Thingy:52 Mesh Network
Hello! I would like to implement a mesh network with some Thingy:52 boards. I have the following approach and I would need some general guidance for my next step, if it is possible.
My idea: I want to implement a communication between my phone and a development kit through a mesh network, formed of Thingy:52 devices.
My approach: For this, my idea would be the following: I started with a working example between my phone & the nRF 52840 board. I decided to go with the BLE Blinky Application, since it is quite straight-forward.
Question 1. Now, I am thinking how to integrate the Thingys:52 into my set-up, in order to build the mesh in-between. What kind of example should I start from? Do you have any suggestions?
Question 2. I read in some posts that the Thingys:52 should have this relay feature enabled by default, but I would like to know how is that made (i.e. in what function and/or what source code).
Thank you in advance and have a great week,
Marry
  • Hello.
    You can take a look at this ticket addressing a similar issue: https://devzone.nordicsemi.com/f/nordic-q-a/65033/combining-mesh-and-blinky-examples/
    - Thanks, I checked this, but it's not helping me at the moment. I'll keep an eye on it.
    Can you try copy from the template instead and remove #error message at the top of the fil? Does it make any difference?
    - I tried this. And now there is a new error mesh_opt_gatt.h not found...I commented the line in which that .h file is included and now I get new errors, as you may see in line 109.
    Rebuilding ‘ble_app_blinky_pca10056_s140’ from solution ‘ble_app_blinky_pca10056_s140’ in configuration ‘Release’
      Assembling ‘thumb_crt0.s’
      Compiling ‘nrf_log_backend_rtt.c’
      Compiling ‘nrf_log_backend_serial.c’
      Compiling ‘nrf_log_backend_uart.c’
      Compiling ‘nrf_log_default_backends.c’
      Compiling ‘nrf_log_frontend.c’
      Compiling ‘nrf_log_str_formatter.c’
      Compiling ‘app_button.c’
      Compiling ‘app_error.c’
      Compiling ‘app_error_handler_gcc.c’
      Compiling ‘app_error_weak.c’
      Compiling ‘app_scheduler.c’
      Compiling ‘app_timer.c’
      Compiling ‘app_util_platform.c’
      Compiling ‘hardfault_implementation.c’
      Compiling ‘nrf_assert.c’
      Compiling ‘nrf_atfifo.c’
      Compiling ‘nrf_atflags.c’
      Compiling ‘nrf_atomic.c’
      Compiling ‘nrf_balloc.c’
      Compiling ‘nrf_fprintf.c’
      Compiling ‘nrf_fprintf_format.c’
      Compiling ‘nrf_memobj.c’
      Compiling ‘nrf_pwr_mgmt.c’
      Compiling ‘nrf_ringbuf.c’
      Compiling ‘nrf_section_iter.c’
      Compiling ‘nrf_strerror.c’
      Assembling ‘ses_startup_nrf52840.s’
      Assembling ‘ses_startup_nrf_common.s’
      Compiling ‘system_nrf52840.c’
      Compiling ‘boards.c’
      Compiling ‘nrf_drv_clock.c’
      Compiling ‘nrf_drv_uart.c’
      Compiling ‘nrfx_atomic.c’
      Compiling ‘nrfx_clock.c’
      Compiling ‘nrfx_gpiote.c’
      Compiling ‘nrfx_prs.c’
      Compiling ‘nrfx_uart.c’
      Compiling ‘nrfx_uarte.c’
      Compiling ‘nrf_drv_pwm.c’
      Compiling ‘main.c’
      Compiling ‘SEGGER_RTT.c’
      Compiling ‘SEGGER_RTT_Syscalls_SES.c’
      Compiling ‘SEGGER_RTT_printf.c’
      Compiling ‘ble_advdata.c’
      Compiling ‘ble_conn_params.c’
      Compiling ‘ble_conn_state.c’
      Compiling ‘ble_srv_common.c’
      Compiling ‘nrf_ble_gatt.c’
      Compiling ‘nrf_ble_qwr.c’
      Compiling ‘utf.c’
      Compiling ‘ble_lbs.c’
      Compiling ‘nrf_sdh.c’
      Compiling ‘nrf_sdh_ble.c’
      Compiling ‘nrf_sdh_soc.c’
      Compiling ‘access.c’
      Compiling ‘access_publish.c’
      Compiling ‘access_publish_retransmission.c’
      Compiling ‘access_reliable.c’
      Compiling ‘ad_listener.c’
      Compiling ‘ad_type_filter.c’
      Compiling ‘adv_ext_packet.c’
      Compiling ‘adv_ext_tx.c’
      Compiling ‘advertiser.c’
      Compiling ‘adv_packet_filter.c’
