How to upgrade my nrf52810 over I2C (or UART) by using a nrf52832 as a bridge
In our product we have the following hardware configuration that implies two MCUs :
- a nrF52832 with BLE capability and running as an I2C master
- a nrf52810 runing as an I2C slave (without any BLE connection possibility)
I can upgrade the nrf52832 without any issue by using DFU and nRF Toolbox app but my question was about upgrading the nRF52810. In that case, the nRF52832 will acte as a bridge and it will transfer data over I2C (or UART if i reconfigure the pin, i didn't decide yet) to the nRF52810 DFU.
I know i will need to rewrite my own DFU for the nRF52810 but what i'm missing is the entry point. For the nRF52832, i can use nRF-Toolbox from my phone but which tool can i use for the nRF52810 ?
The BLE from my nRF52832 is the only interface to upgrade both CPU.
Is there someone that has already accomplished this ?
Aurélien
    Nordic does not provide anything that will give you this out of the box, so you would have to write something yourself, probably utilizing parts of the existing DFU solution.
    One possible way of doing it could be like this:
    • nRF52810 runs a serial bootloader form the SDK (we provide a UART transport layer which could be used, alternatively you would have to make a TWI transport)
    • The nRF52832 has a DFU master implementation. This is not something we provide for the nRF, so you would have to implement that yourself.
    • DFU master (phone) does a normal DFU upgrade via BLE of the nRF52832.
      • This firmware includes the firmware destined for the nRF52810. (If flash space on the 832 is a limiting factor, this could be a temporary firmware that has reduced functionality in order to hold the upgrade image of the 810 and DFU master implementation.)
    • The nRF52832 upgrades the nRF52810 via serial interface (UART or TWI) by acting as a DFU master.
    • (If a temporary firmware was used on the nRF52832, then it is updated again with the firmware it should normally have when not updating the 810).
    Update: You can find some unofficial serial DFU master implementations here.
    Einar
  • Hi Einar,
    Thank you very much for the answer and i'm sorry for the late reply.
    Indeed, what you propose is a kind of what i want excepted i wasn't thinking about storing the 810 binary onto the flash of the 832 but actually it is not a big deal. At first, i was thinking to just hook "upgrade" function on the 832 and then, directly transfer data on the serial port. Tell me if i'm wrong, but the upgrade protocole, whether is be uart or BLE, is the same, right ?
    I will take a look at the link you attached since i really need to find a solution to upgrade my 810 since we are deploying a batch of 200 devices for testing purpose in the coming month.
    Aurélien
  • Hi Aurélien,
    Ah, I see. I did not think of that, but I suppose it should be possible to make that work.
    Yes, that is correct. The DFU protocol itself is the same regardless of which transport layer you use.
    Br,
    Einar
  • Hi Einar,
    I ll try this and let you know if i'm facing issues Slight smile
    Aurélie
  • Actually, firstly i tried to update my nrf52810 directly by using a FTDI from my labtop, just to validate this part. Then i will switch on nrf52832 to implement the full part, nrf52810 + nrf52832
    But on the nrf52810, i'm facing an issue :
    <info> nrf_dfu_serial_uart: Allocated buffer 20000AF0
    <info> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <info> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <info> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
    <error> nrf_dfu_serial: Failed to send data over serial interface!
    on the laptop i'm seeing this when i try to upgrade by using nrfutil :
    > nrfutil dfu usb-serial -pkg consumer_aux_app_1_0_0.zip -p /dev/ttyUSB0 -b 9600
    2020-08-19 18:55:15,059 No trigger interface found for device with serial number: A50285BI, Product ID: 0x6001 and Vendor ID: 0x403
      File "/usr/local/bin/nrfutil", line 33, in <module>
        sys.exit(load_entry_point('nrfutil==6.1.0', 'console_scripts', 'nrfutil')())
      File "/home/aurelien/.local/lib/python3.6/site-packages/click/core.py", line 764, in __call__
        return self.main(*args, **kwargs)
      File "/home/aurelien/.local/lib/python3.6/site-packages/click/core.py", line 717, in main
        rv = self.invoke(ctx)
      File "/home/aurelien/.local/lib/python3.6/site-packages/click/core.py", line 1137, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "/home/aurelien/.local/lib/python3.6/site-packages/click/core.py", line 956, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "/home/aurelien/.local/lib/python3.6/site-packages/click/core.py", line 555, in invoke
        return callback(*args, **kwargs)
      File "/home/aurelien/.local/lib/python3.6/site-packages/nordicsemi/__main__.py", line 1015, in usb_serial
        timeout)
      File "/home/aurelien/.local/lib/python3.6/site-packages/nordicsemi/__main__.py", line 970, in do_serial
        dfu.dfu_send_images()
      File "/home/aurelien/.local/lib/python3.6/site-packages/nordicsemi/dfu/dfu.py", line 127, in dfu_send_images
        self._dfu_send_image(self.manifest.application)
      File "/home/aurelien/.local/lib/python3.6/site-packages/nordicsemi/dfu/dfu.py", line 88, in _dfu_send_image
        self.dfu_transport.open()
      File "/home/aurelien/.local/lib/python3.6/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 217, in open
        self.__get_mtu()
      File "/home/aurelien/.local/lib/python3.6/site-packages/nordicsemi/dfu/dfu_transport_serial.py", line 366, in __get_mtu
        self.mtu = struct.unpack('<H', bytearray(response))[0]
    TypeError: 'NoneType' object is not iterable
    ^C
    i'm working at 9600 baud without flow control (at least deactivated on the nrf52810 for sure and i think it is deactivated on nrfutil too)
    Do you have any idea why the upgrade is failing ?
    Aurélien
