i have used a example of ble_app_template in ble_peripheral of SDK15.0,when code run in ble_advertising_start,return errcode 8.
i have checked low speed Crystals,it's ok。 i don not no what's happen .please give some advice,thank you.
It seems normal. Please try stepping into the code and find where exactly it throw error code 8 and why.
i have tried this methods.
if Step through the code ,when run to switch (p_advertising->adv_mode_current),it will run long time ,then get the error code , when Breaking point after the switch struct,it will run to p_advertising->evt_handler(p_advertising->adv_evt),then get error.
The following code:
uint32_t ble_advertising_start(ble_advertising_t * const p_advertising,
ble_adv_mode_t advertising_mode)
uint32_t ret;
if (p_advertising->initialized == false)
p_advertising->adv_mode_current = advertising_mode;
// Delay starting advertising until the flash operations are complete.
if (flash_access_in_progress())
p_advertising->advertising_start_pending = true;
return NRF_SUCCESS;
memset(&p_advertising->peer_address, 0, sizeof(p_advertising->peer_address));
if ( ((p_advertising->adv_modes_config.ble_adv_directed_high_duty_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
||((p_advertising->adv_modes_config.ble_adv_directed_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED_HIGH_DUTY))
||((p_advertising->adv_modes_config.ble_adv_directed_enabled) && (p_advertising->adv_mode_current == BLE_ADV_MODE_DIRECTED))
if (p_advertising->evt_handler != NULL)
p_advertising->peer_addr_reply_expected = true;
p_advertising->evt_handler(BLE_ADV_EVT_PEER_ADDR_REQUEST);
p_advertising->peer_addr_reply_expected = false;
p_advertising->adv_mode_current = adv_mode_next_avail_get(p_advertising, advertising_mode);
// Fetch the whitelist.
if ((p_advertising->evt_handler != NULL) &&
(p_advertising->adv_mode_current == BLE_ADV_MODE_FAST || p_advertising->adv_mode_current == BLE_ADV_MODE_SLOW) &&
(p_advertising->adv_modes_config.ble_adv_whitelist_enabled) &&
(!p_advertising->whitelist_temporarily_disabled))
p_advertising->whitelist_in_use = false;
p_advertising->whitelist_reply_expected = true;
p_advertising->evt_handler(BLE_ADV_EVT_WHITELIST_REQUEST);
p_advertising->whitelist_reply_expected = false;
// Initialize advertising parameters with default values.
memset(&p_advertising->adv_params, 0, sizeof(p_advertising->adv_params));
p_advertising->adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
// Use 1MBIT as primary phy if no phy was selected.
if (phy_is_valid(&p_advertising->adv_modes_config.ble_adv_primary_phy))
p_advertising->adv_params.primary_phy = p_advertising->adv_modes_config.ble_adv_primary_phy;
p_advertising->adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
if (p_advertising->adv_modes_config.ble_adv_extended_enabled)
// Use 1MBIT as secondary phy if no phy was selected.
p_advertising->adv_params.secondary_phy = p_advertising->adv_modes_config.ble_adv_secondary_phy;
p_advertising->adv_params.secondary_phy = BLE_GAP_PHY_1MBPS;
p_advertising->adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
// Set advertising parameters and events according to selected advertising mode.
case BLE_ADV_MODE_DIRECTED_HIGH_DUTY:
ret = set_adv_mode_directed_high_duty(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_DIRECTED:
ret = set_adv_mode_directed(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_FAST:
ret = set_adv_mode_fast(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_SLOW:
ret = set_adv_mode_slow(p_advertising, &p_advertising->adv_params);
case BLE_ADV_MODE_IDLE:
p_advertising->adv_evt = BLE_ADV_EVT_IDLE;
if (p_advertising->adv_mode_current != BLE_ADV_MODE_IDLE)
ret = sd_ble_gap_adv_set_configure(&p_advertising->adv_handle, p_advertising->p_adv_data, &p_advertising->adv_params);
if (ret != NRF_SUCCESS)
return ret;
ret = sd_ble_gap_adv_start(p_advertising->adv_handle, p_advertising->conn_cfg_tag);
return ret;
p_advertising->evt_handler(p_advertising->adv_evt);
return NRF_SUCCESS;
I don't really get it. Which function returned error 8 ? Could you please take a screenshot where you find error 8 ?
Note that to debug with softdevice you would need to change the optimization level to 0 and you may not be able to step in the code but would need to use logging or breakpoints instead.
