Migration from micro_ecc to oberon backend for ECDSA. Signature verification failure.
I'm using code based on sdk/components/libraries/bootloader/dfu/ for ECDSA verification of the signature. But switched to Oberon crypto backend. The signature was successfully verified with micro ecc but fails with Oberon.
I suspect next can be the root cause:
// <q> NRF_CRYPTO_BACKEND_MICRO_ECC_LITTLE_ENDIAN_ENABLED - Enable non-standard little endian byte order.
// <i> This affects parameters for all ECC API (raw keys, signature, digest, shared secret). Only for use in nRF SDK DFU!
#ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_LITTLE_ENDIAN_ENABLED
#define NRF_CRYPTO_BACKEND_MICRO_ECC_LITTLE_ENDIAN_ENABLED 0
Please suggest the possible solution?
