Hi all :) ,
I'm trying to create my new zip folder with new image.
I connect to my nrf52833, then i click on dfu button into nrfConnect mobil app.
I selec zip file option and strat uploading. Then the uC disconnect and restart. In the console, i see :
<debug> nrf_sdh_ble: BLE event: 0x51.<CR>
<debug> nrf_sdh_ble: BLE event: 0x53.<CR>
<info> app: Device is preparing to enter bootloader mode.<CR>
<debug> app: Disconnected connection handle 0<CR>
<info> app: Disconnected 1 links.<CR>
<debug> app: In ble_dfu_buttonless_bootloader_start_finalize<CR>
<CR>
<info> app: Device will enter bootloader mode.<CR>
<info> app: Power management wants to reset to DFU mode.<CR>
<info> app: Power management allowed to reset to DFU mode.<CR>
When i scan, i see DfuTarg , i connect to it and according to the documentation, at the connexion to the advertiser bootloader, it should update application. But nothing happen it stay connected. after may be 1 minute, it exit but my old application start so update ahas not worked .
I tried unsigned image but same result. I tried to increase application number too , same bad result.
Can you sum up please the different steps in order to be sure my config is ok please ? From bootloader program build ( with private key taken into account) , generation of settings.hex ?
All is a bit confusing with these files everywhere lol. I think i miss an obvious step somewhere and i also confuse between softdevice, bootloader files etc what to merge with merghex utilities etc ..
Hope my question is not to wide but i'm a bit lost with the seeral step and the order to proceed to be clean. As dfu process will be integrated to our own application, we need to really manage in a proper way all the steps to avoid having customers stuck with a corrupted device :D
Thank you very much !
