I'm using:
OS : Windows 10
IDE : Segger Embedded Studio for ARM Realease 4.52c Windows x64
SDK : nRF_SDK_15.0.0_a53641a
In my project I'm using 4 pressure sensors and 1 SD card, all of this using the same SPI.
1) I started with the presure sensors, For this I used the exemple found here : examples\peripheral\SPI and modified it a bit, add a custom Chip Select switching function and It worked just fine.
2) I continued with the SD Card, using the following exemple : examples\peripheral\fatfs, no major problems either
3) I tried to merge 2) in 1), a little of work with the include and the path but my code compiles. Except that it crash,
3.1) I initialize the SPI instance (sensor) make some measures
3.2) Unitialise the SPI instance (sensor)
3.3) Initialize, mount, write the SD Card (which use SPI)
3.4) Unmount, uninitialize the SD_Card
3.5) Unitialize the SPI instance (SD Card... I least I hope)
3.6) Initialize the SPI instance (sensor) make some measures
3.7) Uninitialize the SPI instance (sensor)
3.8) Initialize, mount, write the SD Card (which use SPI) But that dosen't work anymore
If I don't do 3.2) I can't do 3.3) because the SPI is already used
I don't know if I do 3.5) correctly, but if I just uninitialize the SD card it seems that the SPI instance is still used for the SD Card.
Includes:
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf.h"
#include "bsp.h"
#include "ff.h"
#include "diskio_blkdev.h"
#include "nrf_block_dev_sdc.h"
Defines:
#define SPI_INSTANCE 0 /**< SPI instance index. */
#define MISO 15 // P0.15
#define MOSI 16 // P0.16
#define SCLK 14 // P0.14
#define CS_P1 22 // prov DK
#define CS_P2 23 // prov DK
#define CS_P3 24 // prov DK
#define CS_P4 25 // prov DK
#define CS_A1 26 // prov DK
#define CS_A2 27 // prov DK
#define CS_SD 2 // prov DK
#define LED_1 17 // prov DK
#define FILE_NAME "LOG.CSV"
#define SDC_SCK_PIN SCLK ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN MOSI ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN MISO ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN CS_SD ///< SDC chip select (CS) pin.
#define SAMPLE_NBR 100
#define SAMPLE_LENGHT 27
* @brief SDC block device definition
NRF_BLOCK_DEV_SDC_DEFINE(
m_block_dev_sdc,
NRF_BLOCK_DEV_SDC_CONFIG(
SDC_SECTOR_SIZE,
APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)
NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
SD card writing function
static void ecriture_SD(char data[SAMPLE_NBR][SAMPLE_LENGHT])
static FATFS fs;
static DIR dir;
static FILINFO fno;
static FIL file;
bool erreur = false;
uint32_t cpt = 0;
uint32_t bytes_written;
FRESULT ff_result;
DSTATUS disk_state = STA_NOINIT;
// Initialize FATFS disk I/O interface by providing the block device.
static diskio_blkdev_t drives[] =
DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
diskio_blockdev_register(drives, ARRAY_SIZE(drives));
// initialisation de la carte
NRF_LOG_INFO("Initializing disk 0 (SDC)...");
for (uint32_t retries = 3; retries && disk_state; --retries)
disk_state = disk_initialize(0);
if (disk_state)
NRF_LOG_INFO("Disk initialization failed.");
return;
// monte la carte
NRF_LOG_INFO("Mounting volume...");
ff_result = f_mount(&fs, "", 1);
if (ff_result)
NRF_LOG_INFO("Mount failed.");
return;
// delete l'ancien fichier de log si 1er passage
if(clear_data)
f_unlink(FILE_NAME);
NRF_LOG_INFO("old file deleted.")
