Nordic Thingy91 Error updating Modem Firmware
I have setup my new Thingy91 and got it connected to nrf Cloud.  I can see environmental sensor data in the terminal window but it is asking me to update the modem firmware to see services etc.
When I try and use nRF connect Programmer to update the modem firmware via USB it fails each time with the error message
"MCUboot DFU failed. Please make sure that the device is in MCUboot mode and try again."
I am powering up the device with SW3 pressed and I have the option ticked for MCUBoot.
Can you suggest what I should try next as I am not sure which application/firmware is working or not working and how to get the system updated to the latest firmware.
Regards
Mike
2020-07-24T10:09:12.068Z INFO Application data folder: /Users/michaelpyott/Library/Application Support/nrfconnect/pc-nrfconnect-programmer
2020-07-24T10:09:12.177Z DEBUG App pc-nrfconnect-programmer v1.4.3 official
2020-07-24T10:09:12.177Z DEBUG App path: /Users/michaelpyott/.nrfconnect-apps/node_modules/pc-nrfconnect-programmer
2020-07-24T10:09:12.177Z DEBUG nRFConnect 3.4.1 is supported by the app (^3.3.0)
2020-07-24T10:09:12.177Z DEBUG nRFConnect path: /Applications/nRF Connect.app/Contents/Resources/app.asar
2020-07-24T10:09:12.178Z DEBUG HomeDir: /Users/michaelpyott
2020-07-24T10:09:12.178Z DEBUG TmpDir: /var/folders/s3/x3kpzx597cddq3565v7c24kw0000gn/T/
2020-07-24T10:09:12.211Z INFO Using nrfjprog library 10.9.0, pc-nrfjprog-js 1.7.3
2020-07-24T10:09:12.213Z VERBOSE Could not fetch serial number for serial port at /dev/tty.Bluetooth-Incoming-Port
2020-07-24T10:09:12.213Z ERROR Error while probing devices: Error occured when get serial numbers. Errorcode: CouldNotCallFunction (0x9)
Lowlevel error: INVALID_OPERATION (fffffffe)
2020-07-24T10:10:53.563Z INFO Modem DFU starts to write...
2020-07-24T10:10:53.563Z INFO Writing /Users/michaelpyott/Desktop/Thingy91/thingy91_fw_2020-04-29_bc7ade8b/mfwnrf9160120.zip to device
2020-07-24T10:10:54.020Z ERROR MCUboot DFU failed. Please make sure that the device is in MCUboot mode and try again.
