BLE DFU Speed difference between SDK14.2 and SDK15.3
Config1:
MCU : nRF52840
SDK : SDK15.3
Softdevice : s340_nrf52_6.1.1_softdevice (SDK15.3)
Phone: iOS version 12.1
Config2:
MCU : nRF52832
SDK : SDK14.2
Softdevice : s332_nrf52_5.0.0_softdevice (SDK14.2)
We have use SDK Bootloader example code for both SDK14.2 and SDK15.3 for BLE DFU. Our bootloader is based on the BLE secure bootloader example from SDK14.2 and SDK15.3
Now if we use SDK14.2 then it will take max 2 minute for BLE application upgrade.
and if we use SDK15.3 then it will take around 12 to 15 minute for BLE application upgrade.
Note: Application file size which is used in both upgrade is same.
so my question is for SDK15.3 boothloader example code takes more time then SDK14.2 bootloader example code.
Why it takes more time?
I use same app and mobile device in both condition.
Sandip Divani
    12 to 15 minutes is a lot.
    There must be something wrong here. I suspect that the connection interval was set to too large.
    Could you please check the connection interval when doing DFU ?
    As sniffer trace could be useful to reveal what caused the long DFU.
  • Hung Bui
    Following is our connection parameter. Is there any wrong?
    // <h> BLE DFU connection
    // <o> NRF_DFU_BLE_MIN_CONN_INTERVAL - Minimum connection interval (units).
    // <i> Minimum GAP connection interval, in 1.25 ms units.
    #ifndef NRF_DFU_BLE_MIN_CONN_INTERVAL
    #define NRF_DFU_BLE_MIN_CONN_INTERVAL 6 //12
    // <o> NRF_DFU_BLE_MAX_CONN_INTERVAL - Maximum connection interval (units).
    // <i> Maximum GAP connection interval, in 1.25 ms units.
    #ifndef NRF_DFU_BLE_MAX_CONN_INTERVAL
    #define NRF_DFU_BLE_MAX_CONN_INTERVAL 80 //12
    // <o> NRF_DFU_BLE_CONN_SUP_TIMEOUT_MS - Supervision timeout (ms).
    // <i> GAP connection supervision timeout, in milliseconds.
    #ifndef NRF_DFU_BLE_CONN_SUP_TIMEOUT_MS
    #define NRF_DFU_BLE_CONN_SUP_TIMEOUT_MS 4000 //6000
    // </h>
    Sandip Divani
  • Hi Sandip,
    Please try to get the actual connection interval when the DFU is transmitting. It's the p_ble_evt->gap_evt.connected.conn_params. min_conn_interval value when you receive BLE_GAP_EVT_CONNECTED event inside ble_evt_handler()
    Or you can capture a sniffer trace. It gives more information with the sniffer trace.
    I have taken sniffer log for issue and updating here.
    We have use iphone 11 with latest iOS. so, DFU time is reduce and achieve 175 seconds. still we want to reduce this time. Please suggest any method or any other parameter we can change in phone app or bootloader. so, we can achieve less time compare to 175 seconds. Pleas suggest any applicable solution for achieve minimum time for app update.
    We have do 3 test and result and sniffer log file name here.
    MCU : nRF52840
    SDK : SDK15.3
    DFU Test Cases and Sniffer log
    Test# Peripheral Central Conn Interval DFU App Size Observered Param DFU Time Sniffer Log File Name
    1 nRF52840 Chipset nRF52840 DevKit Conn. Interval = 30 msec 241 KBytes PHY1M, Conn. Interval = 30 msec 158 sec Test1_nRFDevKit.pcapng
    2 nRF52840 Chipset nRF52840 DevKit Conn. Interval = 7.5 msec 241 KBytes PHY1M, Conn. Interval = 7.5 msec 122 sec Test2_nRFDevKit_Set7p5ConnInt.pcapng
    3 nRF52840 Chipset iPhone 11   241 KBytes PHY2M, Conn. Interval = 90 msec 174 sec Test3_iPhone11.pcapng
    Himansu
  • Hi Himansu,
    I can see that at test 2 you are achieving quite a good speed of transmitting. However I don't see using data length extension. This resulted in that the length of a packet is only 23 bytes (27 with the header). If you can update the data length extension (LL_LENGTH_REQ) you may be able to achieve faster DFU transmitting.
    Regarding case 3, I think what can be improved here is that instead of requesting min interval of 7.5ms (which will not be accepted by iOS) you can try to request min 30ms max 50 ms for example. Then you will have more chance being granted 30ms , this is much better than 90ms as in your trace.
    In addition, there was quite a lot of retransmission in the trace, seems that the communication was interfered quite a lot or the antenna/radio was not tuned on the NRF52840 DUT board you have. I don't see that problem in the test 1 and test 2.
