S140 + TWI working together - problems
hi Forum.
I'm working on a project with nrf52840 + S140 + TWI (SDK v16). Got all working separatly on my custom board, i.e. softdevice alone works fine and TWI also works with different SDK examples (also I can adapt them to my needs...). The problem is when I join them together...TWI doesn't work properly any more.
Example: I can get Scanner example working before starting softdevice, but if I insert any "nrf_drv_twi_tx" or "nrf_drv_twi_rx" I get stuked  on "while (m_xfer_done == false)"; it never jumps to twi_handler, even after confirming (with I2C signal analyser) that the command is sent to my I2C device . I already loose several days trying to fix this, but can't get it work.
Also, can you advice correct way to get TWI work with S140? from what I've been here in forum it's the TWI HW way, correct? but I got somehow confused with the SDK v16 examples.
Thanks to all for reading.
