I have a project which is intended to log data via the UART port.
When I enable BACKEND LOG via RTT (NRF_LOG_BACKEND_RTT_ENABLED = 1). I'm able to view output via the RTTViewer.
However, when I switch over and enable using backend (NRF_LOG_BACKEND_UART_ENABLED = 1), then the application fails.
The function log_init() fails when nrf_drv_uart_init() is called because UARTE_PRESENT is defined.
I'm using an nrf52 DK, with nrf52832 installed in it.
Any help will be appreciated.
Thank you.
