Hi All,
I am currently designing a BLE module using nRF52840 chip which works with battery.
In the nRF52840 DK, it uses a Power Switch Driver (SC728CSTRT) from Semtech. However, the particular component from Semtech has reached End Of Life.
I found another similar chip from Semtech (SC33020HCSTRT) with reverse blocking. My question is:
1. What is the correct way of connecting this component. In the old SC728CSTRT datasheet there are two 1.0uF capacitors connected to the ground at the input (VIN) and the output VOUT. But it wasn't there in nRF52840 DK schematic. A similar connection is suggested in the new SC33020HCSTRT datasheet as well. Below I have attached snapshot of my circuitry. Is my design is OK? Do you have any suggestions?
2. As shown above, I have connected the Enable pin with VIN. Is this acceptable?
3. Is it good idea to have a Power Switch Driver circuit?
Thanks a lot!!