      Compiling ‘aes.c’
      Compiling ‘aes_cmac.c’
      Compiling ‘assertion_handler_weak.c’
      Compiling ‘beacon.c’
      Compiling ‘bearer_handler.c’
      Compiling ‘bearer_event.c’
      Compiling ‘broadcast.c’
      Compiling ‘ccm_soft.c’
      Compiling ‘cache.c’
      Compiling ‘composition_data.c’
        composition_data.c
        taking address of packed member of 'struct <anonymous>' may result in an unaligned pointer value [-Waddress-of-packed-member]
        in definition of macro 'NRF_MESH_ASSERT'
      Compiling ‘config_server.c’
      Compiling ‘core_tx.c’
      Compiling ‘core_tx_adv.c’
      Compiling ‘core_tx_instaburst.c’
      Compiling ‘core_tx_local.c’
      Compiling ‘core_tx_lpn.c’
      Compiling ‘device_state_manager.c’
      Compiling ‘enc.c’
      Compiling ‘event.c’
      Compiling ‘fifo.c’
      Compiling ‘filter_engine.c’
      Compiling ‘flash_manager.c’
      Compiling ‘flash_manager_defrag.c’
      Compiling ‘flash_manager_internal.c’
      Compiling ‘fsm.c’
      Compiling ‘gap_address_filter.c’
      Compiling ‘hal.c’
      Compiling ‘heartbeat.c’
      Compiling ‘instaburst.c’
      Compiling ‘instaburst_rx.c’
      Compiling ‘internal_event.c’
      Compiling ‘instaburst_tx.c’
      Compiling ‘list.c’
      Compiling ‘log.c’
      Compiling ‘lpn.c’
      Compiling ‘main.c’
      Compiling ‘mesh_config.c’
      Compiling ‘mesh_config_backend.c’
      Compiling ‘mesh_config_flashman_glue.c’
        'FLASH_TIME_TO_WRITE_ONE_WORD_US' undeclared (first use in this function); did you mean 'FLASH_TIME_PER_WORD_US'?
        in expansion of macro 'FLASH_TIME_PER_WORD_US'
        each undeclared identifier is reported only once for each function it appears in
      Compiling ‘mesh_flash.c’
        nrf_mesh_assert.h
        nrf_mesh_dfu_types.h
        bl_if.h
        mesh_flash.h
        mesh_flash.c
        'FLASH_TIME_TO_ERASE_PAGE_US' undeclared here (not in a function)
        in definition of macro '_SELECT_ASSERT_FUNC'
        in expansion of macro 'STATIC_ASSERT_SIMPLE'
        in expansion of macro 'STATIC_ASSERT'
        in expansion of macro 'NRF_MESH_STATIC_ASSERT'
        expression in static assertion is not an integer
      Compiling ‘mesh_lpn_subman.c’
      Compiling ‘mesh_mem_mem_manager.c’
      Compiling ‘mesh_mem_packet_mgr.c’
    Build failed
    And regarding the optional changes
    Also, go through the "Optional changes" in the document.
    - I just tried to follow the tutorial step-by-step, I didn't skip anything and that is why I have not reached that part yet. But now that you suggested, I went through it and to be honest, I have no idea which of those optional changes applies to me. I did this part, however, like you suggested me:
    Copy it from the examples/templates folder in mesh stack repository into your project folder, and remove #error message at the top of the file
    But now there are new errors.
    If you have any new leads, I'd be grateful.
    Thanks!
  • Thanks for checking!
     Commenting out the "#include" might not help, as the file might be included elsewhere in the project.
    Have you made sure that the path to the header file is included in the user include directories?
    Br,
    Joakim
  • Do you mean, if the global macros are correctly defined:
    SDK_ROOT=C:\SESProj\nRF5_SDK_1530
    MESH_ROOT=C:\SESProj\nrf5_SDK_for_Mesh_v320 ?
  • Not exactly;
    The header files is included to the project by adding the path to the folder that contains the header file.
    This path is added to the user include directories:
    Project Options -> (Common configuration) -> Preprocessor -> User Include directories
    Here, from the light switch example, the path is included by taking advantage of the Mesh root folder:
    Have you made sure that the path to all the header files you use is included here?
    Br,
    Joakim
