When I compiled your sample Bluetooth: Central UART from both master and v1.3-branch branches for nRF5340 PDK (network core has Bluetooth: HCI RPMsg firmware) and I use a serial monitor to see UART output from /dev/ttyACM2 port, then everything operates properly. I can push button BOOT/RESET and see logs in a serial monitor. But everything works until I unplug USB cable with nRF5340 PDK from a computer. When I plug it again I already see nothing in the serial monitor, even after pushing BOOT/RESET button. I don't see even such string *** Booting Zephyr OS build v2.3.0-rc1-ncs1 ***. Even when I built it again from SEGGER Embedded Studio for ARM Release 4.52 (Build 2020033100.41808 Linux x64) and run I saw nothing in the serial monitor. And to force it to work I had to build and run another example. Otherwise /dev/ttyACM2 port was completely silent, even after rebooting a system.
However, when I use the same example Bluetooth: Central UART with nRF52840 DK, then I can unplug and plug the development board as many as I want and UART output works properly, unlike nRF5340 PDK, which outputs nothing to /dev/ttyACM2 port after one time unplugging USB cable.