clear_data = false;
// ouvre ou cree le fichier
NRF_LOG_INFO("Writing to file " FILE_NAME "...");
ff_result = f_open(&file, FILE_NAME, FA_READ | FA_WRITE | FA_OPEN_APPEND);
if (ff_result != FR_OK)
NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".");
return;
// ecrit dans le fichier
for(cpt = 0; cpt < SAMPLE_NBR; cpt++)
ff_result = f_write(&file, data[cpt], SAMPLE_LENGHT - 1, (UINT *) &bytes_written);
if (ff_result != FR_OK) erreur = true;
if (erreur)
NRF_LOG_INFO("Write failed\r\n.");
NRF_LOG_INFO("%d bytes written.\n", bytes_written * SAMPLE_NBR);
// ferme le fichier
(void) f_close(&file);
// modif 23.07.2020
// Unmonte la carte
NRF_LOG_INFO("Unmounting volume...");
ff_result = f_mount(NULL, "", 1);
if (ff_result)
NRF_LOG_INFO("Unmount failed.");
return;
// uninitialize disk 0
NRF_LOG_INFO("Uninitializing disk 0 (SDC)...");
disk_state = disk_uninitialize(0);
if (disk_state)
NRF_LOG_INFO("Disk uninitialization failed.");
return;
nrf_drv_spi_uninit(&spi); // detruit l'instance SPI
// end of modif
NRF_LOG_FLUSH();
return;
Main
uint32_t v_Press_1, v_Press_2, v_Press_3, v_Press_4;
char data[SAMPLE_NBR][SAMPLE_LENGHT];
uint32_t cpt = 0;
uint32_t sample_number = 0;
init_cs(); // init et set les Chip Select
// initialisation des log
NRF_LOG_INFO("Main TB Wipfli start.");
NRF_LOG_FLUSH();
// initialisation SPI
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = LED_1;
spi_config.frequency = NRF_SPI_FREQ_4M;
spi_config.miso_pin = MISO;
spi_config.mosi_pin = MOSI;
spi_config.sck_pin = SCLK;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
spi_xfer_done = false; // reset fin de transfet
// initialisation des capteurs de pression
if(init_Capt_Press(CS_P1))NRF_LOG_INFO("Erreur init capt press 1");
if(init_Capt_Press(CS_P2))NRF_LOG_INFO("Erreur init capt press 2");
if(init_Capt_Press(CS_P3))NRF_LOG_INFO("Erreur init capt press 3");
if(init_Capt_Press(CS_P4))NRF_LOG_INFO("Erreur init capt press 4");
NRF_LOG_INFO("Init capt press done");
NRF_LOG_INFO("Start main");
NRF_LOG_FLUSH();
while (1)
// Reset rx buffer and transfer done flag
memset(m_rx_buf, 0, m_length);
v_Press_1 = 0; // reset pression
v_Press_2 = 0; // reset pression
v_Press_3 = 0; // reset pression
v_Press_4 = 0; // reset pression
v_Press_1 = get_pression(CS_P1);
v_Press_2 = get_pression(CS_P2);
v_Press_3 = get_pression(CS_P3);
v_Press_4 = get_pression(CS_P4);
// log provisoir pour lire sur 4 digit
NRF_LOG_INFO("Capt1 : %d hPa",v_Press_1);
NRF_LOG_INFO("Capt2 : %d hPa",v_Press_2);
NRF_LOG_INFO("Capt3 : %d hPa",v_Press_3);
NRF_LOG_INFO("Capt4 : %d hPa\n",v_Press_4);
NRF_LOG_FLUSH();
// met en forme les datas dans un chunk
sprintf(data[cpt],"%05d;%04d;%04d;%04d;%04d\n",sample_number,v_Press_1,v_Press_2,v_Press_3,v_Press_4);
sample_number++;
cpt++;
// des qu'un chunk de data est pret
if(cpt==SAMPLE_NBR)
cpt = 0;
ecriture_SD(data);
// recree l'instance SPI
nrf_delay_ms(100);
As I already said it work until I write in the SD card for the second time
Thanks for your time
