My current setup is:
Nrf 52832 custom board (pca10040)
SDK 15.3.0
SES 4.52
Softdevice no s132
Using a j-link mini EDU debugger
I've been trying to follow the step by step guide as per this link https://devzone.nordicsemi.com/nordic/short-range-guides/b/software-development-kit/posts/getting-started-with-nordics-secure-dfu-bootloader.
I have completed everything until step D) testing DFU without any errors. The code of the secure_bootloader example pca10040_ble gets compiled successfully and dumped onto the board without any errors and runs properly but the DFUtarg label is not displayed on the NRFConnect application on my android device.
For testing, I dumped the pca10040_ble_debug version of the code onto the board and I still face the same issue. I've been trying to debug the code for a few days without any success. according the code the bsp board led switches on when it enter the dfu observer function meaning the board is waiting for dfu update but is not advertising. I've not made any changes to the sample code and it is as follows:-
static void dfu_observer(nrf_dfu_evt_type_t evt_type)
switch (evt_type)
case NRF_DFU_EVT_DFU_FAILED:
case NRF_DFU_EVT_DFU_ABORTED:
case NRF_DFU_EVT_DFU_INITIALIZED:
bsp_board_led_on(BSP_BOARD_LED_0);
bsp_board_led_on(BSP_BOARD_LED_1);
bsp_board_led_off(BSP_BOARD_LED_2);
case NRF_DFU_EVT_TRANSPORT_ACTIVATED:
bsp_board_led_off(BSP_BOARD_LED_1);
bsp_board_led_on(BSP_BOARD_LED_2);
case NRF_DFU_EVT_DFU_STARTED:
/**@brief Function for application main entry. */
uint32_t ret_val;
// Protect MBR and bootloader code from being overwritten.
ret_val = nrf_bootloader_flash_protect(0, MBR_SIZE, false);
APP_ERROR_CHECK(ret_val);
ret_val = nrf_bootloader_flash_protect(BOOTLOADER_START_ADDR, BOOTLOADER_SIZE, false);
(void) NRF_LOG_INIT(nrf_bootloader_dfu_timer_counter_get);
NRF_LOG_INFO("Inside main");
ret_val = nrf_bootloader_init(dfu_observer);
//APP_ERROR_CHECK(ret_val);
// Either there was no DFU functionality enabled in this project or the DFU module detected
// no ongoing DFU operation and found a valid main application.
// Boot the main application.
nrf_bootloader_app_start();
// Should never be reached.
NRF_LOG_INFO("After main");
I'm working on a nordic device for the first time and am very new to the SDK. Please let me know if i have done anything wrong.
