start it, the application freezes.
t stops in the following loop.
And RTC1 is not counting up.
port_cmsis_systick.c
     /* No SD -  we would just block interrupts globally.
      * BASEPRI cannot be used for that because it would prevent WFE from wake up.
      do{
         __WFE();
      } while (0 == (NVIC->ISPR[0] | NVIC->ISPR[1]));
However, after WDT reset, blinky works normally.
I have built the same application with SDK15.
It was perfectly fine.
SDK17 seems to have a problem.
I found a difference with SDK15.
SDK17 nrf_drv_clock.c
    if (nrf_wdt_started())
        m_clock_cb.lfclk_on = true;
If a software reset occurs after WDT is activated, WDT remains activated after the reset. However, LFCLK is stopped.
As a result, the above process does not start LFCLK, so even if RTC1 is started, it will not be counted up.
  • Cannot comment on EOL for SDK 17 but I now fall back to this logical flow.
    If Soft Device is enabled before starting the watch dog then this is not an issue.
    Else if you are not using Soft Device and still want to use the watch dog then one must start the LF CLOCK task explicitly (it is not enough to just set required preprocessor symbols in the configuration).
    Good Luck.
