hai ,
i my application i need to update ota over serial . i m using nrf52840 and sdk 15.2
step 1 : at first flashed uart boot loader code on my board
step 2 : updated the application over serial is worked fine
but second time after changing to boot loader mode i got issues with not loading a new firmware file .
even not a ping response also.
i dont know whether the issue with button-less to enter in boot-loader mode or on boot-loader
application memory
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x100000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x40000
FLASH_START=0x26000
FLASH_SIZE=0xda000
RAM_START=0x20001cd0
RAM_SIZE=0x3e330
uart bootloader memory
FLASH_PH_START=0x0
RAM_PH_SIZE=0x40000
FLASH_START=0xe4000
FLASH_SIZE=0x1a000
RAM_START=0x20000008
RAM_SIZE=0x3fff8
completed with serial. but when i am merging the code its not entering the boot loader mode.
on uart boot-loader code just changed button-less option to 1 in sdk.h and timed out 2 mins
on my application side implemented for entering boot loader ,attached the code below.
#define BOOTLOADER_DFU_START 0xB1 void boot_mode() { nrf_delay_ms(100); NRF_POWER->GPREGRET = BOOTLOADER_DFU_START; nrf_delay_ms(100); NVIC_SystemReset(); }
but once its enter into boot mode after timeout also staying in same mode not changing to application.
dont know why ,same process done with BLE its working .
coming to over serial having these issues.
how to merge the code with sofdevice , uart boot loader , application and bl_settings.hex ?
is there any documentation for uart ?
could you please explain me on that ?
