Dear all,
I try to self provision device by it self following steps below:
Step 1 : Bind key
void app_common_self_provision(access_model_handle_t handle, bool is_client, uint16_t unicast_addr, uint8_t * netkey, uint8_t * appkey)
dsm_handle_t netkey_handle, devkey_handle;
dsm_local_unicast_address_t local_address;
local_address.address_start = unicast_addr;
local_address.count = ACCESS_ELEMENT_COUNT;
uint32_t status;
/* Store received provisioning data in the DSM */
status = dsm_local_unicast_addresses_set(&local_address);
ERROR_CHECK(status);
status = dsm_subnet_add(0, netkey, &netkey_handle);
// NRF_MESH_ERROR_CHECK(net_state_iv_index_set(0, 0));
dsm_handle_t app_handle;
dsm_handle_t network_handle = dsm_net_key_index_to_subnet_handle(0);
status = dsm_appkey_add(0, network_handle, appkey, &app_handle);
// ERROR_CHECK(dsm_devkey_add(unicast_addr, netkey_handle, m_provisioner.p_nw_data->self_devkey, &m_provisioner.p_dev_data->m_self_devkey_handle));
/* Bind config server to the device key */
if (!is_client)
status = config_server_bind(devkey_handle);
status = access_model_application_bind(handle, app_handle);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "provision_by_my_self done\r\n");
ERROR_CHECK(access_default_ttl_set(NRF_MESH_TTL_MAX));
}Step 2 : Subscribe to topic
void subscribe_default_topic()
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Add default subscribe topic\r\n");
dsm_handle_t subscription_address_handle;
uint32_t status;
status = dsm_address_subscription_add(m_dev_info.info.topic_all, &subscription_address_handle);
NRF_MESH_ERROR_CHECK(status);
status = access_model_subscription_add(m_custom_server_0.server.model_handle, subscription_address_handle);
status = dsm_address_subscription_add(m_dev_info.info.topic_control, &subscription_address_handle);
}Step3 : Set publication topic
static void add_default_publication_topic(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Add default publication topic\r\n");
dsm_handle_t publish_address_handle;
ERROR_CHECK(dsm_address_publish_add(m_dev_info.info.topic_report, &publish_address_handle));
ERROR_CHECK(access_model_publish_address_set(m_custom_server_0.server.model_handle, publish_address_handle));
ERROR_CHECK(access_model_publish_application_set(m_custom_server_0.server.model_handle, publish_address_handle));
Step 4 The main code to config device
#if 1
custom_application_server_t *p_server = &m_custom_server_0;
app_common_self_provision(p_server->server.model_handle,
false,
m_dev_info.info.exchange_pair_addr,
m_dev_info.info.key.netkey,
m_dev_info.info.key.appkey);
subscribe_default_topic();
add_default_publication_topic();
uint8_t id = PAIR_ID_PROCESS_DONE;
mesh_central_data_t msg;
msg.len = 1;
msg.data = &id;
mesh_device_central_send(&msg);
The problem is, after self provisioned and reboot device, when message publish from client in other node always return error 5 (NRF_ERROR_NOT_FOUND)
But when i comment out function subscribe_default_topic, device publish message without error.
Could you please give me your suggestion?
Thank you
